I used to have the Gnome Shell Extension Sound Input & Output Device Chooser to switch between speakers and mics.
Unfortunately, that does not work anymore with Gnome 43.
Even worse, I cannot select different sound inputs and outputs at all anymore. Not in the system tray menu nor in the settings.
No matter which output device I select it always is coming through the monitor speakers (HDMI)
Before I was able to use my Galaxay Buds Pro for conference calls (with mono mode when using mic and output), now neither audio output nor mic are working.
I don’t change any settings actively, it most have changed with one of the recent updates.
Kernel: 5.15.86-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=62a17635-6c76-4335-b6ca-6f8b162b53d5 rw quiet splash apparmor=1
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: TUXEDO product: TUXEDO Pulse 15 Gen1 v: Standard
serial: <superuser required>
Mobo: NB02 model: PULSE1501 v: Standard serial: <superuser required>
UEFI: American Megatrends v: N.1.07.A03 date: 05/11/2021
ID-1: BAT0 charge: 91.6 Wh (100.0%) condition: 91.6/91.6 Wh (100.0%)
volts: 13.0 min: 11.6 model: standard type: Li-ion serial: <filter>
status: full
RAM: total: 30.78 GiB used: 4.19 GiB (13.6%)
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1402 high: 1857 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1336 2: 1397
3: 1397 4: 1252 5: 1384 6: 1393 7: 1857 8: 1252 9: 1397 10: 1397 11: 1397
12: 1397 13: 1397 14: 1397 15: 1397 16: 1397 bogomips: 92660
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Tongfang Hongkong driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 36.0 C
Device-2: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 04f2:b71a class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) HDR 4K serial: <filter>
built: 2022 res: 3840x2160 dpi: 139 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 806mm (31.7") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: eDP-1 model: BOE Display 0x0900 built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
Device-1: AMD Renoir Radeon High Definition Audio vendor: Tongfang Hongkong
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.86-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4.4:5 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.82 TiB used: 432.36 GiB (23.2%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 292.97 GiB size: 287.31 GiB (98.07%)
used: 78.49 GiB (27.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: linux uuid: 62a17635-6c76-4335-b6ca-6f8b162b53d5
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: EFI
uuid: 72C7-6823
ID-3: /home raw-size: 292.97 GiB size: 287.31 GiB (98.07%)
used: 51.71 GiB (18.0%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
label: home uuid: 0b600184-26ec-47aa-a3e9-3f8170d03c67
ID-4: /mnt/ARCHIVE raw-size: 348.66 GiB size: 348.58 GiB (99.98%)
used: 192 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p11 maj-min: 259:11
label: ARCHIVE uuid: 7334-EA42
ID-5: /mnt/data raw-size: 585.94 GiB size: 575.68 GiB (98.25%)
used: 251.8 GiB (43.7%) fs: ext4 dev: /dev/nvme0n1p10 maj-min: 259:10
label: data uuid: e1395614-181f-4c93-8e17-e872f4e6ba11
ID-6: /mnt/winData raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 50.36 GiB (51.6%) fs: ntfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: winData uuid: 1C60C607317DD167
ID-1: swap-1 type: partition size: 97.66 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 9f2f59e0-34a6-4374-8e9f-5d4bc26350d2
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 82C1-D534
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 145.87 GiB fs: ntfs label: win10
uuid: 1682D08882D06DAD
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: 526A7DAE6A7D8F89
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b71a
Hub-2: 1-4:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.3:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-4.4:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:3 info: Keychron K3 Pro type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 3434:0230 class-ID: 0300
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.4 C mobo: N/A gpu: amdgpu temp: 36.0 C
Processes: 406 Uptime: 10m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1952
pm: pacman pkgs: 1938 libs: 416 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 14 Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.24
