-- Journal begins at Thu 2020-09-24 22:00:05 CEST, ends at Mon 2021-09-27 13:28:30 CEST. --
Sep 27 08:53:46 hp850 kernel: microcode: microcode updated early to revision 0x26, date = 2019-11-12
Sep 27 08:53:46 hp850 kernel: Linux version 5.10.68-1-MANJARO (builduser@fv-az72-509) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Sep 22 12:29:47 UTC 2021
Sep 27 08:53:46 hp850 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=bbec8e84-8299-4688-bc58-f35cce905310 rw quiet udev.log_priority=3 resume=/dev/sdb2
Sep 27 08:53:46 hp850 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Sep 27 08:53:46 hp850 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Sep 27 08:53:46 hp850 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Sep 27 08:53:46 hp850 kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Sep 27 08:53:46 hp850 kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
Sep 27 08:53:46 hp850 kernel: BIOS-provided physical RAM map:
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009dbff] usable
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x000000000009dc00-0x000000000009ffff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x0000000000100000-0x000000008cb7efff] usable
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x000000008cb7f000-0x000000008de7efff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x000000008de7f000-0x000000008df7efff] ACPI NVS
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x000000008df7f000-0x000000008dffefff] ACPI data
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x000000008dfff000-0x000000008dffffff] usable
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x000000008e000000-0x00000000af1fffff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x00000000fed10000-0x00000000fed13fff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x00000000fed18000-0x00000000fed19fff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved
Sep 27 08:53:46 hp850 kernel: BIOS-e820: [mem 0x0000000100000000-0x000000024edfffff] usable
Sep 27 08:53:46 hp850 kernel: NX (Execute Disable) protection: active
Sep 27 08:53:46 hp850 kernel: SMBIOS 2.7 present.
Sep 27 08:53:46 hp850 kernel: DMI: Hewlett-Packard HP EliteBook 850 G1/198F, BIOS L71 Ver. 01.46 07/20/2018
Sep 27 08:53:46 hp850 kernel: tsc: Fast TSC calibration using PIT
Sep 27 08:53:46 hp850 kernel: tsc: Detected 2693.795 MHz processor
Sep 27 08:53:46 hp850 kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Sep 27 08:53:46 hp850 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Sep 27 08:53:46 hp850 kernel: last_pfn = 0x24ee00 max_arch_pfn = 0x400000000
Sep 27 08:53:46 hp850 kernel: MTRR default type: uncachable
Sep 27 08:53:46 hp850 kernel: MTRR fixed ranges enabled:
Sep 27 08:53:46 hp850 kernel: 00000-9FFFF write-back
Sep 27 08:53:46 hp850 kernel: A0000-BFFFF uncachable
Sep 27 08:53:46 hp850 kernel: C0000-FFFFF write-protect
Sep 27 08:53:46 hp850 kernel: MTRR variable ranges enabled:
Sep 27 08:53:46 hp850 kernel: 0 base 00FF800000 mask 7FFF800000 write-protect
Sep 27 08:53:46 hp850 kernel: 1 base 0000000000 mask 7F80000000 write-back
Sep 27 08:53:46 hp850 kernel: 2 base 0080000000 mask 7FE0000000 write-back
Sep 27 08:53:46 hp850 kernel: 3 base 0090000000 mask 7FF0000000 uncachable
Sep 27 08:53:46 hp850 kernel: 4 base 008F000000 mask 7FFF000000 uncachable
Sep 27 08:53:46 hp850 kernel: 5 base 0100000000 mask 7F00000000 write-back
Sep 27 08:53:46 hp850 kernel: 6 base 0200000000 mask 7FC0000000 write-back
Sep 27 08:53:46 hp850 kernel: 7 base 0240000000 mask 7FE0000000 write-back
Sep 27 08:53:46 hp850 kernel: 8 base 0250000000 mask 7FF0000000 uncachable
Sep 27 08:53:46 hp850 kernel: 9 base 024F000000 mask 7FFF000000 uncachable
Sep 27 08:53:46 hp850 kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Sep 27 08:53:46 hp850 kernel: last_pfn = 0x8e000 max_arch_pfn = 0x400000000
Sep 27 08:53:46 hp850 kernel: check: Scanning 1 areas for low memory corruption
Sep 27 08:53:46 hp850 kernel: Using GB pages for direct mapping
Sep 27 08:53:46 hp850 kernel: RAMDISK: [mem 0x367e1000-0x373e7fff]
Sep 27 08:53:46 hp850 kernel: ACPI: Early table checksum verification disabled
Sep 27 08:53:46 hp850 kernel: ACPI: RSDP 0x00000000000F2FE0 000024 (v02 HPQOEM)
Sep 27 08:53:46 hp850 kernel: ACPI: XSDT 0x000000008DFFE120 0000A4 (v01 HPQOEM SLIC-MPC 00000001 01000013)
Sep 27 08:53:46 hp850 kernel: ACPI: FACP 0x000000008DFFC000 00010C (v05 HPQOEM 198F 00000001 HP 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: DSDT 0x000000008DFD1000 02555B (v02 HPQOEM 198F 00000001 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: FACS 0x000000008DDE3000 000040
Sep 27 08:53:46 hp850 kernel: ACPI: HPET 0x000000008DFFB000 000038 (v01 HPQOEM 198F 00000001 HP 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: APIC 0x000000008DFFA000 0000BC (v01 HPQOEM 198F 00000001 HP 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: MCFG 0x000000008DFF9000 00003C (v01 HPQOEM 198F 00000001 HP 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0x000000008DFCE000 000313 (v01 HPQOEM SataAhci 00001000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0x000000008DFCD000 00048A (v01 HPQOEM PtidDevc 00001000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: SLIC 0x000000008DFCC000 000176 (v01 HPQOEM SLIC-MPC 00000001 HP 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: FPDT 0x000000008DFCA000 000044 (v01 HPQOEM 198F 00000001 HP 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: BGRT 0x000000008DFC9000 000038 (v00 HPQOEM 198F 00000001 HP 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0x000000008DFC5000 000544 (v01 PmRef Cpu0Ist 00003000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0x000000008DFC4000 000AF3 (v01 PmRef CpuPm 00003000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0x000000008DFC3000 0001D5 (v01 PmRef LakeTiny 00003000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0x000000008DFC2000 000706 (v01 SaSsdt SaSsdt 00003000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0x000000008DFC0000 001455 (v01 HP AMDSGTBL 00001000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: ASF! 0x000000008DFF8000 0000A5 (v32 HPQOEM 198F 00000001 HP 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: DMAR 0x000000008DFBF000 0000B0 (v01 INTEL HSW 00000001 INTL 00000001)
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving FACP table memory at [mem 0x8dffc000-0x8dffc10b]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving DSDT table memory at [mem 0x8dfd1000-0x8dff655a]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving FACS table memory at [mem 0x8dde3000-0x8dde303f]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving HPET table memory at [mem 0x8dffb000-0x8dffb037]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving APIC table memory at [mem 0x8dffa000-0x8dffa0bb]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving MCFG table memory at [mem 0x8dff9000-0x8dff903b]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving SSDT table memory at [mem 0x8dfce000-0x8dfce312]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving SSDT table memory at [mem 0x8dfcd000-0x8dfcd489]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving SLIC table memory at [mem 0x8dfcc000-0x8dfcc175]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving FPDT table memory at [mem 0x8dfca000-0x8dfca043]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving BGRT table memory at [mem 0x8dfc9000-0x8dfc9037]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving SSDT table memory at [mem 0x8dfc5000-0x8dfc5543]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving SSDT table memory at [mem 0x8dfc4000-0x8dfc4af2]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving SSDT table memory at [mem 0x8dfc3000-0x8dfc31d4]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving SSDT table memory at [mem 0x8dfc2000-0x8dfc2705]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving SSDT table memory at [mem 0x8dfc0000-0x8dfc1454]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving ASF! table memory at [mem 0x8dff8000-0x8dff80a4]
Sep 27 08:53:46 hp850 kernel: ACPI: Reserving DMAR table memory at [mem 0x8dfbf000-0x8dfbf0af]
Sep 27 08:53:46 hp850 kernel: ACPI: Local APIC address 0xfee00000
Sep 27 08:53:46 hp850 kernel: No NUMA configuration found
Sep 27 08:53:46 hp850 kernel: Faking a node at [mem 0x0000000000000000-0x000000024edfffff]
Sep 27 08:53:46 hp850 kernel: NODE_DATA(0) allocated [mem 0x24edfc000-0x24edfffff]
Sep 27 08:53:46 hp850 kernel: Zone ranges:
Sep 27 08:53:46 hp850 kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
Sep 27 08:53:46 hp850 kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
Sep 27 08:53:46 hp850 kernel: Normal [mem 0x0000000100000000-0x000000024edfffff]
Sep 27 08:53:46 hp850 kernel: Device empty
Sep 27 08:53:46 hp850 kernel: Movable zone start for each node
Sep 27 08:53:46 hp850 kernel: Early memory node ranges
Sep 27 08:53:46 hp850 kernel: node 0: [mem 0x0000000000001000-0x000000000009cfff]
Sep 27 08:53:46 hp850 kernel: node 0: [mem 0x0000000000100000-0x000000008cb7efff]
Sep 27 08:53:46 hp850 kernel: node 0: [mem 0x000000008dfff000-0x000000008dffffff]
Sep 27 08:53:46 hp850 kernel: node 0: [mem 0x0000000100000000-0x000000024edfffff]
Sep 27 08:53:46 hp850 kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000024edfffff]
Sep 27 08:53:46 hp850 kernel: On node 0 totalpages: 1947932
Sep 27 08:53:46 hp850 kernel: DMA zone: 64 pages used for memmap
Sep 27 08:53:46 hp850 kernel: DMA zone: 21 pages reserved
Sep 27 08:53:46 hp850 kernel: DMA zone: 3996 pages, LIFO batch:0
Sep 27 08:53:46 hp850 kernel: DMA32 zone: 8942 pages used for memmap
Sep 27 08:53:46 hp850 kernel: DMA32 zone: 572288 pages, LIFO batch:63
Sep 27 08:53:46 hp850 kernel: Normal zone: 21432 pages used for memmap
Sep 27 08:53:46 hp850 kernel: Normal zone: 1371648 pages, LIFO batch:63
Sep 27 08:53:46 hp850 kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Sep 27 08:53:46 hp850 kernel: On node 0, zone DMA: 99 pages in unavailable ranges
Sep 27 08:53:46 hp850 kernel: On node 0, zone DMA32: 5248 pages in unavailable ranges
Sep 27 08:53:46 hp850 kernel: On node 0, zone Normal: 8192 pages in unavailable ranges
Sep 27 08:53:46 hp850 kernel: On node 0, zone Normal: 4608 pages in unavailable ranges
Sep 27 08:53:46 hp850 kernel: Reserving Intel graphics memory at [mem 0x8f200000-0xaf1fffff]
Sep 27 08:53:46 hp850 kernel: ACPI: PM-Timer IO Port: 0x1808
Sep 27 08:53:46 hp850 kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Sep 27 08:53:46 hp850 kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Sep 27 08:53:46 hp850 kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Sep 27 08:53:46 hp850 kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Sep 27 08:53:46 hp850 kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Sep 27 08:53:46 hp850 kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Sep 27 08:53:46 hp850 kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Sep 27 08:53:46 hp850 kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Sep 27 08:53:46 hp850 kernel: IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-39
Sep 27 08:53:46 hp850 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Sep 27 08:53:46 hp850 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Sep 27 08:53:46 hp850 kernel: ACPI: IRQ0 used by override.
Sep 27 08:53:46 hp850 kernel: ACPI: IRQ9 used by override.
