I have Manjaro 20.10 xcfe installed on Khadas VIM3 box.
The issue I have that on 1900x1200 resolution via HDMI port I have vertically shifted up image and not possible to configure something on monitor with this signal.
Are there any ways to calibrate an image on Manjaro or to try manual hdmi configuration for this resolution?
Via DVI port an image located correctly, but no audio(as it’s not HDMI)
Fabby
21 October 2020 09:15
2
Welcome to Manjaro!
You’ve taken a picture of your monitor to show the artefacts.
Does this also show up in a screenshot?
If no: Sorry, this is a monitor issue, please update the monitor’s firmware or use another resolution
If yes: Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Screenshot looks normal.
So looks like it’s monitor issue.
Are there any ways to add manual resolution/frame rate? (not only that EDID have)
[vim3@vim3 ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.8.10-1-MANJARO-ARM aarch64 bits: 64 compiler: N/A
parameters: root=LABEL=ROOT_MNJRO rootflags=data=writeback rw
console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0
fsck.fix=yes fsck.repair=yes net.ifnames=0
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro ARM
Type: ARM Device System: Khadas VIM3 details: N/A
RAM: total: 3.54 GiB used: 1.15 GiB (32.3%)
RAM Report: missing: Required program dmidecode not available
Topology: 6-Core (2-Die) model: N/A variant-1: cortex-a53
variant-2: cortex-a73 bits: 64 type: MCP MCM arch: ARMv8 family: 8
model-id: N/A stepping: 4 microcode: N/A bogomips: 0
Speed: 250 MHz min/max: 100/1800:2208 MHz Core speeds (MHz): 1: 250 2: 250
3: 250 4: 250 5: 250 6: 250
Features: aes asimd cpuid crc32 evtstrm fp pmull sha1 sha2
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 status: Vulnerable
Device-1: meson-g12a-mali driver: panfrost v: kernel bus ID: N/A
chip ID: amlogic:ffe40000
Device-2: meson-g12a-dw-hdmi driver: meson_dw_hdmi v: N/A bus ID: N/A
chip ID: amlogic:ff600000
Display: x11 server: X.org 1.20.9 driver: modesetting alternate: fbdev
resolution: <xdpyinfo missing>
Device-1: meson-g12a-dw-hdmi driver: meson_dw_hdmi bus ID: N/A
Device-2: axg-sound-card driver: axg_sound_card bus ID: N/A
chip ID: amlogic:sound
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-1.1:3 chip ID: 046d:0825 serial: <filter>
Sound Server: ALSA v: k5.8.10-1-MANJARO-ARM
Device-1: meson-axg-dwmac driver: meson8b_dwmac v: N/A port: N/A bus ID: N/A
chip ID: amlogic:ff3f0000
IF: eth0 state: down mac: <filter>
Device-2: pwm-clock driver: pwm_clock v: N/A port: N/A bus ID: N/A
chip ID: pwm-clock:wifi32k
IF-ID-1: ip6tnl0 state: down mac: <filter>
IF-ID-2: wlan0 state: up mac: <filter>
Local Storage: total: 29.12 GiB used: 4.61 GiB (15.8%)
ID-1: /dev/mmcblk2 vendor: Samsung model: BJTD4R size: 29.12 GiB block size:
physical: 512 B logical: 512 B serial: <filter> rev: 0x8 scheme: MBR
ID-1: / raw size: 28.23 GiB size: 27.66 GiB (97.99%) used: 4.54 GiB (16.4%)
fs: ext4 dev: /dev/mmcblk2p2 label: ROOT_MNJRO
uuid: bc7ccd25-0fed-4f62-b604-03f86396ad48
ID-2: /boot raw size: 244.0 MiB size: 243.7 MiB (99.89%)
used: 68.0 MiB (27.9%) fs: vfat dev: /dev/mmcblk2p1 label: BOOT_MNJRO
uuid: 1876-FFD3
ID-1: swap-1 type: zram size: 5.32 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 1-1:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1a40:0801
Device-1: 1-1.1:3 info: Logitech Webcam C270 type: Video,Audio
Hub: 1-1.2:4 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 058f:6254
Device-1: 1-1.2.3:5 info: KYE Systems (Mouse Systems) type: Keyboard,Mouse
chip ID: 0458:0067
Device-2: 1-1.2.4:6 info: N/A type: Mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s chip ID: 0715:0206
Hub: 2-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Message: No sensors data was found. Is sensors configured?
