Not booting to desktop - kernel 6.12
I tried kernel 6.12.4-1 and this kernel does not boot to desktop KDE and no splash screen.
inxi -Fza:
  Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
    root=UUID=86b44fe2-10a4-46cd-a916-50fa4f477973 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Server System: Supermicro product: X10SRA v: 0123456789
    serial: <filter> Chassis: type: 17 v: 0123456789 serial: <filter>
  Mobo: Supermicro model: X10SRA v: 1.01 serial: <filter>
    uuid: 00000000-0000-0000-0000-ac1f6b15f24c UEFI: American Megatrends v: 2.1a
    date: 10/24/2018
  Info: model: Intel Core i7-6800K socket: LGA2011-3 bits: 64 type: MT MCP
    arch: Broadwell gen: core 6 level: v3 note: check built: 2015-18
    process: Intel 14nm family: 6 model-id: 0x4F (79) stepping: 1
    microcode: 0xB000040
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 15 MiB desc: 1x15 MiB
  Speed (MHz): avg: 3800 min/max: 1200/3800 base/boost: 3400/4000 scaling:
    driver: intel_cpufreq governor: schedutil volts: 1.8 V ext-clock: 100 MHz
    cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800 6: 3800 7: 3800 8: 3800
    9: 3800 10: 3800 11: 3800 12: 3800 bogomips: 81646
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nouveau v: kernel
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 10de:2182
    class-ID: 0300 temp: 25.0 C
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    alternate: fbdev,vesa dri: nouveau gpu: nouveau display-ID: 0
  Monitor-1: DP-1 model: Dell U2713HM serial: <filter> built: 2012 res:
    mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
    device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
    drv: nouveau x11: drv: nouveau
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.8-arch1.1 glx-v: 1.4
    direct-render: yes renderer: NV168 device-ID: 10de:2182 memory: 5.84 GiB
    unified: no display-ID: :1.0
  Device-1: Intel C610/X99 series HD Audio vendor: Super Micro
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
    class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 03:00.1 chip-ID: 10de:1aeb class-ID: 0403
  API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel I210 Gigabit Network vendor: Super Micro driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
    chip-ID: 8086:1533 class-ID: 0200
  Device-2: Intel I210 Gigabit Network vendor: Super Micro driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
  IF: eno2 state: down mac: <filter>
  Info: services: NetworkManager
  Local Storage: total: 1.36 TiB used: 313.15 GiB (22.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 19.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 52d 7h cycles: 17,428
    read-units: 111,398,750 [57.0 TB] written-units: 35,733,524 [18.2 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    family: based SSDs size: 232.89 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 4B6Q temp: 18 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 158d 14h cycles: 33365
    written: 1.12 TiB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 2B6Q temp: 19 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 76d 19h cycles: 12989
    written: 3.58 TiB
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 9.04 GiB (9.2%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8
  ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
    used: 231.7 MiB (23.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
    maj-min: 259:6
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 300 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
    maj-min: 259:5
  ID-4: /home raw-size: 300 GiB size: 294.23 GiB (98.08%)
    used: 15.93 GiB (5.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p9
    maj-min: 259:9
  ID-5: /var raw-size: 32.46 GiB size: 31.66 GiB (97.51%)
    used: 11.32 GiB (35.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p10
    maj-min: 259:10
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p7 maj-min: 259:7
  System Temperatures: cpu: 16.0 C pch: 28.5 C mobo: N/A gpu: nouveau
    temp: 25.0 C
  Fan Speeds (rpm): N/A gpu: nouveau fan: 461
  Memory: total: 32 GiB available: 31.22 GiB used: 2.51 GiB (8.0%)
  Processes: 290 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1285 libs: 361 tools: pamac pm: flatpak pkgs: 0
    Compilers: N/A Shell: Bash (su) v: 5.2.37 running-in: konsole inxi: 3.3.37
Something seem to be wrong as the Kernel parameters still show 6.6.65
Did you fully update first? If not, you’d be in a partial update status.
Hi @Keruskerfuerst,
I suspect that output is from a still-working kernel.
We need more information. I am using 6.12 as I type this, so it does work. (And I have an Nvidia GPU.)
So kindly provide more information, and provide the output of the following:
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • the --no-pager formats the output nicely for use here, on the forum; and
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
More:
Note that the above text is partially pre-prepared as general instructions for new users. Please take the time to follow the given links to learn more.
Yes, that’s my assumption as well. Seem to be that the update at least partially didn’t go through.
I am using also 6.12 and my secondary GPU is working without issues.
is you video card is recognized well with wayland / and drivers nouveau ,
also missing boot kernel parameter
( in case of nvidia drivers , not nouveau drivers )
nvidia-drm.modeset=1 nvidia_drm.fbdev=1
you can check this point
sudo cat /sys/module/nvidia_drm/parameters/modeset
Y or N
Is there maybe something wrong with nvidia and kernel 6.12 in the branch?