Sep 27 08:53:46 hp850 kernel: Using ACPI (MADT) for SMP configuration information
Sep 27 08:53:46 hp850 kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Sep 27 08:53:46 hp850 kernel: TSC deadline timer available
Sep 27 08:53:46 hp850 kernel: smpboot: Allowing 8 CPUs, 4 hotplug CPUs
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x8cb7f000-0x8de7efff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x8de7f000-0x8df7efff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x8df7f000-0x8dffefff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0x8e000000-0xaf1fffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xaf200000-0xdfffffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfebfffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed13fff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed14000-0xfed17fff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed18000-0xfed19fff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff7fffff]
Sep 27 08:53:46 hp850 kernel: PM: hibernation: Registered nosave memory: [mem 0xff800000-0xffffffff]
Sep 27 08:53:46 hp850 kernel: [mem 0xaf200000-0xdfffffff] available for PCI devices
Sep 27 08:53:46 hp850 kernel: Booting paravirtualized kernel on bare hardware
Sep 27 08:53:46 hp850 kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Sep 27 08:53:46 hp850 kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
Sep 27 08:53:46 hp850 kernel: percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
Sep 27 08:53:46 hp850 kernel: pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
Sep 27 08:53:46 hp850 kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Sep 27 08:53:46 hp850 kernel: Built 1 zonelists, mobility grouping on. Total pages: 1917473
Sep 27 08:53:46 hp850 kernel: Policy zone: Normal
Sep 27 08:53:46 hp850 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=bbec8e84-8299-4688-bc58-f35cce905310 rw quiet udev.log_priority=3 resume=/dev/sdb2
Sep 27 08:53:46 hp850 kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Sep 27 08:53:46 hp850 kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Sep 27 08:53:46 hp850 kernel: mem auto-init: stack:off, heap alloc:on, heap free:off
Sep 27 08:53:46 hp850 kernel: Memory: 7537156K/7791728K available (14344K kernel code, 2061K rwdata, 9160K rodata, 1712K init, 4236K bss, 254312K reserved, 0K cma-reserved)
Sep 27 08:53:46 hp850 kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
Sep 27 08:53:46 hp850 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Sep 27 08:53:46 hp850 kernel: Kernel/User page tables isolation: enabled
Sep 27 08:53:46 hp850 kernel: ftrace: allocating 41919 entries in 164 pages
Sep 27 08:53:46 hp850 kernel: ftrace: allocated 164 pages with 3 groups
Sep 27 08:53:46 hp850 kernel: rcu: Preemptible hierarchical RCU implementation.
Sep 27 08:53:46 hp850 kernel: rcu: RCU dyntick-idle grace-period acceleration is enabled.
Sep 27 08:53:46 hp850 kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
Sep 27 08:53:46 hp850 kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
Sep 27 08:53:46 hp850 kernel: Trampoline variant of Tasks RCU enabled.
Sep 27 08:53:46 hp850 kernel: Rude variant of Tasks RCU enabled.
Sep 27 08:53:46 hp850 kernel: Tracing variant of Tasks RCU enabled.
Sep 27 08:53:46 hp850 kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Sep 27 08:53:46 hp850 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
Sep 27 08:53:46 hp850 kernel: NR_IRQS: 20736, nr_irqs: 760, preallocated irqs: 16
Sep 27 08:53:46 hp850 kernel: Console: colour dummy device 80x25
Sep 27 08:53:46 hp850 kernel: printk: console [tty0] enabled
Sep 27 08:53:46 hp850 kernel: ACPI: Core revision 20200925
Sep 27 08:53:46 hp850 kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
Sep 27 08:53:46 hp850 kernel: APIC: Switch to symmetric I/O mode setup
Sep 27 08:53:46 hp850 kernel: DMAR: Host address width 39
Sep 27 08:53:46 hp850 kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Sep 27 08:53:46 hp850 kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020660462 ecap f0101a
Sep 27 08:53:46 hp850 kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Sep 27 08:53:46 hp850 kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008020660462 ecap f010da
Sep 27 08:53:46 hp850 kernel: DMAR: RMRR base: 0x0000008dd18000 end: 0x0000008dd37fff
Sep 27 08:53:46 hp850 kernel: DMAR: RMRR base: 0x0000008f000000 end: 0x000000af1fffff
Sep 27 08:53:46 hp850 kernel: DMAR-IR: IOAPIC id 0 under DRHD base 0xfed91000 IOMMU 1
Sep 27 08:53:46 hp850 kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Sep 27 08:53:46 hp850 kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
Sep 27 08:53:46 hp850 kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Sep 27 08:53:46 hp850 kernel: x2apic enabled
Sep 27 08:53:46 hp850 kernel: Switched APIC routing to cluster x2apic.
Sep 27 08:53:46 hp850 kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Sep 27 08:53:46 hp850 kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26d458cc458, max_idle_ns: 440795298126 ns
Sep 27 08:53:46 hp850 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5389.07 BogoMIPS (lpj=8979316)
Sep 27 08:53:46 hp850 kernel: pid_max: default: 32768 minimum: 301
Sep 27 08:53:46 hp850 kernel: LSM: Security Framework initializing
Sep 27 08:53:46 hp850 kernel: Yama: becoming mindful.
Sep 27 08:53:46 hp850 kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
Sep 27 08:53:46 hp850 kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
Sep 27 08:53:46 hp850 kernel: mce: CPU0: Thermal monitoring enabled (TM1)
Sep 27 08:53:46 hp850 kernel: process: using mwait in idle threads
Sep 27 08:53:46 hp850 kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
Sep 27 08:53:46 hp850 kernel: Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
Sep 27 08:53:46 hp850 kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Sep 27 08:53:46 hp850 kernel: Spectre V2 : Mitigation: Full generic retpoline
Sep 27 08:53:46 hp850 kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Sep 27 08:53:46 hp850 kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
Sep 27 08:53:46 hp850 kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Sep 27 08:53:46 hp850 kernel: Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
Sep 27 08:53:46 hp850 kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Sep 27 08:53:46 hp850 kernel: SRBDS: Mitigation: Microcode
Sep 27 08:53:46 hp850 kernel: MDS: Mitigation: Clear CPU buffers
Sep 27 08:53:46 hp850 kernel: Freeing SMP alternatives memory: 36K
Sep 27 08:53:46 hp850 kernel: smpboot: CPU0: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz (family: 0x6, model: 0x45, stepping: 0x1)
Sep 27 08:53:46 hp850 kernel: Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
Sep 27 08:53:46 hp850 kernel: ... version: 3
Sep 27 08:53:46 hp850 kernel: ... bit width: 48
Sep 27 08:53:46 hp850 kernel: ... generic registers: 4
Sep 27 08:53:46 hp850 kernel: ... value mask: 0000ffffffffffff
Sep 27 08:53:46 hp850 kernel: ... max period: 00007fffffffffff
Sep 27 08:53:46 hp850 kernel: ... fixed-purpose events: 3
Sep 27 08:53:46 hp850 kernel: ... event mask: 000000070000000f
Sep 27 08:53:46 hp850 kernel: rcu: Hierarchical SRCU implementation.
Sep 27 08:53:46 hp850 kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Sep 27 08:53:46 hp850 kernel: smp: Bringing up secondary CPUs ...
Sep 27 08:53:46 hp850 kernel: x86: Booting SMP configuration:
Sep 27 08:53:46 hp850 kernel: .... node #0, CPUs: #1
Sep 27 08:53:46 hp850 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Sep 27 08:53:46 hp850 kernel: #2 #3
Sep 27 08:53:46 hp850 kernel: smp: Brought up 1 node, 4 CPUs
Sep 27 08:53:46 hp850 kernel: smpboot: Max logical packages: 2
Sep 27 08:53:46 hp850 kernel: smpboot: Total of 4 processors activated (21558.29 BogoMIPS)
Sep 27 08:53:46 hp850 kernel: devtmpfs: initialized
Sep 27 08:53:46 hp850 kernel: x86/mm: Memory block size: 128MB
Sep 27 08:53:46 hp850 kernel: PM: Registering ACPI NVS region [mem 0x8de7f000-0x8df7efff] (1048576 bytes)
Sep 27 08:53:46 hp850 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Sep 27 08:53:46 hp850 kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Sep 27 08:53:46 hp850 kernel: pinctrl core: initialized pinctrl subsystem
Sep 27 08:53:46 hp850 kernel: PM: RTC time: 06:53:42, date: 2021-09-27
Sep 27 08:53:46 hp850 kernel: NET: Registered protocol family 16
Sep 27 08:53:46 hp850 kernel: DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
Sep 27 08:53:46 hp850 kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Sep 27 08:53:46 hp850 kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Sep 27 08:53:46 hp850 kernel: audit: initializing netlink subsys (disabled)
Sep 27 08:53:46 hp850 kernel: audit: type=2000 audit(1632725622.026:1): state=initialized audit_enabled=0 res=1
Sep 27 08:53:46 hp850 kernel: thermal_sys: Registered thermal governor 'fair_share'
Sep 27 08:53:46 hp850 kernel: thermal_sys: Registered thermal governor 'bang_bang'
Sep 27 08:53:46 hp850 kernel: thermal_sys: Registered thermal governor 'step_wise'
Sep 27 08:53:46 hp850 kernel: thermal_sys: Registered thermal governor 'user_space'
Sep 27 08:53:46 hp850 kernel: thermal_sys: Registered thermal governor 'power_allocator'
Sep 27 08:53:46 hp850 kernel: cpuidle: using governor ladder
Sep 27 08:53:46 hp850 kernel: cpuidle: using governor menu
Sep 27 08:53:46 hp850 kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Sep 27 08:53:46 hp850 kernel: ACPI: bus type PCI registered
Sep 27 08:53:46 hp850 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Sep 27 08:53:46 hp850 kernel: PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
Sep 27 08:53:46 hp850 kernel: PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
Sep 27 08:53:46 hp850 kernel: PCI: Using configuration type 1 for base access
Sep 27 08:53:46 hp850 kernel: core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
Sep 27 08:53:46 hp850 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Sep 27 08:53:46 hp850 kernel: Kprobes globally optimized
Sep 27 08:53:46 hp850 kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Sep 27 08:53:46 hp850 kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Sep 27 08:53:46 hp850 kernel: ACPI: Added _OSI(Module Device)
Sep 27 08:53:46 hp850 kernel: ACPI: Added _OSI(Processor Device)
Sep 27 08:53:46 hp850 kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Sep 27 08:53:46 hp850 kernel: ACPI: Added _OSI(Processor Aggregator Device)
Sep 27 08:53:46 hp850 kernel: ACPI: Added _OSI(Linux-Dell-Video)
Sep 27 08:53:46 hp850 kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Sep 27 08:53:46 hp850 kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
Sep 27 08:53:46 hp850 kernel: ACPI: 8 ACPI AML tables successfully acquired and loaded
Sep 27 08:53:46 hp850 kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Sep 27 08:53:46 hp850 kernel: ACPI: Dynamic OEM Table Load:
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0xFFFF925AC0DE0000 0003F3 (v01 PmRef Cpu0Cst 00003001 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0xFFFF925AC1082000 0005DB (v01 PmRef ApIst 00003000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: SSDT 0xFFFF925AC0F47E00 000119 (v01 PmRef ApCst 00003000 INTL 20110112)
Sep 27 08:53:46 hp850 kernel: ACPI: EC: EC started
Sep 27 08:53:46 hp850 kernel: ACPI: EC: interrupt blocked
Sep 27 08:53:46 hp850 kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Sep 27 08:53:46 hp850 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
Sep 27 08:53:46 hp850 kernel: ACPI: Interpreter enabled
Sep 27 08:53:46 hp850 kernel: ACPI: (supports S0 S3 S4 S5)
Sep 27 08:53:46 hp850 kernel: ACPI: Using IOAPIC for interrupt routing
Sep 27 08:53:46 hp850 kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Sep 27 08:53:46 hp850 kernel: ACPI: Enabled 8 GPEs in block 00 to 7F
Sep 27 08:53:46 hp850 kernel: ACPI: Power Resource [APPR] (off)
Sep 27 08:53:46 hp850 kernel: ACPI: Power Resource [COMP] (on)
Sep 27 08:53:46 hp850 kernel: ACPI: Power Resource [LPP] (on)
Sep 27 08:53:46 hp850 kernel: ACPI: Power Resource [PXP6] (on)
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
Sep 27 08:53:46 hp850 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Sep 27 08:53:46 hp850 kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
Sep 27 08:53:46 hp850 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
Sep 27 08:53:46 hp850 kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
Sep 27 08:53:46 hp850 kernel: PCI host bridge to bus 0000:00
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: root bus resource [mem 0xaf200000-0xdfffffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfed3ffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: root bus resource [mem 0xfed45000-0xfedfffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: root bus resource [mem 0xfee01000-0xffffffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: root bus resource [bus 00-fe]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:00.0: [8086:0a04] type 00 class 0x060000
