Hello,
When using nonfree nvidia driver I am stuck with a white cursor on a blackscreen on startup, this also happens when booting with nonfree driver with the latest manjaro xfce iso. (in both cases, tty doesn’t work)
I tried to reinstall, it works as expected until I install nonfree drivers and reboot.
I am using kernel 5.15.25-1
I have the laptop asus rog strix scar g533 with a 3070ti
I reinstalled manjaro and just did mhwd -a pci nonfree 0300
and the same issue happened after reboot
I got the following output by chrooting from intallation media:
sh-5.1# inxi -G
12Graphics:
12Device-1 Intel Alder Lake-P Integrated Graphics 12driver i915 12v kernel
12Device-2 NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] 12driver nouveau 12v kernel
12Display 12server X.Org 12v 1.21.1.3 12driver 12X 12loaded modesetting,nvidia 12gpu i915
12resolution 2560x1440~240Hz
12Message Unable to show GL data. Required tool glxinfo missing.
Output of journalctl -b1 -p4
Mar 06 21:40:35 quenouille kernel: #13 #14 #15 #16 #17 #18 #19
Mar 06 21:40:35 quenouille kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Mar 06 21:40:35 quenouille kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.PC00.LPCB.SEN2 (20210730/dspkginit-438)
Mar 06 21:40:35 quenouille kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Mar 06 21:40:35 quenouille kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Mar 06 21:40:35 quenouille kernel: hpet_acpi_add: no address or irqs in _CRS
Mar 06 21:40:35 quenouille kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 06 21:40:35 quenouille kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 06 21:40:35 quenouille kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 06 21:40:35 quenouille kernel: pci 10000:e0:06.0: Primary bus is hard wired to 0
Mar 06 21:40:35 quenouille kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT D
Mar 06 21:40:35 quenouille kernel: pcieport 10000:e0:06.0: PCI INT D: no GSI
Mar 06 21:40:35 quenouille kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT A
Mar 06 21:40:35 quenouille kernel: nvme 10000:e1:00.0: PCI INT A: not connected
Mar 06 21:40:35 quenouille kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Mar 06 21:40:35 quenouille kernel: nvidia: loading out-of-tree module taints kernel.
Mar 06 21:40:35 quenouille kernel: nvidia: module license 'NVIDIA' taints kernel.
Mar 06 21:40:35 quenouille kernel: Disabling lock debugging due to kernel taint
Mar 06 21:40:35 quenouille kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.54 Tue Feb 8 04:42:21 UTC 2022
Mar 06 21:40:36 quenouille kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Mar 06 21:40:37 quenouille kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcffff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
Mar 06 21:40:37 quenouille kernel: caller igen6_probe+0x1a2/0x7d0 [igen6_edac] mapping multiple BARs
Mar 06 21:40:37 quenouille kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-66.ucode failed with error -2
Mar 06 21:40:37 quenouille kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-65.ucode failed with error -2
Mar 06 21:40:37 quenouille kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Mar 06 21:40:38 quenouille kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Mar 06 21:40:39 quenouille kernel: kauditd_printk_skb: 44 callbacks suppressed
Mar 06 21:40:41 quenouille kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
Mar 06 21:40:41 quenouille kernel: caller tgl_uncore_imc_freerunning_init_box+0xbf/0x100 [intel_uncore] mapping multiple BARs
Mar 06 21:40:43 quenouille kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Mar 06 21:40:43 quenouille kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Mar 06 21:40:43 quenouille kernel: NVRM: GPU at PCI:0000:01:00: GPU-f016a8c2-dbcb-8434-293a-bb41271e5b55
Mar 06 21:40:43 quenouille kernel: NVRM: Xid (PCI:0000:01:00): 62, pid=963, 0000(0000) 00000000 00000000
Mar 06 21:40:47 quenouille kernel: BUG: kernel NULL pointer dereference, address: 0000000000000048
Mar 06 21:40:47 quenouille kernel: #PF: supervisor write access in kernel mode