  1. I can´t boot kernel 6.12.4-1: no desktop, no tty.
  2. I am using the noveau driver.
  3. The system is fully updated.
  4. cat: /sys/module/nvidia_drm/parameters/modeset: Datei oder Verzeichnis nicht gefunden
output:
Jan 22 16:12:21 Workstation kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Jan 22 16:12:21 Workstation kernel: TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_abort.html for more details.
Jan 22 16:12:21 Workstation kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Jan 22 16:12:21 Workstation kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jan 22 16:12:21 Workstation kernel: ata8.00: supports DRM functions and may not be fully accessible
Jan 22 16:12:21 Workstation kernel: ata7.00: supports DRM functions and may not be fully accessible
Jan 22 16:12:21 Workstation kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Jan 22 16:12:21 Workstation systemd-fstab-generator[344]: Mount point Partition is not a valid path, ignoring.
Jan 22 16:12:22 Workstation kernel: i2c i2c-19: Systems with more than 4 memory slots not supported yet, not instantiating SPD
Jan 22 16:12:22 Workstation kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Jan 22 16:12:22 Workstation kernel: EDAC sbridge: Couldn't find mci handler
Jan 22 16:12:22 Workstation kernel: EDAC sbridge: Failed to register device with error -19.
Jan 22 16:12:23 Workstation kernel: nvidia-gpu 0000:03:00.3: i2c timeout error e0000000
Jan 22 16:12:23 Workstation kernel: ucsi_ccg 18-0008: i2c_transfer failed -110
Jan 22 16:12:23 Workstation kernel: ucsi_ccg 18-0008: ucsi_ccg_init failed - -110
Jan 22 16:12:23 Workstation kernel: ucsi_ccg: probe of 18-0008 failed with error -110
Jan 22 16:12:25 Workstation dbus-broker-launch[629]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jan 22 16:12:25 Workstation dbus-broker-launch[702]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jan 22 16:12:25 Workstation dbus-broker-launch[702]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jan 22 16:12:25 Workstation dbus-broker-launch[702]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jan 22 16:12:28 Workstation dbus-broker-launch[629]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jan 22 16:12:28 Workstation kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:f0:b0:14:71:f4:8f:08:00 SRC=192.168.188.1 DST=224.0.0.1 LEN=52 TOS=0x00 PREC=0x00 TTL=1 ID=19862 PROTO=UDP SPT=5351 DPT=5350 LEN=32
Jan 22 16:12:29 Workstation sddm-greeter-qt6[698]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Jan 22 16:12:30 Workstation dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jan 22 16:12:30 Workstation dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jan 22 16:12:30 Workstation dbus-broker-launch[762]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jan 22 16:12:30 Workstation kwin_wayland[775]: kwin_wayland_drm: drmSetClientCap for Atomic Mode Setting failed. Using legacy mode on GPU "/dev/dri/card0"
Jan 22 16:12:31 Workstation wireplumber[841]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
Jan 22 16:12:31 Workstation wireplumber[841]: spa.bluez5: BlueZ system service is not available
Jan 22 16:12:31 Workstation kded6[896]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Jan 22 16:12:31 Workstation kded6[896]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Jan 22 16:12:31 Workstation kded6[896]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Jan 22 16:12:32 Workstation kconf_update[957]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Jan 22 16:12:32 Workstation kconf_update[957]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Jan 22 16:12:32 Workstation kconf_update[957]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Jan 22 16:12:32 Workstation kconf_update[957]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Jan 22 16:12:32 Workstation kconf_update[957]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Jan 22 16:12:32 Workstation kconf_update[957]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Jan 22 16:12:32 Workstation dbus-broker-launch[629]: Activation request for 'org.freedesktop.ModemManager1' failed: The systemd unit 'dbus-org.freedesktop.ModemManager1.service' could not be found.
Jan 22 16:12:32 Workstation kded6[896]: kf.modemmanagerqt: Failed enumerating MM objects: "org.freedesktop.DBus.Error.NameHasNoOwner"
                                         "Could not activate remote peer 'org.freedesktop.ModemManager1': activation request failed: unknown unit"
Jan 22 16:12:32 Workstation kded6[896]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Jan 22 16:12:32 Workstation kded6[896]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
Jan 22 16:12:32 Workstation kded6[896]: kf.bluezqt: PendingCall Error: "Could not activate remote peer 'org.bluez': unit failed"
Jan 22 16:12:32 Workstation kactivitymanagerd[956]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod&) may only be used on X11
Jan 22 16:12:32 Workstation plasmashell[942]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
                                              file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Jan 22 16:12:32 Workstation plasmashell[942]: Toolbox not loading, toolbox package is either invalid or disabled.