Sep 27 08:53:46 hp850 kernel: pci 0000:00:02.0: [8086:0a16] type 00 class 0x030000
Sep 27 08:53:46 hp850 kernel: pci 0000:00:02.0: reg 0x10: [mem 0xd0000000-0xd03fffff 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:02.0: reg 0x20: [io 0x4000-0x403f]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:03.0: [8086:0a0c] type 00 class 0x040300
Sep 27 08:53:46 hp850 kernel: pci 0000:00:03.0: reg 0x10: [mem 0xd0830000-0xd0833fff 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:14.0: [8086:9c31] type 00 class 0x0c0330
Sep 27 08:53:46 hp850 kernel: pci 0000:00:14.0: reg 0x10: [mem 0xd0820000-0xd082ffff 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:16.0: [8086:9c3a] type 00 class 0x078000
Sep 27 08:53:46 hp850 kernel: pci 0000:00:16.0: reg 0x10: [mem 0xd0839000-0xd083901f 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:16.3: [8086:9c3d] type 00 class 0x070002
Sep 27 08:53:46 hp850 kernel: pci 0000:00:16.3: reg 0x10: [io 0x40b0-0x40b7]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:16.3: reg 0x14: [mem 0xd083f000-0xd083ffff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:19.0: [8086:155a] type 00 class 0x020000
Sep 27 08:53:46 hp850 kernel: pci 0000:00:19.0: reg 0x10: [mem 0xd0800000-0xd081ffff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:19.0: reg 0x14: [mem 0xd083e000-0xd083efff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:19.0: reg 0x18: [io 0x4080-0x409f]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1b.0: [8086:9c20] type 00 class 0x040300
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xd0834000-0xd0837fff 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.0: [8086:9c10] type 01 class 0x060400
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.3: [8086:9c16] type 01 class 0x060400
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.4: [8086:9c18] type 01 class 0x060400
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: [8086:9c1a] type 01 class 0x060400
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1d.0: [8086:9c26] type 00 class 0x0c0320
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xd083d000-0xd083d3ff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.0: [8086:9c43] type 00 class 0x060100
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.2: [8086:9c03] type 00 class 0x010601
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.2: reg 0x10: [io 0x40a8-0x40af]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.2: reg 0x14: [io 0x40bc-0x40bf]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.2: reg 0x18: [io 0x40a0-0x40a7]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.2: reg 0x1c: [io 0x40b8-0x40bb]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.2: reg 0x20: [io 0x4060-0x407f]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xd083c000-0xd083c7ff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.2: PME# supported from D3hot
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.3: [8086:9c22] type 00 class 0x0c0500
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xd0838000-0xd08380ff 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1f.3: reg 0x20: [io 0xef80-0xef9f]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.0: bridge window [mem 0xd0700000-0xd07fffff]
Sep 27 08:53:46 hp850 kernel: pci 0000:02:00.0: [8086:08b1] type 00 class 0x028000
Sep 27 08:53:46 hp850 kernel: pci 0000:02:00.0: reg 0x10: [mem 0xd0600000-0xd0601fff 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.3: PCI bridge to [bus 02]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.3: bridge window [mem 0xd0600000-0xd06fffff]
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: [1002:6601] type 00 class 0x030000
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: reg 0x10: [mem 0xb0000000-0xbfffffff 64bit pref]
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: reg 0x18: [mem 0xd0500000-0xd053ffff 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: reg 0x20: [io 0x3000-0x30ff]
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: enabling Extended Tags
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: supports D1 D2
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: PME# supported from D1 D2 D3hot
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:1c.4 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.1: [1002:aab0] type 00 class 0x040300
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.1: reg 0x10: [mem 0xd0540000-0xd0543fff 64bit]
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.1: enabling Extended Tags
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.1: supports D1 D2
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.4: PCI bridge to [bus 03]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.4: bridge window [mem 0xd0500000-0xd05fffff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.4: bridge window [mem 0xb0000000-0xbfffffff 64bit pref]
Sep 27 08:53:46 hp850 kernel: pci 0000:04:00.0: [10ec:5227] type 00 class 0xff0000
Sep 27 08:53:46 hp850 kernel: pci 0000:04:00.0: reg 0x10: [mem 0xd0400000-0xd0400fff]
Sep 27 08:53:46 hp850 kernel: pci 0000:04:00.0: supports D1 D2
Sep 27 08:53:46 hp850 kernel: pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: PCI bridge to [bus 04]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: bridge window [mem 0xd0400000-0xd04fffff]
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 *10 11 12 14 15)
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 10 11 12 14 15)
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
Sep 27 08:53:46 hp850 kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
Sep 27 08:53:46 hp850 kernel: ACPI: EC: interrupt unblocked
Sep 27 08:53:46 hp850 kernel: ACPI: EC: event unblocked
Sep 27 08:53:46 hp850 kernel: ACPI: EC: GPE=0x6
Sep 27 08:53:46 hp850 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
Sep 27 08:53:46 hp850 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
Sep 27 08:53:46 hp850 kernel: iommu: Default domain type: Translated
Sep 27 08:53:46 hp850 kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
Sep 27 08:53:46 hp850 kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
Sep 27 08:53:46 hp850 kernel: pci 0000:00:02.0: vgaarb: no bridge control possible
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: vgaarb: bridge control possible
Sep 27 08:53:46 hp850 kernel: vgaarb: loaded
Sep 27 08:53:46 hp850 kernel: SCSI subsystem initialized
Sep 27 08:53:46 hp850 kernel: libata version 3.00 loaded.
Sep 27 08:53:46 hp850 kernel: ACPI: bus type USB registered
Sep 27 08:53:46 hp850 kernel: usbcore: registered new interface driver usbfs
Sep 27 08:53:46 hp850 kernel: usbcore: registered new interface driver hub
Sep 27 08:53:46 hp850 kernel: usbcore: registered new device driver usb
Sep 27 08:53:46 hp850 kernel: pps_core: LinuxPPS API ver. 1 registered
Sep 27 08:53:46 hp850 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Sep 27 08:53:46 hp850 kernel: PTP clock support registered
Sep 27 08:53:46 hp850 kernel: EDAC MC: Ver: 3.0.0
Sep 27 08:53:46 hp850 kernel: NetLabel: Initializing
Sep 27 08:53:46 hp850 kernel: NetLabel: domain hash size = 128
Sep 27 08:53:46 hp850 kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
Sep 27 08:53:46 hp850 kernel: NetLabel: unlabeled traffic allowed by default
Sep 27 08:53:46 hp850 kernel: PCI: Using ACPI for IRQ routing
Sep 27 08:53:46 hp850 kernel: PCI: pci_cache_line_size set to 64 bytes
Sep 27 08:53:46 hp850 kernel: e820: reserve RAM buffer [mem 0x0009dc00-0x0009ffff]
Sep 27 08:53:46 hp850 kernel: e820: reserve RAM buffer [mem 0x8cb7f000-0x8fffffff]
Sep 27 08:53:46 hp850 kernel: e820: reserve RAM buffer [mem 0x8e000000-0x8fffffff]
Sep 27 08:53:46 hp850 kernel: e820: reserve RAM buffer [mem 0x24ee00000-0x24fffffff]
Sep 27 08:53:46 hp850 kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Sep 27 08:53:46 hp850 kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
Sep 27 08:53:46 hp850 kernel: clocksource: Switched to clocksource tsc-early
Sep 27 08:53:46 hp850 kernel: VFS: Disk quotas dquot_6.6.0
Sep 27 08:53:46 hp850 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Sep 27 08:53:46 hp850 kernel: pnp: PnP ACPI init
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xfed10000-0xfed17fff] could not be reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xfed90000-0xfed93fff] could not be reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xfed45000-0xfed8ffff] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xfec00000-0xfec00fff] could not be reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: [mem 0xaf210000-0xaf21ffff] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 27 08:53:46 hp850 kernel: system 00:01: [io 0x0200-0x027f] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:01: [io 0xffff] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:01: [io 0x1800-0x18fe] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:01: [io 0xef80-0xef9f] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 27 08:53:46 hp850 kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
Sep 27 08:53:46 hp850 kernel: pnp 00:03: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
Sep 27 08:53:46 hp850 kernel: pnp 00:04: Plug and Play ACPI device, IDs SYN3003 SYN0100 SYN0002 PNP0f13 (active)
Sep 27 08:53:46 hp850 kernel: system 00:05: [mem 0x20000000-0x201fffff] could not be reserved
Sep 27 08:53:46 hp850 kernel: system 00:05: [mem 0x40004000-0x40004fff] could not be reserved
Sep 27 08:53:46 hp850 kernel: system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active)
Sep 27 08:53:46 hp850 kernel: system 00:06: [mem 0xfed40000-0xfed44fff window] has been reserved
Sep 27 08:53:46 hp850 kernel: system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
Sep 27 08:53:46 hp850 kernel: pnp: PnP ACPI: found 7 devices
Sep 27 08:53:46 hp850 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Sep 27 08:53:46 hp850 kernel: NET: Registered protocol family 2
Sep 27 08:53:46 hp850 kernel: IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Sep 27 08:53:46 hp850 kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
Sep 27 08:53:46 hp850 kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
Sep 27 08:53:46 hp850 kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
Sep 27 08:53:46 hp850 kernel: TCP: Hash tables configured (established 65536 bind 65536)
Sep 27 08:53:46 hp850 kernel: MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
Sep 27 08:53:46 hp850 kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
Sep 27 08:53:46 hp850 kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
Sep 27 08:53:46 hp850 kernel: NET: Registered protocol family 44
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: no compatible bridge window
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: bridge window [io 0x1000-0x0fff] to [bus 04] add_size 1000
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04] add_size 200000 add_align 100000
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: BAR 15: assigned [mem 0xaf300000-0xaf4fffff 64bit pref]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: BAR 13: assigned [io 0x2000-0x2fff]
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.0: BAR 6: assigned [mem 0xd0560000-0xd057ffff pref]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: bridge window [io 0x2000-0x2fff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1c.5: bridge window [mem 0xaf300000-0xaf4fffff 64bit pref]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: resource 7 [mem 0xaf200000-0xdfffffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfed3ffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: resource 9 [mem 0xfed45000-0xfedfffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:00: resource 10 [mem 0xfee01000-0xffffffff window]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:01: resource 1 [mem 0xd0700000-0xd07fffff]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:02: resource 1 [mem 0xd0600000-0xd06fffff]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:03: resource 1 [mem 0xd0500000-0xd05fffff]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:03: resource 2 [mem 0xb0000000-0xbfffffff 64bit pref]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:04: resource 0 [io 0x2000-0x2fff]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:04: resource 1 [mem 0xd0400000-0xd04fffff]
Sep 27 08:53:46 hp850 kernel: pci_bus 0000:04: resource 2 [mem 0xaf300000-0xaf4fffff 64bit pref]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Sep 27 08:53:46 hp850 kernel: pci 0000:00:14.0: enabling device (0000 -> 0002)
Sep 27 08:53:46 hp850 kernel: pci 0000:00:1d.0: enabling device (0000 -> 0002)
Sep 27 08:53:46 hp850 kernel: pci 0000:03:00.1: D0 power state depends on 0000:03:00.0
Sep 27 08:53:46 hp850 kernel: PCI: CLS 64 bytes, default 64
Sep 27 08:53:46 hp850 kernel: Trying to unpack rootfs image as initramfs...
