nik:
aplay -l
list sinks short 1 ✘
54 alsa_output.pci-0000_00_1f.3.analog-stereo PipeWire s32le 2ch 48000Hz SUSPENDED
122 alsa_output.pci-0000_01_00.1.hdmi-stereo PipeWire s32le 2ch 48000Hz SUSPENDED
pactl get-default-sink
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [BenQ GW2475H]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
pactl list cards ✔
Card #49
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "1"
api.alsa.card.longname = "HDA NVidia at 0x53080000 irq 17"
api.alsa.card.name = "HDA NVidia"
api.alsa.path = "hw:1"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio1"
api.dbus.ReserveDevice1.Priority = "-20"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:01:00.1"
device.description = "GA102 High Definition Audio Controller"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_01_00.1"
device.nick = "HDA NVidia"
device.plugged.usec = "3364725"
device.product.id = "0x1aef"
device.product.name = "GA102 High Definition Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.vendor.id = "0x10de"
device.vendor.name = "NVIDIA Corporation"
media.class = "Audio/Device"
factory.id = "15"
client.id = "47"
object.id = "49"
object.serial = "49"
object.path = "alsa:acp:NVidia"
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0x53080000 irq 17"
alsa.mixer_name = "Nvidia GPU 9a HDMI/DP"
alsa.components = "HDA:10de009a,73772000,00100100"
alsa.id = "NVidia"
device.string = "1"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
Active Profile: output:hdmi-stereo
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
device.product.name = "BenQ GW2475H
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
Part of profile(s): output:hdmi-stereo-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #50
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "2"
api.alsa.card.longname = "MUSIC-BOOST Usb Microphone at usb-0000:00:14.0-13, full speed"
api.alsa.card.name = "Usb Microphone"
api.alsa.path = "hw:2"
api.dbus.ReserveDevice1 = "Audio2"
device.api = "alsa"
device.bus = "usb"
device.bus-id = "usb-MUSIC-BOOST_Usb_Microphone-00"
device.bus_path = "pci-0000:00:14.0-usb-0:13:1.0"
device.description = "Usb Microphone"
device.form_factor = "microphone"
device.icon_name = "audio-input-microphone-analog-usb"
device.name = "alsa_card.usb-MUSIC-BOOST_Usb_Microphone-00"
device.nick = "Usb Microphone"
device.plugged.usec = "3423934"
device.product.id = "0x2008"
device.product.name = "Usb Microphone"
device.serial = "MUSIC-BOOST_Usb_Microphone"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13:1.0/sound/card2"
device.vendor.id = "0x1b3f"
device.vendor.name = "Generalplus Technology Inc."
factory.id = "15"
client.id = "47"
object.id = "50"
object.serial = "50"
object.path = "alsa:acp:Microphone"
alsa.card = "2"
alsa.card_name = "Usb Microphone"
alsa.long_card_name = "MUSIC-BOOST Usb Microphone at usb-0000:00:14.0-13, full speed"
alsa.driver_name = "snd_usb_audio"
alsa.mixer_name = "USB Mixer"
alsa.components = "USB1b3f:2008"
alsa.id = "Microphone"
device.string = "2"
Profiles:
pro-audio: Pro Audio (sinks: 0, sources: 1, priority: 1, available: yes)
input:mono-fallback: Mono Input (sinks: 0, sources: 1, priority: 1, available: yes)
Active Profile: input:mono-fallback
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
Properties:
port.type = "mic"
Part of profile(s): input:mono-fallback
Card #51
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "0"
api.alsa.card.longname = "HDA Intel PCH at 0x4804210000 irq 178"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "hw:0"
device.api = "alsa"
device.bus = "pci"
device.description = "Built-in Audio"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "3412448"
device.product.id = "0x7ad0"
device.product.name = "Alder Lake-S HD Audio Controller"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.vendor.id = "0x8086"
factory.id = "15"
client.id = "47"
object.id = "51"
object.serial = "51"
object.path = "alsa:acp:PCH"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x4804210000 irq 178"
alsa.mixer_name = "Realtek ALC1220"
alsa.components = "HDA:10ec1220,103c8917,00100003"
alsa.id = "PCH"
device.string = "0"
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
pro-audio: Pro Audio (sinks: 1, sources: 2, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "mic"
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "line"
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "line"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 6, available)
Properties:
port.type = "headphones"
port.availability-group = "Legacy 6"
card.profile.port = "5"
