When i connect my Sony Wireless Headphones WH-CH510 via Bluetooth, the sound is fixed most of the time, means that whether i lower the volume or higher it, it’s still the same as the last connection.
So for example, if i connect my headphones yesterday and the volume was 60, today its fixed at 60 and i cannot tune it up or down.
I have to disconnect and reconnect again for the volume tuning to work correctly.
So most of the time, i need to connect 2 times for the headphones to function correctly. Connect, disconnect and reconnect again.
Any idea how to debug this issue ?
System info
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=d37c6e4a-949c-4370-8055-0f9e011a3409 rw quiet
cryptdevice=UUID=99cf4234-a381-4eff-9a33-abb366e019d2:luks-99cf4234-a381-4eff-9a33-abb366e019d2
root=/dev/mapper/luks-99cf4234-a381-4eff-9a33-abb366e019d2 splash
resume=/dev/mapper/luks-97e9302e-784a-4db6-a839-80af7dbb8188
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_x11 with: krunner
dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK MAX WIFI (MS-7C91)
v: 1.0 serial: <filter> uuid: be5679e8-c7c8-c813-a8b1-047c16beaab1
UEFI: American Megatrends LLC. v: 2.60 date: 10/10/2023
Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3400 min/max: 2200/5083 boost: enabled
base/boost: 3400/5050 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3400 2: 3400 3: 3400 4: 3400
5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400 20: 3400
21: 3400 22: 3400 23: 3400 24: 3400 25: 3400 26: 3400 27: 3400 28: 3400
29: 3400 30: 3400 31: 3400 32: 3400 bogomips: 217726
affected
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: Micro-Star MSI
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none off: DP-2 empty: DP-1,DP-3,HDMI-A-1
bus-ID: 2b:00.0 chip-ID: 10de:2487 class-ID: 0300
Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x333mm (23.70x13.11")
s-diag: 688mm (27.09")
Monitor-1: DP-2 res: 2560x1440 hz: 165 dpi: 108
size: 600x330mm (23.62x12.99") diag: 685mm (26.96") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.120 device-ID: 10de:2487
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 2b:00.1 chip-ID: 10de:228b class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: n/a (root, process) with:
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 14c3:0608
class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:6 chip-ID: 0e8d:0608
Local Storage: total: 1.82 TiB used: 264.2 GiB (14.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: MSI model: M480 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM80.0 temp: 33.9 C
scheme: GPT
SMART: yes health: PASSED on: 143d 19h cycles: 346
read-units: 14,299,929 [7.32 TB] written-units: 30,108,604 [15.4 TB]
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 264.2 GiB (14.7%)
fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-99cf4234-a381-4eff-9a33-abb366e019d2
used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-97e9302e-784a-4db6-a839-80af7dbb8188
System Temperatures: cpu: 46.5 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 32 GiB available: 31.26 GiB used: 10.52 GiB (33.7%)
Processes: 656 Power: uptime: 7h 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1658 pm: pacman pkgs: 1607 libs: 409 tools: pamac pm: appimage
pkgs: 0 pm: flatpak pkgs: 51 Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: Sudo (sudo) v: 1.9.16 default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.36