Mar 06 21:40:47 quenouille kernel: #PF: error_code(0x0002) - not-present page
Mar 06 21:40:47 quenouille kernel: Oops: 0002 [#1] PREEMPT SMP NOPTI
Mar 06 21:40:47 quenouille kernel: CPU: 6 PID: 963 Comm: Xorg Tainted: P OE 5.15.25-1-MANJARO #1 e15baac653f22a5e80697cd53468da94469c43a0
Mar 06 21:40:47 quenouille kernel: Hardware name: ASUSTeK COMPUTER INC. ROG Strix G533ZW_G533ZW/G533ZW, BIOS G533ZW.310 02/22/2022
Mar 06 21:40:47 quenouille kernel: RIP: 0010:_nv033456rm+0xac/0x130 [nvidia]
Mar 06 21:40:47 quenouille kernel: Code: 44 89 e0 5b 41 5c c3 0f 1f 80 00 00 00 00 48 c1 e1 06 48 03 8c fe 58 23 00 00 45 84 c0 8b 50 08 44 8b 48 0c 74 78 85 db 74 3c <48> 83 41 08 01 0f b6 10 83 e2 03 80 fa 03 75 bf 45 84 c0 75 ba 0f
Mar 06 21:40:47 quenouille kernel: RSP: 0018:ffffa5ed41d87710 EFLAGS: 00010206
Mar 06 21:40:47 quenouille kernel: RAX: ffff89c00566dd80 RBX: 0000000000000055 RCX: 0000000000000040
Mar 06 21:40:47 quenouille kernel: RDX: 0000000000000089 RSI: ffff89c027418008 RDI: 0000000000000013
Mar 06 21:40:47 quenouille kernel: RBP: ffff89c00566dd30 R08: 0000000000000001 R09: 0000000000000000
Mar 06 21:40:47 quenouille kernel: R10: 0000000000001d50 R11: 0000000000000000 R12: 0000000000000055
Mar 06 21:40:47 quenouille kernel: R13: ffff89c027418008 R14: 0000000000000014 R15: ffff89c01fb98008
Mar 06 21:40:47 quenouille kernel: FS: 00007f37d44ef940(0000) GS:ffff89c3a0180000(0000) knlGS:0000000000000000
Mar 06 21:40:47 quenouille kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mar 06 21:40:47 quenouille kernel: CR2: 0000000000000048 CR3: 0000000104ee6004 CR4: 0000000000770ee0
Mar 06 21:40:47 quenouille kernel: PKRU: 55555554
Mar 06 21:40:47 quenouille kernel: Call Trace:
Mar 06 21:40:47 quenouille kernel: <TASK>
Mar 06 21:40:47 quenouille kernel: ? _nv033453rm+0x162/0x2f0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv032298rm+0x128/0x1f0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv032298rm+0xf8/0x1f0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv010911rm+0x4e/0xc0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv033836rm+0x109/0x220 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv009158rm+0x115/0x170 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv011979rm+0x2b5/0x4c0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv012024rm+0x25d/0x310 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv014228rm+0x3a/0x100 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv015165rm+0x16e/0x3c0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv021890rm+0x91/0x1e0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv021891rm+0x21/0x40 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv000696rm+0x1aa/0x2f0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? _nv000643rm+0x49c/0x20b0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? rm_init_adapter+0xc5/0xe0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? try_to_wake_up+0x213/0x590
Mar 06 21:40:47 quenouille kernel: ? nv_open_device+0x23b/0x8c0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? nvidia_open+0x2f1/0x600 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? kobj_lookup+0xf0/0x170
Mar 06 21:40:47 quenouille kernel: ? nvidia_frontend_open+0x50/0xa0 [nvidia 3acc3577c0c2537cfcaadec2747c3973c47d586b]
Mar 06 21:40:47 quenouille kernel: ? chrdev_open+0xc8/0x260
Mar 06 21:40:47 quenouille kernel: ? cdev_device_add+0x90/0x90
Mar 06 21:40:47 quenouille kernel: ? do_dentry_open+0x14c/0x3c0
Mar 06 21:40:47 quenouille kernel: ? path_openat+0xbbb/0x1030
Mar 06 21:40:47 quenouille kernel: ? try_to_unlazy+0x4c/0x90
Mar 06 21:40:47 quenouille kernel: ? terminate_walk+0x61/0xf0
Mar 06 21:40:47 quenouille kernel: ? path_lookupat+0x82/0x1a0
Mar 06 21:40:47 quenouille kernel: ? do_filp_open+0xa5/0x150
Mar 06 21:40:47 quenouille kernel: ? do_sys_openat2+0xc4/0x190
Mar 06 21:40:47 quenouille kernel: ? __x64_sys_openat+0x53/0xa0
Mar 06 21:40:47 quenouille kernel: ? do_syscall_64+0x59/0x90
Mar 06 21:40:47 quenouille kernel: ? __audit_syscall_exit+0x255/0x2c0
Mar 06 21:40:47 quenouille kernel: ? syscall_exit_to_user_mode+0x23/0x50
Mar 06 21:40:47 quenouille kernel: ? do_syscall_64+0x69/0x90