Sep 27 08:53:46 hp850 kernel: Freeing initrd memory: 12316K
Sep 27 08:53:46 hp850 kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Sep 27 08:53:46 hp850 kernel: software IO TLB: mapped [mem 0x0000000088b7f000-0x000000008cb7f000] (64MB)
Sep 27 08:53:46 hp850 kernel: check: Scanning for low memory corruption every 60 seconds
Sep 27 08:53:46 hp850 kernel: Initialise system trusted keyrings
Sep 27 08:53:46 hp850 kernel: Key type blacklist registered
Sep 27 08:53:46 hp850 kernel: workingset: timestamp_bits=41 max_order=21 bucket_order=0
Sep 27 08:53:46 hp850 kernel: zbud: loaded
Sep 27 08:53:46 hp850 kernel: Key type asymmetric registered
Sep 27 08:53:46 hp850 kernel: Asymmetric key parser 'x509' registered
Sep 27 08:53:46 hp850 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
Sep 27 08:53:46 hp850 kernel: io scheduler mq-deadline registered
Sep 27 08:53:46 hp850 kernel: io scheduler kyber registered
Sep 27 08:53:46 hp850 kernel: io scheduler bfq registered
Sep 27 08:53:46 hp850 kernel: atomic64_test: passed for x86-64 platform with CX8 and with SSE
Sep 27 08:53:46 hp850 kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 42
Sep 27 08:53:46 hp850 kernel: pcieport 0000:00:1c.3: PME: Signaling with IRQ 43
Sep 27 08:53:46 hp850 kernel: pcieport 0000:00:1c.4: PME: Signaling with IRQ 44
Sep 27 08:53:46 hp850 kernel: pcieport 0000:00:1c.5: PME: Signaling with IRQ 45
Sep 27 08:53:46 hp850 kernel: pcieport 0000:00:1c.5: pciehp: Slot #5 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
Sep 27 08:53:46 hp850 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Sep 27 08:53:46 hp850 kernel: vesafb: mode is 1920x1080x32, linelength=7680, pages=0
Sep 27 08:53:46 hp850 kernel: vesafb: scrolling: redraw
Sep 27 08:53:46 hp850 kernel: vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Sep 27 08:53:46 hp850 kernel: vesafb: framebuffer at 0xc0000000, mapped to 0x00000000370196f1, using 8128k, total 8128k
Sep 27 08:53:46 hp850 kernel: fbcon: Deferring console take-over
Sep 27 08:53:46 hp850 kernel: fb0: VESA VGA frame buffer device
Sep 27 08:53:46 hp850 kernel: intel_idle: MWAIT substates: 0x11142120
Sep 27 08:53:46 hp850 kernel: intel_idle: v0.5.1 model 0x45
Sep 27 08:53:46 hp850 kernel: intel_idle: Local APIC timer is reliable in all C-states
Sep 27 08:53:46 hp850 kernel: ACPI: AC Adapter [AC] (on-line)
Sep 27 08:53:46 hp850 kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
Sep 27 08:53:46 hp850 kernel: ACPI: Sleep Button [SLPB]
Sep 27 08:53:46 hp850 kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
Sep 27 08:53:46 hp850 kernel: ACPI: Lid Switch [LID]
Sep 27 08:53:46 hp850 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Sep 27 08:53:46 hp850 kernel: ACPI: Power Button [PWRF]
Sep 27 08:53:46 hp850 kernel: thermal LNXTHERM:00: registered as thermal_zone0
Sep 27 08:53:46 hp850 kernel: ACPI: Thermal Zone [CPUZ] (29 C)
Sep 27 08:53:46 hp850 kernel: thermal LNXTHERM:01: registered as thermal_zone1
Sep 27 08:53:46 hp850 kernel: ACPI: Thermal Zone [GFXZ] (0 C)
Sep 27 08:53:46 hp850 kernel: thermal LNXTHERM:02: registered as thermal_zone2
Sep 27 08:53:46 hp850 kernel: ACPI: Thermal Zone [EXTZ] (0 C)
Sep 27 08:53:46 hp850 kernel: thermal LNXTHERM:03: registered as thermal_zone3
Sep 27 08:53:46 hp850 kernel: ACPI: Thermal Zone [LOCZ] (25 C)
Sep 27 08:53:46 hp850 kernel: thermal LNXTHERM:04: registered as thermal_zone4
Sep 27 08:53:46 hp850 kernel: ACPI: Thermal Zone [BATZ] (24 C)
Sep 27 08:53:46 hp850 kernel: thermal LNXTHERM:05: registered as thermal_zone5
Sep 27 08:53:46 hp850 kernel: ACPI: Thermal Zone [PCHZ] (114 C)
Sep 27 08:53:46 hp850 kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Sep 27 08:53:46 hp850 kernel: 0000:00:16.3: ttyS4 at I/O 0x40b0 (irq = 19, base_baud = 115200) is a 16550A
Sep 27 08:53:46 hp850 kernel: Non-volatile memory driver v1.3
Sep 27 08:53:46 hp850 kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
Sep 27 08:53:46 hp850 kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
Sep 27 08:53:46 hp850 kernel: ahci 0000:00:1f.2: version 3.0
Sep 27 08:53:46 hp850 kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
Sep 27 08:53:46 hp850 kernel: ahci 0000:00:1f.2: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
Sep 27 08:53:46 hp850 kernel: scsi host0: ahci
Sep 27 08:53:46 hp850 kernel: scsi host1: ahci
Sep 27 08:53:46 hp850 kernel: ata1: SATA max UDMA/133 abar m2048@0xd083c000 port 0xd083c100 irq 46
Sep 27 08:53:46 hp850 kernel: ata2: SATA max UDMA/133 abar m2048@0xd083c000 port 0xd083c180 irq 46
Sep 27 08:53:46 hp850 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sep 27 08:53:46 hp850 kernel: ehci-pci: EHCI PCI platform driver
Sep 27 08:53:46 hp850 kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
Sep 27 08:53:46 hp850 kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 1
Sep 27 08:53:46 hp850 kernel: ehci-pci 0000:00:1d.0: debug port 2
Sep 27 08:53:46 hp850 kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
Sep 27 08:53:46 hp850 kernel: ehci-pci 0000:00:1d.0: irq 17, io mem 0xd083d000
Sep 27 08:53:46 hp850 kernel: battery: ACPI: Battery Slot [BAT0] (battery present)
Sep 27 08:53:46 hp850 kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Sep 27 08:53:46 hp850 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Sep 27 08:53:46 hp850 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 27 08:53:46 hp850 kernel: usb usb1: Product: EHCI Host Controller
Sep 27 08:53:46 hp850 kernel: usb usb1: Manufacturer: Linux 5.10.68-1-MANJARO ehci_hcd
Sep 27 08:53:46 hp850 kernel: usb usb1: SerialNumber: 0000:00:1d.0
Sep 27 08:53:46 hp850 kernel: hub 1-0:1.0: USB hub found
Sep 27 08:53:46 hp850 kernel: hub 1-0:1.0: 3 ports detected
Sep 27 08:53:46 hp850 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Sep 27 08:53:46 hp850 kernel: ohci-pci: OHCI PCI platform driver
Sep 27 08:53:46 hp850 kernel: uhci_hcd: USB Universal Host Controller Interface driver
Sep 27 08:53:46 hp850 kernel: usbcore: registered new interface driver usbserial_generic
Sep 27 08:53:46 hp850 kernel: usbserial: USB Serial support registered for generic
Sep 27 08:53:46 hp850 kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Sep 27 08:53:46 hp850 kernel: i8042: Detected active multiplexing controller, rev 1.1
Sep 27 08:53:46 hp850 kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Sep 27 08:53:46 hp850 kernel: serio: i8042 AUX0 port at 0x60,0x64 irq 12
Sep 27 08:53:46 hp850 kernel: serio: i8042 AUX1 port at 0x60,0x64 irq 12
Sep 27 08:53:46 hp850 kernel: serio: i8042 AUX2 port at 0x60,0x64 irq 12
Sep 27 08:53:46 hp850 kernel: serio: i8042 AUX3 port at 0x60,0x64 irq 12
Sep 27 08:53:46 hp850 kernel: rtc_cmos 00:02: RTC can wake from S4
Sep 27 08:53:46 hp850 kernel: rtc_cmos 00:02: registered as rtc0
Sep 27 08:53:46 hp850 kernel: rtc_cmos 00:02: setting system clock to 2021-09-27T06:53:44 UTC (1632725624)
Sep 27 08:53:46 hp850 kernel: rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
Sep 27 08:53:46 hp850 kernel: intel_pstate: Intel P-state driver initializing
Sep 27 08:53:46 hp850 kernel: ledtrig-cpu: registered to indicate activity on CPUs
Sep 27 08:53:46 hp850 kernel: hid: raw HID events driver (C) Jiri Kosina
Sep 27 08:53:46 hp850 kernel: ashmem: initialized
Sep 27 08:53:46 hp850 kernel: drop_monitor: Initializing network drop monitor service
Sep 27 08:53:46 hp850 kernel: Initializing XFRM netlink socket
Sep 27 08:53:46 hp850 kernel: NET: Registered protocol family 10
Sep 27 08:53:46 hp850 kernel: Segment Routing with IPv6
Sep 27 08:53:46 hp850 kernel: RPL Segment Routing with IPv6
Sep 27 08:53:46 hp850 kernel: NET: Registered protocol family 17
Sep 27 08:53:46 hp850 kernel: microcode: sig=0x40651, pf=0x40, revision=0x26
Sep 27 08:53:46 hp850 kernel: microcode: Microcode Update Driver: v2.2.
Sep 27 08:53:46 hp850 kernel: IPI shorthand broadcast: enabled
Sep 27 08:53:46 hp850 kernel: sched_clock: Marking stable (2152384390, 430825)->(2159379583, -6564368)
Sep 27 08:53:46 hp850 kernel: registered taskstats version 1
Sep 27 08:53:46 hp850 kernel: Loading compiled-in X.509 certificates
Sep 27 08:53:46 hp850 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 55a33a7eecb7984093c5301c4991fda12ca45160'
Sep 27 08:53:46 hp850 kernel: zswap: loaded using pool zstd/z3fold
Sep 27 08:53:46 hp850 kernel: Key type ._fscrypt registered
Sep 27 08:53:46 hp850 kernel: Key type .fscrypt registered
Sep 27 08:53:46 hp850 kernel: Key type fscrypt-provisioning registered
Sep 27 08:53:46 hp850 kernel: PM: Magic number: 5:23:874
Sep 27 08:53:46 hp850 kernel: RAS: Correctable Errors collector initialized.
