NordVPN failing to build
Hi I’ve been trying to install nordvpn, and i keep running into this error. I am simply trying to install the client on my own machine.
I have tried to add my user to the docker group.
How can I fix this error?
I would love to understand the reason behind this error.
Preparing...
Cloning nordvpn build files...
Generating nordvpn information...
Checking nordvpn dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building nordvpn...
==> Making package: nordvpn 3.16.6-1 (2023-11-01T23:58:27 CET)
==> Retrieving sources...
  -> Found 3.16.6.tar.gz
    3.16.6.tar.gz ... Passed
==> Extracting sources...
  -> Extracting 3.16.6.tar.gz with bsdtar
==> Starting prepare()...
You are not a member of the docker group. Docker is required to build the package.
Failed to build nordvpn
Looks like its telling you exactly what the problem is.
Are you a member of the group?
groups
Though I will also mention that this package looks weird.
This kind of thing could be handled by the PKGBUILD itself.
Though is docker really required to build this?
Also worth noting - this is a very new submission.
I would personally use one of the more vetted packages with votes, etc … instead of this one by an unknown packager from a few days ago.
https://aur.archlinux.org/packages?K=nordvpn&O=0&SB=v&SO=d
I was also a bit confused about the docker part. It worked after a restart and starting the docker daemon.
nordvpn-bin was building fine, but said it was outdated and didn’t want to login. This one seemed like the best option in the package manager, but I guess it’s on me, since I thought this was a GUI client.
I ended up configuring the vpn through settings though.
Also give this fine tutorial a read:
docker ? please specify which custom script you are using.
When installing nordvpn the nordvpn-bin is the most common.
pamac build nordvpn-bin
When done
 sudo gpasswd -a $USER nordvpn
Then
 sudo systemctl enable nordvpnd
Finally
 reboot
Thank you to summarize the process. This was very helpful !
