I installed NoMachine from the AUR. Never got it to work, forgot about it.
Either way, one day my Wayland wouldn’t work, some cogs would spin on my screen and the text Manjaro. 20 secs later, black screen and nothing but a cursor. Couldn’t do anything. Other than switch to TTY. Fired up journalctl -f to see what was going on. Got something about plasma.kcminit.phase1.service and dependency failed. Is it KDE then? I rebooted, logged into X11 instead, worked like usual. But none of my games would start. That’s weird. vulkaninfo --summary just threw errors, like 5-6 lines of them. Something with Mesa?
Turns out it was NoMachine. It seems to not clear out the files it installs and places on the system, when uninstalling it. Creating problems. More info: [SOLVED]KDE under Wayland has issues starting. libEGL and Mesa invo... / Applications & Desktop Environments / Arch Linux Forums
Now, as long as you don’t uninstall NoMachine, you wont have problems but as soon as you do…
As the last post says: “Remove /etc/udev/rules.d/99-virtualgl-dri.rules solve the problem.”
It did solve the problem.
Initially I thought latest update might have caused something. I like to play with my system so clashes and incompatibilities are not rare. Took me 2 weeks trying to find the cause, used a backup clone 2-3 times etc.
Part of journalctl that finally lead me to the answer, especially the last part about Mesa (which I did not see when following journalctl):
xdg-desktop-por[10879]: Failed to create settings proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: Timeout was reached
jun 17 21:46:07 xdg-desktop-por[10879]: Failed to create file chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: Timeout was reached
jun 17 21:46:32 xdg-desktop-por[10879]: Failed to create app chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: Timeout was reached
jun 17 21:46:48 kded6[21283]: MESA: error: ZINK: vkEnumeratePhysicalDevices failed (VK_ERROR_INITIALIZATION_FAILED)
I hope the next person finds the solution faster than I did.