Sep 27 08:53:46 hp850 kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
Sep 27 08:53:46 hp850 kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
Sep 27 08:53:46 hp850 kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Sep 27 08:53:46 hp850 kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Sep 27 08:53:46 hp850 kernel: ata2.00: ATA-9: TS240GMTS420S, S0509A0, max UDMA/133
Sep 27 08:53:46 hp850 kernel: ata2.00: 468862128 sectors, multi 1: LBA48 NCQ (depth 32), AA
Sep 27 08:53:46 hp850 kernel: ata2.00: configured for UDMA/133
Sep 27 08:53:46 hp850 kernel: ata1.00: ATA-8: ST500LM021-1KJ152, 0002YXM1, max UDMA/133
Sep 27 08:53:46 hp850 kernel: ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32), AA
Sep 27 08:53:46 hp850 kernel: ata1.00: configured for UDMA/133
Sep 27 08:53:46 hp850 kernel: scsi 0:0:0:0: Direct-Access ATA ST500LM021-1KJ15 YXM1 PQ: 0 ANSI: 5
Sep 27 08:53:46 hp850 kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Sep 27 08:53:46 hp850 kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Sep 27 08:53:46 hp850 kernel: sd 0:0:0:0: [sda] Write Protect is off
Sep 27 08:53:46 hp850 kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Sep 27 08:53:46 hp850 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 27 08:53:46 hp850 kernel: scsi 1:0:0:0: Direct-Access ATA TS240GMTS420S 9A0 PQ: 0 ANSI: 5
Sep 27 08:53:46 hp850 kernel: sd 1:0:0:0: [sdb] 468862128 512-byte logical blocks: (240 GB/224 GiB)
Sep 27 08:53:46 hp850 kernel: sd 1:0:0:0: [sdb] Write Protect is off
Sep 27 08:53:46 hp850 kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Sep 27 08:53:46 hp850 kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 27 08:53:46 hp850 kernel: sdb: sdb1 sdb2 sdb3
Sep 27 08:53:46 hp850 kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=8000, bcdDevice= 0.04
Sep 27 08:53:46 hp850 kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 27 08:53:46 hp850 kernel: hub 1-1:1.0: USB hub found
Sep 27 08:53:46 hp850 kernel: hub 1-1:1.0: 8 ports detected
Sep 27 08:53:46 hp850 kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Sep 27 08:53:46 hp850 kernel: sda: sda1
Sep 27 08:53:46 hp850 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Sep 27 08:53:46 hp850 kernel: PM: Image not found (code -22)
Sep 27 08:53:46 hp850 kernel: Freeing unused decrypted memory: 2036K
Sep 27 08:53:46 hp850 kernel: Freeing unused kernel image (initmem) memory: 1712K
Sep 27 08:53:46 hp850 kernel: Write protecting the kernel read-only data: 26624k
Sep 27 08:53:46 hp850 kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
Sep 27 08:53:46 hp850 kernel: Freeing unused kernel image (rodata/data gap) memory: 1080K
Sep 27 08:53:46 hp850 kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Sep 27 08:53:46 hp850 kernel: rodata_test: all tests were successful
Sep 27 08:53:46 hp850 kernel: x86/mm: Checking user space page tables
Sep 27 08:53:46 hp850 kernel: Run /init as init process
Sep 27 08:53:46 hp850 kernel: with arguments:
Sep 27 08:53:46 hp850 kernel: /init
Sep 27 08:53:46 hp850 kernel: with environment:
Sep 27 08:53:46 hp850 kernel: HOME=/
Sep 27 08:53:46 hp850 kernel: TERM=linux
Sep 27 08:53:46 hp850 kernel: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
Sep 27 08:53:46 hp850 kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Sep 27 08:53:46 hp850 kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Sep 27 08:53:46 hp850 kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x000000000004b810
Sep 27 08:53:46 hp850 kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
Sep 27 08:53:46 hp850 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Sep 27 08:53:46 hp850 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 27 08:53:46 hp850 kernel: usb usb2: Product: xHCI Host Controller
Sep 27 08:53:46 hp850 kernel: usb usb2: Manufacturer: Linux 5.10.68-1-MANJARO xhci-hcd
Sep 27 08:53:46 hp850 kernel: usb usb2: SerialNumber: 0000:00:14.0
Sep 27 08:53:46 hp850 kernel: hub 2-0:1.0: USB hub found
Sep 27 08:53:46 hp850 kernel: hub 2-0:1.0: 9 ports detected
Sep 27 08:53:46 hp850 kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
Sep 27 08:53:46 hp850 kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
Sep 27 08:53:46 hp850 kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
Sep 27 08:53:46 hp850 kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 27 08:53:46 hp850 kernel: usb usb3: Product: xHCI Host Controller
Sep 27 08:53:46 hp850 kernel: usb usb3: Manufacturer: Linux 5.10.68-1-MANJARO xhci-hcd
Sep 27 08:53:46 hp850 kernel: usb usb3: SerialNumber: 0000:00:14.0
Sep 27 08:53:46 hp850 kernel: hub 3-0:1.0: USB hub found
Sep 27 08:53:46 hp850 kernel: hub 3-0:1.0: 4 ports detected
Sep 27 08:53:46 hp850 kernel: usb: port power management may be unreliable
Sep 27 08:53:46 hp850 kernel: random: fast init done
Sep 27 08:53:46 hp850 kernel: usb 3-3: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
Sep 27 08:53:46 hp850 kernel: usb 3-3: New USB device found, idVendor=0424, idProduct=5534, bcdDevice=50.00
Sep 27 08:53:46 hp850 kernel: usb 3-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
Sep 27 08:53:46 hp850 kernel: usb 3-3: Product: USB5534B
Sep 27 08:53:46 hp850 kernel: usb 3-3: Manufacturer: SMSC
Sep 27 08:53:46 hp850 kernel: hub 3-3:1.0: USB hub found
Sep 27 08:53:46 hp850 kernel: hub 3-3:1.0: 4 ports detected
Sep 27 08:53:46 hp850 kernel: tsc: Refined TSC clocksource calibration: 2693.764 MHz
Sep 27 08:53:46 hp850 kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26d43bb7f27, max_idle_ns: 440795270902 ns
Sep 27 08:53:46 hp850 kernel: EXT4-fs (sdb1): recovery complete
Sep 27 08:53:46 hp850 kernel: EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
Sep 27 08:53:46 hp850 kernel: usb 2-3: new high-speed USB device number 2 using xhci_hcd
Sep 27 08:53:46 hp850 systemd[1]: systemd 249.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
Sep 27 08:53:46 hp850 kernel: usb 2-3: New USB device found, idVendor=0424, idProduct=2134, bcdDevice=50.00
Sep 27 08:53:46 hp850 kernel: usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 27 08:53:46 hp850 kernel: usb 2-3: Product: USB2134B
Sep 27 08:53:46 hp850 kernel: usb 2-3: Manufacturer: SMSC
Sep 27 08:53:46 hp850 kernel: hub 2-3:1.0: USB hub found
Sep 27 08:53:46 hp850 kernel: hub 2-3:1.0: 4 ports detected
Sep 27 08:53:46 hp850 systemd[1]: Detected architecture x86-64.
Sep 27 08:53:46 hp850 systemd[1]: Hostname set to <hp850>.
Sep 27 08:53:46 hp850 kernel: usb 2-5: new full-speed USB device number 3 using xhci_hcd
Sep 27 08:53:46 hp850 kernel: usb 2-5: New USB device found, idVendor=138a, idProduct=003f, bcdDevice= 1.04
Sep 27 08:53:46 hp850 kernel: usb 2-5: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Sep 27 08:53:46 hp850 kernel: usb 2-5: SerialNumber: 002094360580
Sep 27 08:53:46 hp850 kernel: random: lvmconfig: uninitialized urandom read (4 bytes read)
Sep 27 08:53:46 hp850 kernel: usb 2-3.2: new full-speed USB device number 4 using xhci_hcd
Sep 27 08:53:46 hp850 kernel: usb 2-3.2: New USB device found, idVendor=8087, idProduct=07dc, bcdDevice= 0.01
Sep 27 08:53:46 hp850 kernel: usb 2-3.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 27 08:53:46 hp850 systemd[1]: Queued start job for default target Graphical Interface.
Sep 27 08:53:46 hp850 systemd[1]: Created slice Slice /system/getty.
Sep 27 08:53:46 hp850 systemd[1]: Created slice Slice /system/modprobe.
Sep 27 08:53:46 hp850 systemd[1]: Created slice Slice /system/systemd-fsck.
Sep 27 08:53:46 hp850 systemd[1]: Created slice User and Session Slice.
Sep 27 08:53:46 hp850 systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Sep 27 08:53:46 hp850 systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Sep 27 08:53:46 hp850 systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Sep 27 08:53:46 hp850 systemd[1]: Reached target Local Encrypted Volumes.
Sep 27 08:53:46 hp850 systemd[1]: Reached target Login Prompts.
Sep 27 08:53:46 hp850 systemd[1]: Reached target Remote File Systems.
Sep 27 08:53:46 hp850 systemd[1]: Reached target Slice Units.
Sep 27 08:53:46 hp850 systemd[1]: Reached target Local Verity Integrity Protected Volumes.
Sep 27 08:53:46 hp850 systemd[1]: Listening on Device-mapper event daemon FIFOs.
Sep 27 08:53:46 hp850 systemd[1]: Listening on LVM2 poll daemon socket.
Sep 27 08:53:46 hp850 systemd[1]: Listening on Process Core Dump Socket.
Sep 27 08:53:46 hp850 systemd[1]: Listening on Journal Audit Socket.
Sep 27 08:53:46 hp850 systemd[1]: Listening on Journal Socket (/dev/log).
Sep 27 08:53:46 hp850 systemd[1]: Listening on Journal Socket.
Sep 27 08:53:46 hp850 systemd[1]: Listening on udev Control Socket.
Sep 27 08:53:46 hp850 systemd[1]: Listening on udev Kernel Socket.
Sep 27 08:53:46 hp850 systemd[1]: Mounting Huge Pages File System...
Sep 27 08:53:46 hp850 systemd[1]: Mounting POSIX Message Queue File System...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Kernel Debug File System...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Kernel Trace File System...
Sep 27 08:53:46 hp850 systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
Sep 27 08:53:46 hp850 systemd[1]: Starting Create List of Static Device Nodes...
Sep 27 08:53:46 hp850 systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Sep 27 08:53:46 hp850 systemd[1]: Starting Load Kernel Module configfs...
Sep 27 08:53:46 hp850 systemd[1]: Starting Load Kernel Module drm...
Sep 27 08:53:46 hp850 systemd[1]: Starting Load Kernel Module fuse...
Sep 27 08:53:46 hp850 systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
Sep 27 08:53:46 hp850 kernel: random: lvm: uninitialized urandom read (4 bytes read)
Sep 27 08:53:46 hp850 systemd[1]: Starting Set Up Additional Binary Formats...
Sep 27 08:53:46 hp850 systemd[1]: Starting Load Kernel Modules...
Sep 27 08:53:46 hp850 systemd[1]: Starting Remount Root and Kernel File Systems...
Sep 27 08:53:46 hp850 kernel: Linux agpgart interface v0.103
Sep 27 08:53:46 hp850 systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
Sep 27 08:53:46 hp850 systemd[1]: Starting Coldplug All udev Devices...
Sep 27 08:53:46 hp850 kernel: acpi_call: loading out-of-tree module taints kernel.
Sep 27 08:53:46 hp850 kernel: acpi_call: module verification failed: signature and/or required key missing - tainting kernel
Sep 27 08:53:46 hp850 kernel: EXT4-fs (sdb1): re-mounted. Opts: (null)
Sep 27 08:53:46 hp850 systemd[1]: Mounted Huge Pages File System.
Sep 27 08:53:46 hp850 systemd[1]: Mounted POSIX Message Queue File System.
Sep 27 08:53:46 hp850 systemd[1]: Mounted Kernel Debug File System.
Sep 27 08:53:46 hp850 systemd[1]: Mounted Kernel Trace File System.
Sep 27 08:53:46 hp850 systemd[1]: Finished Create List of Static Device Nodes.
Sep 27 08:53:46 hp850 systemd[1]: modprobe@configfs.service: Deactivated successfully.
Sep 27 08:53:46 hp850 systemd[1]: Finished Load Kernel Module configfs.
Sep 27 08:53:46 hp850 systemd[1]: Finished Remount Root and Kernel File Systems.
Sep 27 08:53:46 hp850 systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 204 (systemd-binfmt)
Sep 27 08:53:46 hp850 systemd[1]: Mounting Arbitrary Executable File Formats File System...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Kernel Configuration File System...
Sep 27 08:53:46 hp850 systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Sep 27 08:53:46 hp850 systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Sep 27 08:53:46 hp850 kernel: fuse: init (API version 7.32)
Sep 27 08:53:46 hp850 systemd[1]: Starting Load/Save Random Seed...
Sep 27 08:53:46 hp850 systemd[1]: Condition check resulted in Create System Users being skipped.
Sep 27 08:53:46 hp850 systemd[1]: Starting Create Static Device Nodes in /dev...
Sep 27 08:53:46 hp850 systemd[1]: modprobe@fuse.service: Deactivated successfully.
Sep 27 08:53:46 hp850 systemd[1]: Finished Load Kernel Module fuse.
Sep 27 08:53:46 hp850 systemd[1]: Mounted Arbitrary Executable File Formats File System.
Sep 27 08:53:46 hp850 systemd[1]: Mounted Kernel Configuration File System.
Sep 27 08:53:46 hp850 systemd[1]: Mounting FUSE Control File System...
Sep 27 08:53:46 hp850 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Sep 27 08:53:46 hp850 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Sep 27 08:53:46 hp850 systemd[1]: Finished Set Up Additional Binary Formats.
Sep 27 08:53:46 hp850 systemd[1]: Mounted FUSE Control File System.
Sep 27 08:53:46 hp850 kernel: mc: Linux media interface: v0.10
Sep 27 08:53:46 hp850 systemd[1]: modprobe@drm.service: Deactivated successfully.
Sep 27 08:53:46 hp850 systemd[1]: Finished Load Kernel Module drm.
Sep 27 08:53:46 hp850 systemd[1]: Finished Create Static Device Nodes in /dev.