Mar 06 21:40:47 quenouille kernel: ? entry_SYSCALL_64_after_hwframe+0x44/0xae
Mar 06 21:40:47 quenouille kernel: </TASK>
Mar 06 21:40:47 quenouille kernel: Modules linked in: ccm cmac algif_hash algif_skcipher af_alg bnep joydev btusb btrtl btbcm mousedev btintel bluetooth ecdh_generic hid_asus iTCO_wdt mei_hdcp intel_pmc_bxt iTCO_vendor_support hid_multitouch intel_rapl_msr intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr asus_nb_wmi asus_wmi sparse_keymap platform_profile wmi_bmof snd_hda_codec_realtek snd_hda_codec_generic usbhid snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp iwlmvm snd_sof snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match mac80211 snd_soc_acpi soundwire_bus intel_spi_pci ledtrig_audio intel_spi snd_soc_core r8169 squashfs spi_nor libarc4 i2c_i801 qrtr snd_compress realtek iwlwifi ns mtd mei_me mdio_devres ac97_bus loop i2c_smbus
Mar 06 21:40:47 quenouille kernel: snd_pcm_dmaengine libphy mei cfg80211 intel_lpss_pci snd_hda_codec_hdmi intel_lpss idma64 rfkill snd_hda_intel vfat snd_intel_dspcfg fat thunderbolt snd_intel_sdw_acpi i915 snd_hda_codec snd_hda_core snd_hwdep processor_thermal_device_pci snd_pcm processor_thermal_device processor_thermal_rfim processor_thermal_mbox ucsi_acpi snd_timer processor_thermal_rapl typec_ucsi snd ttm intel_rapl_common typec intel_gtt soundcore igen6_edac roles mac_hid i2c_hid_acpi i2c_hid ov13858 v4l2_fwnode v4l2_async tpm_crb int3403_thermal int340x_thermal_zone videodev tpm_tis mc tpm_tis_core tpm rng_core int3400_thermal acpi_thermal_rel acpi_tad acpi_pad uinput nvidia_uvm(POE) nvidia_drm(POE) nvidia_modeset(POE) nvidia(POE) fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 i8042 crc32c_intel vmd xhci_pci wmi serio video
Mar 06 21:40:47 quenouille kernel: ---[ end trace cba8acb1541d0309 ]---
sh-5.1# mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
My bios is updated
I tried to remove the nouveau driver using
mhwd -r pci video-nvidia
but it didn’t help
sh-5.1# inxi --full
\12System:
12Kernel 5.15.25-1-MANJARO x86_64 12bits 64 12Desktop Xfce 4.16.0 12Distro Manjaro Linux
12Machine:
12Type Laptop 12System ASUSTeK 12product ROG Strix G533ZW_G533ZW 12v 1.0 12serial <filter>
12Mobo ASUSTeK 12model G533ZW 12v 1.0 12serial <filter> 12UEFI American Megatrends LLC. 12v G533ZW.310
12date 02/22/2022
12Battery:
12ID-1 BAT0 12charge 91.1 Wh (100.0%) 12condition 91.1/90.0 Wh (101.2%)
12CPU:
12Info 14-core (6-mt/8-st) 12model 12th Gen Intel Core i9-12900H 12bits 64 12type MST AMCP 12cache
12L2 11.5 MiB
12Speed (MHz) 12avg 512 12min/max 400/5000:3800 12cores 121 572 122 401 123 579 124 507 125 556 126 458 127 539
128 590 129 467 1210 460 1211 441 1212 448 1213 492 1214 562 1215 570 1216 615 1217 510 1218 485 1219 493 1220 503
12Graphics:
12Audio:
12Device-1 Intel Alder Lake PCH-P High Definition Audio 12driver snd_hda_intel
12Device-2 NVIDIA GA104 High Definition Audio 12driver snd_hda_intel
12Sound Server-1 ALSA 12v k5.15.25-1-MANJARO 12running yes
12Sound Server-2 PulseAudio 12v 15.0 12running yes
12Network:
12Device-1 Intel Alder Lake-P PCH CNVi WiFi 12driver iwlwifi
12IF wlo1 12state up 12mac <filter>
12Device-2 Realtek RTL8125 2.5GbE 12driver r8169
12IF enp44s0 12state down 12mac <filter>
12Bluetooth:
12Device-1 Intel 12type USB 12driver btusb
12Report rfkill 12ID hci0 12rfk-id 1 12state down 12bt-service N/A 12rfk-block 12hardware no 12software yes
12address see --recommends
12RAID:
12Hardware-1 Intel Volume Management Device NVMe RAID Controller 12driver vmd
12Drives:
12Local Storage 12total 1.88 TiB 12used 9.84 GiB (0.5%)
12ID-1 /dev/nvme0n1 12vendor Samsung 12model MZVL22T0HBLB-00B00 12size 1.86 TiB
12ID-2 /dev/sda 12type USB 12vendor SanDisk 12model Cruzer Blade 12size 14.59 GiB
12Partition:
12ID-1 / 12size 319.45 GiB 12used 9.84 GiB (3.1%) 12fs ext4 12dev /dev/nvme0n1p7
12Swap:
12Alert No swap data was found.
12Sensors:
12System Temperatures 12cpu 27.8 C 12mobo N/A
12Fan Speeds (RPM) 12cpu 2100
12Info:
12Processes 378 12Uptime 31m 12Memory 15.29 GiB 12used 3.17 GiB (20.7%) 12Client Unknown Client: systemd
12inxi 3.3.13