Processes: 227 Uptime: 1m Init: systemd v: 246 Compilers: gcc: N/A Packages:
pacman: 650 lib: 193 Shell: Bash v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
Fabby
21 October 2020 10:42
4
Yes, please provide:
the output to xrandr
the technical specifications of your monitor (resolution and frame rates missing from the xrandr output) as that will allow us to define custom resolutions.
P.S. Your profile section still looks as empty as the Sahara desert…
This is output from HDMI connection, that have an issue
[vim3@vim3 X11]$ xrandr --verbose
Screen 0: minimum 320 x 200, current 1920 x 1200, maximum 3840 x 2160
HDMI-1 connected 1920x1200+0+0 (0x42) normal (normal left inverted right x axis y axis) 160mm x 90mm
Identifier: 0x40
Timestamp: 1551461
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff004c2df60300000000
0b120103801009782aee91a3544c9926
0f5054bfef80a94081808140714f0101
010101010101283c80a070b023403020
3600a05a0000001a011d00bc52d01e20
b8285540a05a0000001e000000fd0032
4b1b5111000a202020202020000000fc
0053796e634d61737465720a202001ea
02031ff24b9304128314052021221f10
230907078301000066030c001000808c
0ad08a20e02d10103e9600a05a000000
18011d007251d01e206e285500a05a00
00001e011d80d0721c1620102c2580a0
5a0000009e011d8018711c1620582c25
00a05a0000009e8c0ad090204031200c
405500a05a0000001800000000000031
max bpc: 0
range: (8, 16)
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 32
supported: 32
non-desktop: 0
range: (0, 1)
1920x1200 (0x42) 154.000MHz +HSync -VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 74.04KHz
v: height 1200 start 1203 end 1209 total 1235 clock 59.95Hz
1920x1080 (0x43) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x44) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x45) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080i (0x46) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.75KHz
v: height 1080 start 1084 end 1094 total 1125 clock 60.00Hz
1920x1080i (0x47) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1094 total 1125 clock 50.00Hz
1920x1080 (0x48) 74.250MHz +HSync +VSync
v: height 1080 start 1084 end 1089 total 1125 clock 30.00Hz
1920x1080 (0x49) 74.250MHz +HSync +VSync
v: height 1080 start 1084 end 1089 total 1125 clock 25.00Hz
1920x1080 (0x4a) 74.250MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 27.00KHz
v: height 1080 start 1084 end 1089 total 1125 clock 24.00Hz
1920x1080i (0x4b) 74.176MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.72KHz
v: height 1080 start 1084 end 1094 total 1125 clock 59.94Hz
1920x1080 (0x4c) 74.176MHz +HSync +VSync
v: height 1080 start 1084 end 1089 total 1125 clock 29.97Hz
1920x1080 (0x4d) 74.176MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
1600x1200 (0x4e) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1280x1024 (0x4f) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x50) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x51) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1152x864 (0x52) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x53) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x54) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x55) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x56) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x57) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x58) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
832x624 (0x59) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
800x600 (0x5a) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x5b) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x5c) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x5d) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
