You are not really giving any info on what you have installed there. WIFI
should work out of the box if you installed an image with a DE.
Sometimes people have to install crda and set their country code. Sometimes people have to change the WIFI channel in their router.
If you installed a minimal image then I am not sure what all needs done as I never use a minimal image. It may need some manual configs to get wifi going.
I just can’t remember what I did. I didn’t mess with the wifi at any point before that, and didn’t try plugging in any USB network adapters before that, either.
Best guess: when I disabled bluetooth I took the wifi interface out with it without realizing it. I haven’t disabled bluetooth on this reinstall, yet.
So, um. Don’t do that thing I did that I don’t know what I did.
I do not mess with it in config.txt. If the attach-bluetooth is not disabled it can causes network issues and cpu usage trying to connect. I basically cut the head off the snake.
