Hi all!
I know this isn’t strictly a Manjaro-only question, but I have a bit of a conundrum here, so I’m taking a chance.
I’ve done this a while ago, but everything seemed to be working. Today, I saw that it isn’t really. Or at least, if it is, then I don’t know how or why.
I tried adding some environment variables to /etc/environment
, if this isn’t the right place, I’ll happily change it, but I put it there, so that the variables would be available to anyone using the computer. (It’s only me, but I did it this way to learn something new, to use in the future should it b e neccessary.) I used an if
to check if it’s root
or not, and assign the variables if it’s not.
This morning, after the update, I wanted to make sure there are no errors on boot. So, I did:
journalctl --boot --priority=3
as root
And it gave me some HDD errors, that was caused by a faulty cable but I don’t know how to clear S.M.A.R.T. errors, or even if they can be cleared. However, I also received:
$ journalctl --boot --priority=3
pam_env(systemd-user:session): non-alphanumeric key 'if [[ $UID -eq 1000 ]];' in /etc/environment', ignoring
So it looks too me, like my if
in /etc/enviroment
isn’t correct.
The if
statement:
## Some environment variables by Mirdarthos
then
# a Custom editor for visudo
SUDO_EDITOR="/usr/bin/micro"
fi
My questions are:
- Am I doing the check if not root correct?
- If not, how should I change it?
- If so, what is causing the error?
- Anything else I need to be aware of?
I know we always say to include an inxi
output here, so here is mine, althoough I have no idea what use it could possibly be:
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet apparmor=1
security=apparmor resume=UUID=1b3f894f-5481-4241-ace5-c129a0cdb412
udev.log_priority=3
Console: pty pts/2 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A serial: N/A
Mobo: Gigabyte model: Z370 HD3-CF v: x.x serial: N/A
UEFI: American Megatrends v: F5 date: 10/30/2017
RAM: total: 15.58 GiB used: 4.08 GiB (26.2%)
Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 size: No Module Installed
Device-2: ChannelA-DIMM1 size: No Module Installed
Device-3: ChannelB-DIMM0 size: 8 GiB speed: 2133 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: G.Skill part-no: F4-3000C16-8GSXKB
serial: N/A
Device-4: ChannelB-DIMM1 size: 8 GiB speed: 2133 MT/s type: DDR4
serial: N/A
Info: model: Intel Core i7-8700 socket: LGA1151 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4447 high: 4502 min/max: 800/4600 base/boost: 4300/8300
scaling: driver: intel_pstate governor: performance volts: 1.1 V
ext-clock: 100 MHz cores: 1: 4502 2: 4431 3: 4315 4: 4469 5: 4461 6: 4498
7: 4398 8: 4423 9: 4473 10: 4470 11: 4500 12: 4425 bogomips: 76831
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1401
class-ID: 0300
Display: server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: nvidia tty: 252x45
Message: Advanced graphics data unavailable in console for root.
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fba
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 8.41 TiB used: 2.81 TiB (33.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 31.9 C scheme: GPT
SMART: yes health: PASSED on: 141d 15h cycles: 1,674
read-units: 39,455,047 [20.2 TB] written-units: 26,392,307 [13.5 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST5000VX0011-1T317X
family: Surveillance size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: VN02 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 343d 21h cycles: 1055
read: 53.06 TiB written: 13.07 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM000-1F2168
family: Desktop HDD.15 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5900
serial: <filter> rev: CC54 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 254d 19h cycles: 1987
read: 55.85 TiB written: 37.06 TiB Old-Age: UDMA CRC errors: 13567
alert: Bad cable/connection? Pre-Fail: end-to-end: 99 threshold: 99
alert: FAILING_NOW attribute: Spin_Retry_Count value: 100 worst: 100
threshold: 97
ID-1: / raw-size: 224.58 GiB size: 220.06 GiB (97.99%)
used: 124.26 GiB (56.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:3 label: N/A uuid: D563-DAB7
ID-3: /mnt/5TB raw-size: 4.55 TiB size: 4.51 TiB (99.19%)
used: 2.69 TiB (59.7%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: 5TB uuid: 953836d8-e355-4c6d-ac1a-0914b8414f50
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1b3f894f-5481-4241-ace5-c129a0cdb412
ID-1: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ext4 label: 4TB
uuid: c47c5a52-db30-4aef-bcbc-af35b7b021fd
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-3:2 info: Corsair CORSAIR K68 RGB Mechanical Gaming Keyboard
type: Keyboard,HID driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1b1c:1b4f class-ID: 0300 serial: <filter>
Device-2: 1-7:3 info: ROCCAT Kone EMP type: Mouse,Keyboard
power: 500mA chip-ID: 1e7d:2e24 class-ID: 0300
Device-3: 1-10:4 info: Samsung M267x 287x Series type: Printer
driver: usblp interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 04e8:3461 class-ID: 0701 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 27.8 C mobo: 16.8 C
Processes: 356 Uptime: 35m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1955 apt: 0 pacman: 1909
lib: 481 flatpak: 46 Shell: Zsh (sudo) v: 5.8 running-in: pty pts/2
inxi: 3.3.11
