Not able to install VirtualBox on Manjaro
I am unable to install VirtualBox on Manjaro. When I attempt to add VirtualBox to the kernel with:
sudo vboxreload
I get the following error messages:
Unloading modules:
Loading modules: modprobe: FATAL: Module vboxnetadp not found in directory /lib/modules/6.12.4-1-MANJARO
modprobe: FATAL: Module vboxnetflt not found in directory /lib/modules/6.12.4-1-MANJARO
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/6.12.4-1-MANJARO
Can anyone help?
mod edit - please learn to enclose your code when pasting:
code pasted here
Or select code and click the </> icon under the :gear: icon menu
Did you install the VirtualBox host modules for your kernel?
You’re running Linux 6.12.4, so that would be linux612-virtualbox-host-modules
With what?
Did you reboot?
Is your system up to date?
Does it not work after a reboot?
What doesn’t work?
How do you know?
You have seen this?:
VirtualBox - ArchWiki
Also don’t forget to add your user to the vboxusers group.
Also, read this - but mostly come back with more information; like details 'n stuff.
Search
Also make sure that you’re properly synced and updated; perhaps REMOVE your virtualbox installation first, then run:
❯ sudo pacman-mirrors --continent && sudo pacman -Syu
After this, install virtualbox and see how that goes.
Take note that if you are using Kernel 6.12 or above:
Virtualbox Kernel 6.12 kernel command line parameter in GRUB:
“kvm.enable_virt_at_load=0″
“In [Linux] kernel 6.12, KVM initializes virtualization on module
loading by default. This prevents VirtualBox VMs from starting,”
said the devs. “In order to avoid this, either add
“kvm.enable_virt_at_load=0″ parameter
into kernel command line or unload the
corresponding kvm_XXX module.”
From my notes:
Your host user must be a member of the group vboxusers:
sudo gpasswd -a $USER vboxusers
Log off to make change registered
Very Important: sudo modprobe vboxdrv
Make certain that the appropriate kernel headers and virtualbox-host-modules are installed, example:
linux-6xx-headers
linux-6xx-virtualbox-host-modules
