After following other thread on this forum to fix the problems caused by latest update, i was able to login and access manjaro. I noticed nvidia drivers were not installed and hence I wanted to install it, which lead me to brick my system and now I can’t boot into the system or access Terminal by CTRL+ALT+F1/F2/F3/F4/F5/F6.
I can edit the grub menu and change the line of linux which ends with rw quiet to rw 3, which allows me to access console.
I can also boot into live usb stick and do manjaro-chroot -a
and then access the terminal.
I removed other drivers i guess by following other thread somewhere here and ended up removing windows boot option in the grub menu completely. Manjaro is still not booting up.
I had installed optimus manager before the update which allowed me to switch b/w intel and nvidia card.
Can anyone please guide me? I tried searching lot of posts on forums but still no luck, and I would just end up bricking my pc more as I’m a beginner to linux.
