I see that manjaro comes with i3 tiling manager installed by default. I got a new pc recently with a 42’’ 4K monitor so it has become mandatory to rely on a proper tiling manager. So far I have been relying on manually resizing and position the windows , currently I use a setup of 6 window, 3 taking 25% of my screen space each , and another 3 taking around 8% of screen space. Of course I prefer to automate this completely.
The mod key suppose to be the super key , aka windows key, it does work as a key because it opens the “start” (?) menu but when I try any of the shortcuts like for instance mod+enter which suppose to open a new terminal window as documented at
https://i3wm.org/docs/userguide.html#_default_keybindings
nothing happens.
How I can make this work for me ? I dont need anything spectacular just typical arrangement and resizing features
My specs are
OS: Manjaro XFCE latest version upgraded
CPU: 12 core 3900X AMD
GPU: NVIDIA 2070 Super
SSD: Kingnston 1TB NVMe M2
RAM: 32GB 3200Mhz
Full system specs
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.14.3 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <filter> UEFI: American Megatrends v: A.10 date: 07/01/2020
Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
L2 cache: 6144 KiB
bogomips: 182458
Speed: 2199 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 2781
2: 2025 3: 2201 4: 2200 5: 2870 6: 2092 7: 2176 8: 2200 9: 2199 10: 2198 11: 2200
12: 2200 13: 2145 14: 2200 15: 2200 16: 2197 17: 2199 18: 2200 19: 2200 20: 2200
21: 2200 22: 2199 23: 2200 24: 2199
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 455.45.01 bus ID: 2b:00.0
Display: x11 server: X.Org 1.20.10 driver: nvidia resolution: 3840x2160~60Hz
OpenGL: renderer: GeForce RTX 2070 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 2b:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 2d:00.4
Device-3: Logitech C922 Pro Stream Webcam type: USB driver: snd-usb-audio,uvcvideo
bus ID: 5-4:3
Sound Server: ALSA v: k5.8.18-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus ID: 28:00.0
IF: enp40s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: N/A port: d000
bus ID: 2a:00.0
Device-3: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB driver: r8188eu
bus ID: 1-3:3
IF: wlp2s0f0u3 state: up mac: <filter>
Local Storage: total: 2.73 TiB used: 351.14 GiB (12.6%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M81000G size: 931.51 GiB
ID-2: /dev/sda type: USB vendor: Seagate model: ST2000DL001-9VT156 size: 1.82 TiB
ID-1: / size: 576.09 GiB used: 351.11 GiB (60.9%) fs: ext4 dev: /dev/nvme0n1p5
System Temperatures: cpu: 49.2 C mobo: N/A gpu: nvidia temp: 41 C
Processes: 415 Uptime: 2h 43m Memory: 31.35 GiB used: 5.09 GiB (16.3%)
Init: systemd Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1467 Shell: Bash
v: 5.0.18 inxi: 3.1.08
