Not expected characters ("y" and "[") in gnome-terminal
Hello Everyone,
I’m experiencing a small graphical problem in the gnome-terminal (currently using zsh with default settings as the one provided by manjaro-zsh-config).
At the beginning of a terminal session, there are two small "y"s on the left side and an open square bracket on the right. What I see is this:
https://paste.pics/72a8aae04eb3bd56cf84bbe67c633deb
Verbally:
Manjaro logo - "y" char - house icon - pwd - "y" char - space - "["
Those are not supposed to be there, and they appeared after a reboot from the last update (2022-10-6).
Does anyone have an idea if this is related to gnome-terminal or zsh or else?
Thanks in advance!
  Kernel: 5.10.151-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=6fbab0e9-c0fe-4e46-803e-8a505f5ea8a1 rw quiet
    resume=UUID=d6c1c1d0-bcbd-441a-9a4f-ab9a734db90f udev.log_priority=3
  Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: ASUSTeK product: UX303UB v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: UX303UB v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: UX303UB.206 date: 03/02/2016
  ID-1: BAT0 charge: 28.9 Wh (76.1%) condition: 38.0/50.1 Wh (75.8%)
    volts: 11.3 min: 11.3 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: discharging cycles: 1545
  RAM: total: 7.67 GiB used: 2.67 GiB (34.8%)
  Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 516 high: 564 min/max: 400/3100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 564 2: 500 3: 500 4: 500
    bogomips: 20810
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
    class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 940M] vendor: ASUSTeK driver: nvidia
    v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1347
    class-ID: 0302
  Device-3: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-5:3 chip-ID: 0bda:57cb class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.4
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1361 built: 2014 res: 1920x1080
    hz: 60 dpi: 166 gamma: 1.2 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel HD Graphics 520 (SKL
    GT2) direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
    chip-ID: 8086:9d70 class-ID: 0403
  Sound API: ALSA v: k5.10.151-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 16.1 running: no
  Sound Server-3: PipeWire v: 0.3.59 running: yes
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
    bus-ID: 1-8:4 chip-ID: 8087:0a2a class-ID: e001
  Local Storage: total: 238.47 GiB used: 150.82 GiB (63.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS256G32MND-2200A
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 0L00 scheme: GPT
  ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
    used: 150.82 GiB (67.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 6fbab0e9-c0fe-4e46-803e-8a505f5ea8a1
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 2854-02D4
    dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: d6c1c1d0-bcbd-441a-9a4f-ab9a734db90f
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: Logitech Wireless Receiver type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
    chip-ID: 046d:c542 class-ID: 0301
  Device-2: 1-5:3 info: Realtek USB2.0 HD UVC WebCam type: Video
  Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 45.0 C pch: 39.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 2300
  Processes: 223 Uptime: 33m wakeups: 1 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1441 libs: 384 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.23
If you are not using defaults - it is impossible to deduct anything.
It is known that some extensions does not work well with Gnome 43 - there is something with the terminal - it has been covered several times - I suggest a more nuanced search.
First, thanks for the reply!
You are absolutely right. Actually, the only customization I made to my terminal was a change of font that I find out only now (I stress that all I point out in the first post are the default customizations shipped with the gnome flavor of Manjaro, specifically zsh and manjaro-zsh-config).
For the record: this behavior was caused by DejaVu Sans Mono, other fonts such as Droid Sans Mono sold the issue.
P.s. as the system details show, I am using Gnome 42.5. No gnome extension is used related to the terminal.
Cheers!