Sep 27 08:53:46 hp850 systemd[1]: Condition check resulted in Entropy Daemon based on the HAVEGE algorithm being skipped.
Sep 27 08:53:46 hp850 systemd[1]: Starting Journal Service...
Sep 27 08:53:46 hp850 systemd[1]: Starting Rule-based Manager for Device Events and Files...
Sep 27 08:53:46 hp850 kernel: videodev: Linux video capture interface: v2.00
Sep 27 08:53:46 hp850 kernel: v4l2loopback driver version 0.6.3 (droidcam) loaded
Sep 27 08:53:46 hp850 kernel: usb 2-6: new high-speed USB device number 5 using xhci_hcd
Sep 27 08:53:46 hp850 systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Sep 27 08:53:46 hp850 kernel: audit: type=1130 audit(1632725626.126:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:46 hp850 systemd[1]: Reached target Preparation for Local File Systems.
Sep 27 08:53:46 hp850 systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for bare, revision 5...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for core, revision 11420...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for core, revision 11606...
Sep 27 08:53:46 hp850 kernel: loop: module loaded
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for core18, revision 2074...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for core18, revision 2128...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for gnome-3-28-1804, revision 145...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for gnome-3-28-1804, revision 161...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for gnome-3-34-1804, revision 66...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for gnome-3-34-1804, revision 72...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1515...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1519...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for kde-frameworks-5-core18, revision 32...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for meshlab, revision 183...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for meshlab, revision 36...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for notepad-plus-plus, revision 291...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for notepad-plus-plus, revision 292...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for p3x-onenote, revision 129...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for p3x-onenote, revision 130...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for snapd, revision 12883...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for snapd, revision 13170...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for wine-platform-5-stable, revision 16...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for wine-platform-5-stable, revision 18...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for wine-platform-6-stable, revision 5...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for wine-platform-6-stable, revision 8...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for wine-platform-runtime, revision 241...
Sep 27 08:53:46 hp850 systemd[1]: Mounting Mount unit for wine-platform-runtime, revision 243...
Sep 27 08:53:46 hp850 systemd[1]: Started Journal Service.
Sep 27 08:53:46 hp850 kernel: audit: type=1130 audit(1632725626.190:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:46 hp850 kernel: vboxdrv: Found 4 processor cores
Sep 27 08:53:46 hp850 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Sep 27 08:53:46 hp850 kernel: audit: type=1130 audit(1632725626.190:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:46 hp850 kernel: vboxdrv: TSC mode is Invariant, tentative frequency 2693762699 Hz
Sep 27 08:53:46 hp850 kernel: vboxdrv: Successfully loaded version 6.1.26 r145957 (interface 0x00300000)
Sep 27 08:53:46 hp850 kernel: VBoxNetAdp: Successfully started.
Sep 27 08:53:46 hp850 kernel: VBoxNetFlt: Successfully started.
Sep 27 08:53:46 hp850 kernel: audit: type=1130 audit(1632725626.230:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:46 hp850 kernel: audit: type=1130 audit(1632725626.236:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:46 hp850 kernel: audit: type=1130 audit(1632725626.246:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:46 hp850 kernel: usb 2-6: New USB device found, idVendor=03f0, idProduct=521d, bcdDevice= 0.01
Sep 27 08:53:46 hp850 kernel: usb 2-6: New USB device strings: Mfr=5, Product=4, SerialNumber=0
Sep 27 08:53:46 hp850 kernel: usb 2-6: Product: HP hs3110 HSPA+ Mobile Broadband Device
Sep 27 08:53:46 hp850 kernel: usb 2-6: Manufacturer: Hewlett-Packard
Sep 27 08:53:46 hp850 kernel: audit: type=1130 audit(1632725626.276:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:46 hp850 kernel: audit: type=1130 audit(1632725626.293:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:46 hp850 kernel: usb 2-3.3: new full-speed USB device number 6 using xhci_hcd
Sep 27 08:53:46 hp850 kernel: input: HP Wireless hotkeys as /devices/virtual/input/input8
Sep 27 08:53:46 hp850 kernel: hp_accel: laptop model unknown, using default axes configuration
Sep 27 08:53:46 hp850 kernel: usb 2-3.3: New USB device found, idVendor=248a, idProduct=8514, bcdDevice= 1.00
Sep 27 08:53:46 hp850 kernel: usb 2-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 27 08:53:46 hp850 kernel: usb 2-3.3: Product: Wireless Receiver
Sep 27 08:53:46 hp850 kernel: usb 2-3.3: Manufacturer: Telink
Sep 27 08:53:46 hp850 kernel: usb 2-7: new high-speed USB device number 7 using xhci_hcd
Sep 27 08:53:46 hp850 kernel: lis3lv02d: 8 bits 3DC sensor found
Sep 27 08:53:46 hp850 kernel: e1000e: Intel(R) PRO/1000 Network Driver
Sep 27 08:53:46 hp850 kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Sep 27 08:53:46 hp850 kernel: e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
Sep 27 08:53:46 hp850 kernel: i801_smbus 0000:00:1f.3: SPD Write Disable is set
Sep 27 08:53:46 hp850 kernel: i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
Sep 27 08:53:46 hp850 kernel: i2c i2c-0: 1/2 memory slots populated (from DMI)
Sep 27 08:53:46 hp850 kernel: i2c i2c-0: Successfully instantiated SPD at 0x50
Sep 27 08:53:46 hp850 kernel: EXT4-fs (sdb3): recovery complete
Sep 27 08:53:46 hp850 kernel: EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: (null)
Sep 27 08:53:46 hp850 kernel: Adding 9008124k swap on /dev/sdb2. Priority:-2 extents:1 across:9008124k SSFS
Sep 27 08:53:46 hp850 kernel: usb 2-7: New USB device found, idVendor=05c8, idProduct=0369, bcdDevice= 1.08
Sep 27 08:53:46 hp850 kernel: usb 2-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 27 08:53:46 hp850 kernel: usb 2-7: Product: HP HD Webcam
Sep 27 08:53:46 hp850 kernel: usb 2-7: Manufacturer: SunplusIT INC.
Sep 27 08:53:46 hp850 kernel: input: PC Speaker as /devices/platform/pcspkr/input/input9
Sep 27 08:53:46 hp850 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Sep 27 08:53:46 hp850 kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Sep 27 08:53:46 hp850 kernel: e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
Sep 27 08:53:46 hp850 kernel: Intel(R) Wireless WiFi driver for Linux
Sep 27 08:53:46 hp850 kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than Reserved [mem 0xfed10000-0xfed13fff]
Sep 27 08:53:46 hp850 kernel: caller snb_uncore_imc_init_box+0x78/0xc0 [intel_uncore] mapping multiple BARs
Sep 27 08:53:46 hp850 kernel: e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 50:65:f3:bc:ef:fe
Sep 27 08:53:46 hp850 kernel: e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
Sep 27 08:53:46 hp850 kernel: e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
Sep 27 08:53:46 hp850 kernel: iwlwifi 0000:02:00.0: loaded firmware version 17.3216344376.0 7260-17.ucode op_mode iwlmvm
Sep 27 08:53:46 hp850 kernel: RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
Sep 27 08:53:46 hp850 kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
Sep 27 08:53:46 hp850 kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
Sep 27 08:53:46 hp850 kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules
Sep 27 08:53:46 hp850 kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
Sep 27 08:53:47 hp850 kernel: audit: type=1130 audit(1632725627.003:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-bf948530\x2da491\x2d4db4\x2da861\x2deaa7941d0f87 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:47 hp850 kernel: cryptd: max_cpu_qlen set to 1000
Sep 27 08:53:47 hp850 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Sep 27 08:53:47 hp850 kernel: snd_hda_intel 0000:03:00.1: Handle vga_switcheroo audio client
Sep 27 08:53:47 hp850 kernel: snd_hda_intel 0000:03:00.1: Force to non-snoop mode
Sep 27 08:53:47 hp850 kernel: input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1c.4/0000:03:00.1/sound/card3/input12
Sep 27 08:53:47 hp850 kernel: input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1c.4/0000:03:00.1/sound/card3/input13
Sep 27 08:53:47 hp850 kernel: snd_hda_codec_idt hdaudioC2D0: autoconfig for 92HD91BXX: line_outs=1 (0xa/0x0/0x0/0x0/0x0) type:line
Sep 27 08:53:47 hp850 kernel: snd_hda_codec_idt hdaudioC2D0: speaker_outs=1 (0xd/0x0/0x0/0x0/0x0)
Sep 27 08:53:47 hp850 kernel: snd_hda_codec_idt hdaudioC2D0: hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
Sep 27 08:53:47 hp850 kernel: snd_hda_codec_idt hdaudioC2D0: mono: mono_out=0x0
Sep 27 08:53:47 hp850 kernel: snd_hda_codec_idt hdaudioC2D0: inputs:
Sep 27 08:53:47 hp850 kernel: snd_hda_codec_idt hdaudioC2D0: Mic=0xc
Sep 27 08:53:47 hp850 kernel: snd_hda_codec_idt hdaudioC2D0: Internal Mic=0x11
Sep 27 08:53:47 hp850 kernel: snd_hda_codec_idt hdaudioC2D0: Line=0xf
Sep 27 08:53:47 hp850 kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144
Sep 27 08:53:47 hp850 kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card2/input14
Sep 27 08:53:47 hp850 kernel: input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card2/input15
Sep 27 08:53:47 hp850 kernel: input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card2/input16
Sep 27 08:53:47 hp850 kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card2/input17
Sep 27 08:53:47 hp850 kernel: iwlwifi 0000:02:00.0: base HW address: d8:fc:93:ac:d2:c6
Sep 27 08:53:47 hp850 kernel: AVX2 version of gcm_enc/dec engaged.
Sep 27 08:53:47 hp850 kernel: AES CTR mode by8 optimization enabled
Sep 27 08:53:47 hp850 kernel: checking generic (c0000000 7f0000) vs hw (d0000000 400000)
Sep 27 08:53:47 hp850 kernel: checking generic (c0000000 7f0000) vs hw (c0000000 10000000)
Sep 27 08:53:47 hp850 kernel: fb0: switching to inteldrmfb from VESA VGA
Sep 27 08:53:47 hp850 kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Sep 27 08:53:47 hp850 kernel: random: crng init done
Sep 27 08:53:47 hp850 kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
Sep 27 08:53:47 hp850 kernel: [drm] radeon kernel modesetting enabled.
Sep 27 08:53:47 hp850 kernel: iTCO_vendor_support: vendor-support=0
Sep 27 08:53:47 hp850 kernel: vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
Sep 27 08:53:47 hp850 kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
Sep 27 08:53:47 hp850 kernel: iTCO_wdt: Found a Lynx Point_LP TCO device (Version=2, TCOBASE=0x1860)
Sep 27 08:53:47 hp850 kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Sep 27 08:53:47 hp850 kernel: [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
Sep 27 08:53:47 hp850 kernel: ATPX version 1, functions 0x00000003
Sep 27 08:53:47 hp850 kernel: ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
Sep 27 08:53:47 hp850 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input19
Sep 27 08:53:47 hp850 kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
Sep 27 08:53:47 hp850 kernel: at24 0-0050: supply vcc not found, using dummy regulator
Sep 27 08:53:47 hp850 kernel: at24 0-0050: 256 byte spd EEPROM, read-only
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: enabling device (0000 -> 0003)
Sep 27 08:53:47 hp850 kernel: [Firmware Bug]: ACPI(DGFX) defines _DOD but not _DOS
Sep 27 08:53:47 hp850 kernel: ACPI: Video Device [DGFX] (multi-head: yes rom: no post: no)
Sep 27 08:53:47 hp850 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3f/LNXVIDEO:01/input/input20
Sep 27 08:53:47 hp850 kernel: snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Sep 27 08:53:47 hp850 kernel: [drm] initializing kernel modesetting (OLAND 0x1002:0x6601 0x103C:0x1990 0x00).
