this sign appears on a display I installed Linux, and I just switched but this is not a manjaro OS issue it seems on every Linux distro I installed ubuntu manjaro 1 year back when I was using manjaro that time also flashing this logo but automatically gone but this time its keep flashing when I watch the video it automatically pauses/play
please please help me fast it keeps me irritating if is it a Gnome issue then I can switch to another flavor
The only thing that i can think of is if the microphone is muting and unmuting itself … so, in alsamixer, F6 to chose your audio and look for Auto Mute and disable it, and give to microphone a 20% volume value, or something.
nope not working but i found temprory solution when I plugged earphone on my laptops 3.5 mm jack it will start blinking and I remove earphone it stops
i will wait till tommarow if i dont got any solution then I’m switching back to windows because this thing keeps lag my keyboard it automatically play/pause video and it is irritating so much
So it is related to audio that activates/deactivates itself or mutes/unmutes itself, well, you can also check the way the switch happens in Audio Settings.
Yes, the shortest path between two points is always a straight line … and the fastest/easiest fix is always what works best for you.
I just installed manjaro KDE now the logo isn’t there but the automatic play/pause video issue is still there I’m happy that the do not disturb logo is gone for now btw whenever I use backspace continuously it is stuck because the play/pause key conflicting with backspace