Jan 22 16:12:32 Workstation plasmashell[942]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.40'
Jan 22 16:12:33 Workstation plasmashell[942]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x56144ab5b410
Jan 22 16:12:33 Workstation plasmashell[942]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x56144ab5b410
Jan 22 16:12:33 Workstation plasmashell[942]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Jan 22 16:12:34 Workstation kdeconnectd[1078]: 2025-01-22T16:12:34 default: Cannot find a compatible running Bluez. Please check the Bluez installation. QtBluetooth requires at least BlueZ version 5.
Jan 22 16:12:34 Workstation kdeconnectd[1078]: 2025-01-22T16:12:34 kdeconnect.core: No local bluetooth adapter found
Jan 22 16:12:34 Workstation plasmashell[942]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Jan 22 16:12:34 Workstation plasmashell[942]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 22 16:12:34 Workstation plasmashell[942]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
Jan 22 16:12:35 Workstation backlighthelper[1116]: org.kde.powerdevil: no kernel backlight interface found
Jan 22 16:12:35 Workstation org_kde_powerdevil[963]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 22 16:12:35 Workstation org_kde_powerdevil[963]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Jan 22 16:12:35 Workstation org_kde_powerdevil[963]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jan 22 16:12:35 Workstation kwin_wayland[775]: kwin_libinput: Libinput: event2  - Logitech G300s Optical Gaming Mouse: client bug: event processing lagging behind by 22ms, your system is too slow
Jan 22 16:12:35 Workstation kwin_wayland[775]: kwin_libinput: Libinput: event2  - Logitech G300s Optical Gaming Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
Jan 22 16:12:36 Workstation kwin_wayland[775]: kwin_libinput: Libinput: event2  - Logitech G300s Optical Gaming Mouse: client bug: event processing lagging behind by 21ms, your system is too slow
Jan 22 16:12:37 Workstation kwin_wayland[775]: kwin_libinput: Libinput: event2  - Logitech G300s Optical Gaming Mouse: client bug: event processing lagging behind by 21ms, your system is too slow
Jan 22 16:12:37 Workstation kwin_wayland[775]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x561d22c4ca90)
Jan 22 16:12:40 Workstation kwin_wayland[775]: This plugin does not support grabbing the keyboard
Jan 22 16:12:42 Workstation kwin_wayland[775]: This plugin does not support grabbing the keyboard
Jan 22 16:12:45 Workstation kwin_wayland[775]: This plugin does not support grabbing the keyboard
Jan 22 16:12:47 Workstation kwin_wayland[775]: This plugin does not support grabbing the keyboard
Jan 22 16:12:55 Workstation kioworker[1432]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Jan 22 16:12:55 Workstation kioworker[1432]: kf.kio.core: An error occurred during write. The worker terminates now.
Jan 22 16:12:55 Workstation dolphin[1213]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Jan 22 16:12:55 Workstation dolphin[1213]: kf.kio.core: Connection::send() called with connection not inited
Jan 22 16:13:00 Workstation kwin_wayland[775]: kwin_libinput: Libinput: event2  - Logitech G300s Optical Gaming Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
Jan 22 16:13:00 Workstation kwin_wayland[775]: kwin_libinput: Libinput: event2  - Logitech G300s Optical Gaming Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
Jan 22 16:14:31 Workstation kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:f0:b0:14:71:f4:8f:08:00 SRC=192.168.188.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=29115 DF PROTO=2
Jan 22 16:16:36 Workstation kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:f0:b0:14:71:f4:8f:08:00 SRC=192.168.188.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=32826 DF PROTO=2
Jan 22 16:18:41 Workstation kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:f0:b0:14:71:f4:8f:08:00 SRC=192.168.188.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=57727 DF PROTO=2
Jan 22 16:18:59 Workstation kernel: [UFW BLOCK] IN=eno1 OUT= MAC=33:33:00:00:00:01:f0:b0:14:71:f4:8f:86:dd SRC=fe80:0000:0000:0000:f2b0:14ff:fe71:f48f DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=53805 DPT=53805 LEN=24
Jan 22 16:20:46 Workstation kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:f0:b0:14:71:f4:8f:08:00 SRC=192.168.188.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=19452 DF PROTO=2
Jan 22 16:20:53 Workstation ksmserver-logout-greeter[3949]: kf.windowsystem: static bool KX11Extras::compositingActive() may only be used on X11
Jan 22 16:20:54 Workstation ksmserver-logout-greeter[3949]: kf.windowsystem: static bool KX11Extras::compositingActive() may only be used on X11
Jan 22 16:20:55 Workstation sddm-helper[721]: Signal received: SIGTERM
Jan 22 16:20:55 Workstation sddm[674]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Jan 22 16:20:55 Workstation sddm[674]: Auth: sddm-helper (--socket /tmp/sddm-auth-0817a681-bbd9-4f46-a23e-d866cb5831c8 --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user armin) crashed (exit code 1)
Jan 22 16:20:55 Workstation sddm[674]: Auth: sddm-helper exited with 1
Jan 22 16:20:55 Workstation sddm[674]: Signal received: SIGTERM
Jan 22 16:20:55 Workstation plasmashell[942]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Jan 22 16:20:55 Workstation kded6[896]: kf.notifications: Playing audio notification failed: Destroyed
Jan 22 16:20:55 Workstation plasmashell[942]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
Jan 22 16:20:55 Workstation kdeconnectd[1078]: 2025-01-22T16:20:55 default: The Wayland connection broke. Did the Wayland compositor die?