Sep 27 08:53:47 hp850 kernel: vga_switcheroo: enabled
Sep 27 08:53:47 hp850 kernel: fbcon: i915drmfb (fb0) is primary device
Sep 27 08:53:47 hp850 kernel: fbcon: Deferring console take-over
Sep 27 08:53:47 hp850 kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Sep 27 08:53:47 hp850 kernel: input: HP WMI hotkeys as /devices/virtual/input/input18
Sep 27 08:53:47 hp850 kernel: input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card1/input21
Sep 27 08:53:47 hp850 kernel: input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card1/input22
Sep 27 08:53:47 hp850 kernel: input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card1/input23
Sep 27 08:53:47 hp850 kernel: input: HDA Intel HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.0/sound/card1/input24
Sep 27 08:53:47 hp850 kernel: ATOM BIOS: IEC/HP
Sep 27 08:53:47 hp850 kernel: [drm] GPU not posted. posting now...
Sep 27 08:53:47 hp850 kernel: kauditd_printk_skb: 2 callbacks suppressed
Sep 27 08:53:47 hp850 kernel: audit: type=1127 audit(1632725627.510:13): pid=400 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: GTT: 2048M 0x0000000040000000 - 0x00000000BFFFFFFF
Sep 27 08:53:47 hp850 kernel: [drm] Detected VRAM RAM=1024M, BAR=256M
Sep 27 08:53:47 hp850 kernel: [drm] RAM width 128bits DDR
Sep 27 08:53:47 hp850 kernel: intel-spi intel-spi: w25q128 (16384 Kbytes)
Sep 27 08:53:47 hp850 kernel: audit: type=1130 audit(1632725627.513:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:47 hp850 kernel: [TTM] Zone kernel: Available graphics memory: 3778316 KiB
Sep 27 08:53:47 hp850 kernel: [TTM] Zone dma32: Available graphics memory: 2097152 KiB
Sep 27 08:53:47 hp850 kernel: [TTM] Initializing pool allocator
Sep 27 08:53:47 hp850 kernel: [TTM] Initializing DMA pool allocator
Sep 27 08:53:47 hp850 kernel: [drm] radeon: 1024M of VRAM memory ready
Sep 27 08:53:47 hp850 kernel: [drm] radeon: 2048M of GTT memory ready.
Sep 27 08:53:47 hp850 kernel: [drm] Loading oland Microcode
Sep 27 08:53:47 hp850 kernel: audit: type=1130 audit(1632725627.526:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:47 hp850 kernel: audit: type=1130 audit(1632725627.533:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:47 hp850 kernel: Creating 1 MTD partitions on "intel-spi":
Sep 27 08:53:47 hp850 kernel: 0x000000000000-0x000001000000 : "BIOS"
Sep 27 08:53:47 hp850 kernel: e1000e 0000:00:19.0 enp0s25: renamed from eth0
Sep 27 08:53:47 hp850 kernel: [drm] Internal thermal controller without fan control
Sep 27 08:53:47 hp850 kernel: [drm] radeon: dpm initialized
Sep 27 08:53:47 hp850 kernel: audit: type=1130 audit(1632725627.560:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=preload comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:47 hp850 kernel: audit: type=1334 audit(1632725627.583:18): prog-id=9 op=LOAD
Sep 27 08:53:47 hp850 kernel: audit: type=1334 audit(1632725627.606:19): prog-id=10 op=LOAD
Sep 27 08:53:47 hp850 kernel: audit: type=1334 audit(1632725627.606:20): prog-id=11 op=LOAD
Sep 27 08:53:47 hp850 kernel: audit: type=1334 audit(1632725627.613:21): prog-id=12 op=LOAD
Sep 27 08:53:47 hp850 kernel: [drm] Found VCE firmware/feedback version 50.0.1 / 17!
Sep 27 08:53:47 hp850 kernel: [drm] GART: num cpu pages 524288, num gpu pages 524288
Sep 27 08:53:47 hp850 kernel: [drm] PCIE gen 2 link speeds already enabled
Sep 27 08:53:47 hp850 kernel: audit: type=1130 audit(1632725627.633:22): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:47 hp850 kernel: [drm] PCIE GART of 2048M enabled (table at 0x00000000001D6000).
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: WB enabled
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 1 use gpu addr 0x0000000040000c04
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 2 use gpu addr 0x0000000040000c08
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 4 use gpu addr 0x0000000040000c10
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Sep 27 08:53:47 hp850 kernel: input: PS/2 Generic Mouse as /devices/platform/i8042/serio2/input/input11
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: failed VCE resume (-110).
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: radeon: MSI limited to 32-bit
Sep 27 08:53:47 hp850 kernel: radeon 0000:03:00.0: radeon: using MSI.
Sep 27 08:53:47 hp850 kernel: [drm] radeon: irq initialized.
Sep 27 08:53:47 hp850 kernel: iwlwifi 0000:02:00.0 wlo1: renamed from wlan0
Sep 27 08:53:47 hp850 kernel: input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input26
Sep 27 08:53:48 hp850 kernel: mousedev: PS/2 mouse device common for all mice
Sep 27 08:53:48 hp850 kernel: intel_rapl_common: Found RAPL domain package
Sep 27 08:53:48 hp850 kernel: intel_rapl_common: Found RAPL domain core
Sep 27 08:53:48 hp850 kernel: intel_rapl_common: Found RAPL domain uncore
Sep 27 08:53:48 hp850 kernel: intel_rapl_common: Found RAPL domain dram
Sep 27 08:53:48 hp850 kernel: NET: Registered protocol family 42
Sep 27 08:53:48 hp850 kernel: input: Telink Wireless Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3.3/2-3.3:1.0/0003:248A:8514.0001/input/input27
Sep 27 08:53:48 hp850 kernel: input: Telink Wireless Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3.3/2-3.3:1.0/0003:248A:8514.0001/input/input28
Sep 27 08:53:48 hp850 kernel: input: Telink Wireless Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3.3/2-3.3:1.0/0003:248A:8514.0001/input/input29
Sep 27 08:53:48 hp850 kernel: hid-generic 0003:248A:8514.0001: input,hidraw0: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:00:14.0-3.3/input0
Sep 27 08:53:48 hp850 kernel: input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3.3/2-3.3:1.1/0003:248A:8514.0002/input/input30
Sep 27 08:53:48 hp850 kernel: fbcon: Taking over console
Sep 27 08:53:48 hp850 kernel: hid-generic 0003:248A:8514.0002: input,hidraw1: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:00:14.0-3.3/input1
Sep 27 08:53:48 hp850 kernel: usbcore: registered new interface driver usbhid
Sep 27 08:53:48 hp850 kernel: usbhid: USB HID core driver
Sep 27 08:53:48 hp850 kernel: psmouse serio3: synaptics: queried max coordinates: x [..5660], y [..4700]
Sep 27 08:53:48 hp850 kernel: uvcvideo: Found UVC 1.00 device HP HD Webcam (05c8:0369)
Sep 27 08:53:48 hp850 kernel: psmouse serio3: synaptics: queried min coordinates: x [1366..], y [1236..]
Sep 27 08:53:48 hp850 kernel: psmouse serio3: synaptics: Your touchpad (PNP: SYN3003 SYN0100 SYN0002 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
Sep 27 08:53:48 hp850 kernel: input: HP HD Webcam: HP HD Webcam as /devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/input/input31
Sep 27 08:53:48 hp850 kernel: usbcore: registered new interface driver uvcvideo
Sep 27 08:53:48 hp850 kernel: USB Video Class driver (1.1.1)
Sep 27 08:53:48 hp850 kernel: psmouse serio3: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd00123/0x840300/0x26800/0x0, board id: 2769, fw id: 1673117
Sep 27 08:53:48 hp850 kernel: Console: switching to colour frame buffer device 240x67
Sep 27 08:53:48 hp850 kernel: input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio3/input/input25
Sep 27 08:53:48 hp850 kernel: Bluetooth: Core ver 2.22
Sep 27 08:53:48 hp850 kernel: NET: Registered protocol family 31
Sep 27 08:53:48 hp850 kernel: Bluetooth: HCI device and connection manager initialized
Sep 27 08:53:48 hp850 kernel: Bluetooth: HCI socket layer initialized
Sep 27 08:53:48 hp850 kernel: Bluetooth: L2CAP socket layer initialized
Sep 27 08:53:48 hp850 kernel: Bluetooth: SCO socket layer initialized
Sep 27 08:53:48 hp850 kernel: usbcore: registered new interface driver btusb
Sep 27 08:53:48 hp850 kernel: Bluetooth: hci0: read Intel version: 370710018002030d00
Sep 27 08:53:48 hp850 kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq
Sep 27 08:53:48 hp850 kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Sep 27 08:53:48 hp850 kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Sep 27 08:53:48 hp850 kernel: Bluetooth: BNEP filters: protocol multicast
Sep 27 08:53:48 hp850 kernel: Bluetooth: BNEP socket layer initialized
Sep 27 08:53:48 hp850 kernel: [drm] ring test on 0 succeeded in 1 usecs
Sep 27 08:53:48 hp850 kernel: [drm] ring test on 1 succeeded in 1 usecs
Sep 27 08:53:48 hp850 kernel: [drm] ring test on 2 succeeded in 1 usecs
Sep 27 08:53:48 hp850 kernel: [drm] ring test on 3 succeeded in 5 usecs
Sep 27 08:53:48 hp850 kernel: [drm] ring test on 4 succeeded in 4 usecs
Sep 27 08:53:49 hp850 kernel: Bluetooth: hci0: Intel BT fw patch 0x57 completed & activated
Sep 27 08:53:49 hp850 kernel: NET: Registered protocol family 38
Sep 27 08:53:49 hp850 kernel: [drm] ring test on 5 succeeded in 2 usecs
Sep 27 08:53:49 hp850 kernel: [drm] UVD initialized successfully.
Sep 27 08:53:49 hp850 kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Sep 27 08:53:49 hp850 kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Sep 27 08:53:49 hp850 kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Sep 27 08:53:49 hp850 kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Sep 27 08:53:49 hp850 kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Sep 27 08:53:49 hp850 kernel: [drm] ib test on ring 5 succeeded
Sep 27 08:53:49 hp850 kernel: [drm] Radeon Display Connectors
Sep 27 08:53:49 hp850 kernel: [drm] Connector 0:
Sep 27 08:53:49 hp850 kernel: [drm] DP-3
Sep 27 08:53:49 hp850 kernel: [drm] HPD1
Sep 27 08:53:49 hp850 kernel: [drm] DDC: 0x6530 0x6530 0x6534 0x6534 0x6538 0x6538 0x653c 0x653c
Sep 27 08:53:49 hp850 kernel: [drm] Encoders:
Sep 27 08:53:49 hp850 kernel: [drm] DFP1: INTERNAL_UNIPHY
Sep 27 08:53:49 hp850 kernel: [drm] Connector 1:
Sep 27 08:53:49 hp850 kernel: [drm] DP-4
Sep 27 08:53:49 hp850 kernel: [drm] HPD2
Sep 27 08:53:49 hp850 kernel: [drm] DDC: 0x6540 0x6540 0x6544 0x6544 0x6548 0x6548 0x654c 0x654c
Sep 27 08:53:49 hp850 kernel: [drm] DFP2: INTERNAL_UNIPHY
Sep 27 08:53:49 hp850 kernel: radeon 0000:03:00.0: [drm] Cannot find any crtc or sizes
Sep 27 08:53:49 hp850 kernel: [drm] Initialized radeon 2.50.0 20080528 for 0000:03:00.0 on minor 1
Sep 27 08:53:50 hp850 kernel: [drm] amdgpu kernel modesetting enabled.