720x576 (0x5e) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x5f) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x60) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x61) 31.500MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.86KHz
v: height 480 start 489 end 492 total 520 clock 72.81Hz
640x480 (0x62) 30.240MHz -HSync -VSync
h: width 640 start 704 end 768 total 864 skew 0 clock 35.00KHz
v: height 480 start 483 end 486 total 525 clock 66.67Hz
[vim3@vim3 X11]$ cvt -v 1920 1200 60
# 1920x1200 59.88 Hz (CVT 2.30MA) hsync: 74.56 kHz; pclk: 193.25 MHz
Modeline "1920x1200_60.00" 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync
[vim3@vim3 X11]$ gtf 1920 1200 60
# 1920x1200 @ 60.00 Hz (GTF) hsync: 74.52 kHz; pclk: 193.16 MHz
Modeline "1920x1200_60.00" 193.16 1920 2048 2256 2592 1200 1201 1204 1242 -HSync +Vsync
This is an output from HDMI-DVI connection that works good:
HDMI-1 connected 1920x1200+0+0 (0x42) normal (normal left inverted right x axis y axis) 518mm x 324mm
Identifier: 0x40
Timestamp: 10620
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0
filter:
EDID:
00ffffffffffff004c2df40336324454
0a120103803722782aee91a3544c9926
360006442100001a000000fd00384b1e
5111000a202020202020000000fc0053
796e634d61737465720a2020000000ff
004831414b3530303030300a20200088
max bpc: 0
range: (8, 16)
link-status: Good
CONNECTOR_ID: 32
supported: 32
non-desktop: 0
range: (0, 1)
1600x1200 (0x43) 162.000MHz +HSync +VSync
1280x1024 (0x44) 135.000MHz +HSync +VSync
1280x1024 (0x45) 108.000MHz +HSync +VSync
1280x960 (0x46) 108.000MHz +HSync +VSync
1152x864 (0x47) 108.000MHz +HSync +VSync
1024x768 (0x48) 78.750MHz +HSync +VSync
1024x768 (0x49) 75.000MHz -HSync -VSync
1024x768 (0x4a) 65.000MHz -HSync -VSync
832x624 (0x4b) 57.284MHz -HSync -VSync
800x600 (0x4c) 50.000MHz +HSync +VSync
800x600 (0x4d) 49.500MHz +HSync +VSync
800x600 (0x4e) 40.000MHz +HSync +VSync
800x600 (0x4f) 36.000MHz +HSync +VSync
640x480 (0x50) 31.500MHz -HSync -VSync
640x480 (0x51) 31.500MHz -HSync -VSync
640x480 (0x52) 30.240MHz -HSync -VSync
[vim3@vim3 X11]$
Monitor is Samsung T260HD, and all resolutions and refresh rates looks correct
Fabby
21 October 2020 18:43
6
There’s nothing I can do from a Manjaro perspective that will be perfect as the monitor is detected fine on both ports.
What’s the output of:
cvt 1920 1200 74.25
I.E. We’re going to try running that resolution at the next lowest common denominator frequency and might be able to scale up from there (but not guaranteed)
P.S. You’re not using a passive converter as I’m unfamiliar wit the Khadas VIM3 HW, are you?
[vim3@vim3 X11]$ cvt 1920 1200 74.25
# 1920x1200 74.17 Hz (CVT) hsync: 93.08 kHz; pclk: 242.75 MHz
Modeline "1920x1200_74.25" 242.75 1920 2064 2264 2608 1200 1203 1209 1255 -hsync +vsync
I just tested on other monitor(that have bigger resolution UWHD) and tried 1920x1200 resolution on it without any issues. I think that something with firmware of my old monitor.
But if anything will be for test then I’m ready.
I don’t know nothing that you mean about converter.
I just use cable HDMI-HDMI or HDMI-DVI. HDMI part from Khadas VIM3 box, HDMI or DVI from monitor side.
I tried but no, monitor doesn’t support such refresh rate. Monitor is too old and no any firmware available.
In any case thank you for your time.
Fabby
22 October 2020 18:16
10
No worries, I’m going to repeat what I already said a few days ago and mark that as a solution:
Sorry, this is a monitor issue, please update the monitor’s firmware or use another resolution / monitor
system
Closed
6 November 2020 18:17
11