Jan 22 16:20:55 Workstation kdeconnectd[1078]: 2025-01-22T16:20:55 qt.qpa.wayland: Attempting wayland reconnect
Jan 22 16:20:55 Workstation kdeconnectd[1078]: 2025-01-22T16:20:55 default: Failed to write to the pipe: UngĂĽltiger Dateideskriptor.
Jan 22 16:20:55 Workstation wireplumber[841]: pw.core: 0x562b71361900: leaked proxy 0x562b71453040 id:3
Jan 22 16:20:55 Workstation wireplumber[841]: pw.core: 0x562b71361900: leaked proxy 0x562b713ef5e0 id:4
Jan 22 16:20:55 Workstation (sd-pam)[730]: pam_systemd(systemd-user:session): Failed to release session: Caller does not belong to any known session.
Jan 22 16:20:56 Workstation dbus-broker-launch[629]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Kernel 6.12.4-1 does not boot to desktop and tty, so I can´t give information.
The computer freezes after login → reset button.
But I can boot kernel 6.12.4-1 to login screen (KDE) and post information.
Then it should have been obvious to do this:
…from the working kernel, wouldn’t you say?
After some tries, I could reproduce the hard lock:
Jan 24 13:52:02 Workstation kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Jan 24 13:52:02 Workstation kernel: TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_abort.html for more details.
Jan 24 13:52:02 Workstation kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Jan 24 13:52:02 Workstation kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jan 24 13:52:02 Workstation kernel: ata8.00: Model 'Samsung SSD 850 EVO 250GB', rev 'EMT02B6Q', applying quirks: noncqtrim zeroaftertrim
Jan 24 13:52:02 Workstation kernel: ata7.00: Model 'Samsung SSD 860 EVO 250GB', rev 'RVT04B6Q', applying quirks: noncqtrim zeroaftertrim noncqonati
Jan 24 13:52:02 Workstation kernel: ata8.00: supports DRM functions and may not be fully accessible
Jan 24 13:52:02 Workstation kernel: ata7.00: supports DRM functions and may not be fully accessible
Jan 24 13:52:02 Workstation systemd-fstab-generator[343]: Mount point Partition is not a valid path, ignoring.
Jan 24 13:52:03 Workstation kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Jan 24 13:52:03 Workstation kernel: EDAC sbridge: Couldn't find mci handler
Jan 24 13:52:03 Workstation kernel: EDAC sbridge: Failed to register device with error -19.
The system does not even boot to login screen.
This May be unrelated.
  • Have you tried to replug your ram modules, and to
    Look into the BIOS wheter all ram Is recognized
    :footprints:
Now, the computer does not even boot to login screen.
During boot, the monitor goes to standby and the computer freezes.
Bios detects all RAM and kernel 6.6.65 boots fine.
Then there’s no problem, really, is there? Seeing as its LTS anyway…
I have tried kernel 6.12.4 and it does not work.
So I continue with kernel 6.6.65.
Without being able to offer you a solution, I can tell you that I have a laptop myself that has similar problems.
It runs without problems with kernel 6.6. With 6.12 it ends up in the emergency shell without a mounted file system. And consequently without a log.
I’ll wait and see. First make a backup. Then, when I have time, I’ll take a closer look.
:footprints:
I have installed kernel 6.12.11 and the computer does not boot to login screen.
I guess you’ve already tried removing “quiet” and “splash” from the GRUB cmdline? Test by doing it from the GRUB menu by pressing E to edit, then boot from that.
This way you should see where it gets stuck, via the startup messages on screen.
It could be a Plymouth issue? :man_shrugging:
This may not be related.
Consider updating your BIOS. I note your current BIOS version 2.1a was released in 2018; there are likely to be several updated non-beta BIOS versions available; perhaps one of them might be more suitable for the latest kernels.
You might try and uninstall and reinstall 6.12.Also since you have an nvidia card did linux612-headers and the nvidia driver update.As @soundofthunder posted might not hurt to update the bios.