Sep 27 08:53:50 hp850 kernel: vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
Sep 27 08:53:50 hp850 kernel: ATPX version 1, functions 0x00000003
Sep 27 08:53:50 hp850 kernel: CRAT table not found
Sep 27 08:53:50 hp850 kernel: Virtual CRAT table created for CPU
Sep 27 08:53:50 hp850 kernel: amdgpu: Topology: Add CPU node
Sep 27 08:53:51 hp850 kernel: radeon 0000:03:00.0: [drm] Cannot find any crtc or sizes
Sep 27 08:53:52 hp850 kernel: kauditd_printk_skb: 53 callbacks suppressed
Sep 27 08:53:52 hp850 kernel: audit: type=1103 audit(1632725632.703:76): pid=3365 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=hp850 addr=? terminal=/dev/tty1 res=success'
Sep 27 08:53:52 hp850 kernel: audit: type=1006 audit(1632725632.703:77): pid=3365 uid=0 old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=2 res=1
Sep 27 08:53:52 hp850 kernel: audit: type=1131 audit(1632725632.716:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:52 hp850 kernel: audit: type=1130 audit(1632725632.733:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:53:52 hp850 kernel: audit: type=1101 audit(1632725632.783:80): pid=3445 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Sep 27 08:53:52 hp850 kernel: audit: type=1130 audit(1632725632.783:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Sep 27 08:53:52 hp850 kernel: audit: type=1105 audit(1632725632.790:82): pid=3365 uid=0 auid=120 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=hp850 addr=? terminal=/dev/tty1 res=success'
Sep 27 08:53:53 hp850 kernel: audit: type=1334 audit(1632725633.626:83): prog-id=19 op=LOAD
Sep 27 08:53:53 hp850 kernel: audit: type=1334 audit(1632725633.626:84): prog-id=20 op=LOAD
Sep 27 08:53:53 hp850 kernel: audit: type=1334 audit(1632725633.626:85): prog-id=21 op=LOAD
Sep 27 08:53:53 hp850 kernel: rfkill: input handler disabled
Sep 27 08:53:55 hp850 kernel: wlo1: authenticate with 04:d4:c4:c0:1e:7c
Sep 27 08:53:55 hp850 kernel: wlo1: send auth to 04:d4:c4:c0:1e:7c (try 1/3)
Sep 27 08:53:55 hp850 kernel: wlo1: authenticated
Sep 27 08:53:55 hp850 kernel: wlo1: associate with 04:d4:c4:c0:1e:7c (try 1/3)
Sep 27 08:53:55 hp850 kernel: wlo1: RX AssocResp from 04:d4:c4:c0:1e:7c (capab=0x1011 status=0 aid=5)
Sep 27 08:53:55 hp850 kernel: wlo1: associated
Sep 27 08:53:55 hp850 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
Sep 27 08:53:55 hp850 kernel: wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by 04:d4:c4:c0:1e:7c
Sep 27 08:53:58 hp850 kernel: kauditd_printk_skb: 5 callbacks suppressed
Sep 27 08:53:58 hp850 kernel: audit: type=1131 audit(1632725638.353:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:54:23 hp850 kernel: audit: type=1130 audit(1632725663.833:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:54:23 hp850 kernel: audit: type=1131 audit(1632725663.833:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:54:23 hp850 kernel: audit: type=1131 audit(1632725663.836:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:54:23 hp850 kernel: audit: type=1131 audit(1632725663.950:95): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:54:23 hp850 kernel: audit: type=1334 audit(1632725663.953:96): prog-id=21 op=UNLOAD
Sep 27 08:54:23 hp850 kernel: audit: type=1334 audit(1632725663.953:97): prog-id=20 op=UNLOAD
Sep 27 08:54:23 hp850 kernel: audit: type=1334 audit(1632725663.953:98): prog-id=19 op=UNLOAD
Sep 27 08:54:24 hp850 kernel: audit: type=1334 audit(1632725664.070:99): prog-id=15 op=UNLOAD
Sep 27 08:54:24 hp850 kernel: audit: type=1334 audit(1632725664.070:100): prog-id=14 op=UNLOAD
Sep 27 08:54:24 hp850 kernel: audit: type=1334 audit(1632725664.070:101): prog-id=13 op=UNLOAD
Sep 27 08:57:07 hp850 kernel: [drm] PCIE gen 2 link speeds already enabled
Sep 27 08:57:07 hp850 kernel: [drm] PCIE GART of 2048M enabled (table at 0x00000000001D6000).
Sep 27 08:57:07 hp850 kernel: radeon 0000:03:00.0: WB enabled
Sep 27 08:57:07 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00
Sep 27 08:57:07 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 1 use gpu addr 0x0000000040000c04
Sep 27 08:57:07 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 2 use gpu addr 0x0000000040000c08
Sep 27 08:57:07 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c
Sep 27 08:57:07 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 4 use gpu addr 0x0000000040000c10
Sep 27 08:57:07 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Sep 27 08:57:07 hp850 kernel: radeon 0000:03:00.0: failed VCE resume (-110).
Sep 27 08:57:07 hp850 kernel: [drm] ring test on 0 succeeded in 2 usecs
Sep 27 08:57:07 hp850 kernel: [drm] ring test on 1 succeeded in 1 usecs
Sep 27 08:57:07 hp850 kernel: [drm] ring test on 2 succeeded in 1 usecs
Sep 27 08:57:07 hp850 kernel: [drm] ring test on 3 succeeded in 5 usecs
Sep 27 08:57:07 hp850 kernel: [drm] ring test on 4 succeeded in 5 usecs
Sep 27 08:57:08 hp850 kernel: [drm] ring test on 5 succeeded in 2 usecs
Sep 27 08:57:08 hp850 kernel: [drm] UVD initialized successfully.
Sep 27 08:57:08 hp850 kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Sep 27 08:57:08 hp850 kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Sep 27 08:57:08 hp850 kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Sep 27 08:57:08 hp850 kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Sep 27 08:57:08 hp850 kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Sep 27 08:57:08 hp850 kernel: [drm] ib test on ring 5 succeeded
Sep 27 08:57:08 hp850 kernel: rfkill: input handler enabled
Sep 27 08:57:08 hp850 kernel: audit: type=1130 audit(1632725828.840:102): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:57:14 hp850 kernel: audit: type=1100 audit(1632725834.483:103): pid=31271 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="claus" exe="/usr/bin/login" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 08:57:14 hp850 kernel: audit: type=1101 audit(1632725834.483:104): pid=31271 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="claus" exe="/usr/bin/login" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 08:57:14 hp850 kernel: audit: type=1103 audit(1632725834.483:105): pid=31271 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="claus" exe="/usr/bin/login" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 08:57:14 hp850 kernel: audit: type=1006 audit(1632725834.483:106): pid=31271 uid=0 old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=3 res=1
Sep 27 08:57:14 hp850 kernel: audit: type=1130 audit(1632725834.506:107): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:57:14 hp850 kernel: audit: type=1101 audit(1632725834.513:108): pid=31273 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="claus" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:57:14 hp850 kernel: audit: type=1103 audit(1632725834.513:109): pid=31273 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="claus" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Sep 27 08:57:14 hp850 kernel: audit: type=1006 audit(1632725834.513:110): pid=31273 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=4 res=1
Sep 27 08:57:14 hp850 kernel: audit: type=1105 audit(1632725834.513:111): pid=31273 uid=0 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="claus" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 08:57:14 hp850 kernel: audit: type=1334 audit(1632725834.520:112): prog-id=24 op=LOAD
Sep 27 09:05:09 hp850 kernel: kauditd_printk_skb: 4 callbacks suppressed
Sep 27 09:05:09 hp850 kernel: audit: type=1100 audit(1632726309.160:117): pid=87398 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_unix acct="claus" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:05:09 hp850 kernel: audit: type=1101 audit(1632726309.160:118): pid=87398 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="claus" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:05:09 hp850 kernel: audit: type=1110 audit(1632726309.163:119): pid=87398 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:05:09 hp850 kernel: audit: type=1105 audit(1632726309.163:120): pid=87398 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:05:09 hp850 kernel: audit: type=1106 audit(1632726309.166:121): pid=87398 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:05:09 hp850 kernel: audit: type=1104 audit(1632726309.166:122): pid=87398 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:05:32 hp850 kernel: audit: type=1100 audit(1632726332.156:123): pid=89841 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=? acct="root" exe="/usr/bin/su" hostname=hp850 addr=? terminal=/dev/tty2 res=failed'
Sep 27 09:05:52 hp850 kernel: audit: type=1101 audit(1632726352.836:124): pid=92285 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="claus" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:06:14 hp850 kernel: audit: type=1101 audit(1632726374.056:125): pid=94738 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="claus" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:06:14 hp850 kernel: audit: type=1110 audit(1632726374.056:126): pid=94738 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_env,pam_unix acct="root" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:06:14 hp850 kernel: audit: type=1105 audit(1632726374.056:127): pid=94738 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:08:48 hp850 kernel: audit: type=1130 audit(1632726528.350:128): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:08:48 hp850 kernel: audit: type=1131 audit(1632726528.350:129): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:11:51 hp850 kernel: audit: type=1334 audit(1632726711.150:130): prog-id=25 op=LOAD
Sep 27 09:11:51 hp850 kernel: audit: type=1334 audit(1632726711.150:131): prog-id=26 op=LOAD
Sep 27 09:11:51 hp850 kernel: audit: type=1334 audit(1632726711.150:132): prog-id=27 op=LOAD
Sep 27 09:11:51 hp850 kernel: audit: type=1130 audit(1632726711.220:133): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:12:21 hp850 kernel: audit: type=1131 audit(1632726741.253:134): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:12:21 hp850 kernel: audit: type=1334 audit(1632726741.393:135): prog-id=27 op=UNLOAD
Sep 27 09:12:21 hp850 kernel: audit: type=1334 audit(1632726741.393:136): prog-id=26 op=UNLOAD
Sep 27 09:12:21 hp850 kernel: audit: type=1334 audit(1632726741.393:137): prog-id=25 op=UNLOAD
Sep 27 09:13:27 hp850 kernel: audit: type=1104 audit(1632726807.613:138): pid=31271 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="claus" exe="/usr/bin/login" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:13:27 hp850 kernel: audit: type=1106 audit(1632726807.620:139): pid=31271 uid=0 auid=1000 ses=3 msg='op=PAM:session_close grantors=? acct="claus" exe="/usr/bin/login" hostname=hp850 addr=? terminal=/dev/tty2 res=failed'
Sep 27 09:13:27 hp850 kernel: audit: type=1106 audit(1632726807.623:140): pid=94738 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:13:27 hp850 kernel: audit: type=1104 audit(1632726807.623:141): pid=94738 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_env,pam_unix acct="root" exe="/usr/bin/sudo" hostname=hp850 addr=? terminal=/dev/tty2 res=success'
Sep 27 09:13:27 hp850 kernel: audit: type=1131 audit(1632726807.650:142): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:13:27 hp850 kernel: audit: type=1131 audit(1632726807.650:143): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:13:27 hp850 kernel: audit: type=1131 audit(1632726807.653:144): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:13:27 hp850 kernel: audit: type=1131 audit(1632726807.653:145): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:13:27 hp850 kernel: audit: type=1131 audit(1632726807.653:146): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:13:27 hp850 kernel: audit: type=1131 audit(1632726807.656:147): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 27 09:13:28 hp850 kernel: [drm] PCIE gen 2 link speeds already enabled
Sep 27 09:13:28 hp850 kernel: [drm] PCIE GART of 2048M enabled (table at 0x00000000001D6000).
Sep 27 09:13:28 hp850 kernel: radeon 0000:03:00.0: WB enabled
Sep 27 09:13:28 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00
Sep 27 09:13:28 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 1 use gpu addr 0x0000000040000c04
Sep 27 09:13:28 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 2 use gpu addr 0x0000000040000c08
Sep 27 09:13:28 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c
Sep 27 09:13:28 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 4 use gpu addr 0x0000000040000c10
Sep 27 09:13:28 hp850 kernel: radeon 0000:03:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Sep 27 09:13:28 hp850 kernel: radeon 0000:03:00.0: failed VCE resume (-110).
Sep 27 09:13:29 hp850 kernel: [drm] ring test on 0 succeeded in 1 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ring test on 1 succeeded in 1 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ring test on 2 succeeded in 1 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ring test on 3 succeeded in 5 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ring test on 4 succeeded in 4 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ring test on 5 succeeded in 2 usecs
Sep 27 09:13:29 hp850 kernel: [drm] UVD initialized successfully.
Sep 27 09:13:29 hp850 kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Sep 27 09:13:29 hp850 kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Sep 27 09:13:30 hp850 kernel: [drm] ib test on ring 5 succeeded
Sep 27 09:13:30 hp850 kernel: wlo1: deauthenticating from 04:d4:c4:c0:1e:7c by local choice (Reason: 3=DEAUTH_LEAVING)
Sep 27 09:13:32 hp850 systemd-shutdown[1]: Syncing filesystems and block devices.
Sep 27 09:13:32 hp850 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
