Node Error, libcrypto.so.1.1 No File
So I tried installing node and npm using
sudo pacman -S nodejs npm
and it seemed to go through
but whenever I run node in the command line(or npm) to see if it works i get this:
node: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
I even tried using the GUI(Add/Remove Software) and pressed “reinstall” on there, still getting the above error.
Do I need to install anything else?
Welcome to the forum! :wave:
Make sure you’re fully up to date first.
wow,
that did the trick thank you so much
I guess I needed to fully update everything after I installed Manjaro from scratch
When you install a distro, you install a collection of pre-compiled packages in the ISO. These ISOs are only built so often, thus anything updated since the ISO was built will be out of date on a newly installed system. One of the first things you should do after installing any distro is check for updates.
