Hello all,
after updating Kernel from 5.13 to 5.15 (via pacman, System Kernel Modul would not fetch from Mirrors dunno) I had Wifi AND Bluetooth working (did not on previous Kernel) which was nice. But now after rebooting there are no Wifi Networks shown and Bluetooth not working.
Tried to google parts and to reinstall network driver in Manjaro HarwareCenter, rebooting couple times nothing seems to work.
neofetch ✔
██████████████████ ████████ jfffs@jon-fa506QR
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: ASUS TUF Gaming A15 FA506QR_FA506QR 1.
████████ ████████ Kernel: 5.15.2-2-MANJARO
████████ ████████ ████████ Uptime: 32 mins
████████ ████████ ████████ Packages: 1414 (pacman)
████████ ████████ ████████ Shell: bash 5.1.8
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: Plasma 5.23.3
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ Theme: Breath2 2021 Dark [Plasma], Breeze [G
████████ ████████ ████████ Icons: We10X [Plasma], We10X [GTK2/3]
████████ ████████ ████████ Terminal: konsole
CPU: AMD Ryzen 7 5800H with Radeon Graphics
GPU: NVIDIA GeForce RTX 3070 Mobile / Max-Q
GPU: AMD ATI 06:00.0 Cezanne
Memory: 3063MiB / 15463MiB
systemctl status NetworkManager ✔ 7s
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
└─NetworkManager-ovs.conf
Active: active (running) since Wed 2021-11-24 01:58:13 CET; 8s ago
Docs: man:NetworkManager(8)
Main PID: 3554 (NetworkManager)
Tasks: 4 (limit: 18460)
Memory: 3.4M
CPU: 78ms
CGroup: /system.slice/NetworkManager.service
└─3554 /usr/bin/NetworkManager --no-daemon
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7322] device (enp6s0f3u1u3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7363] ovsdb: Verbindung ist gescheitert: Datei oder Verzeichnis nicht gefunden
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7364] ovsdb: disconnected from ovsdb
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7372] modem-manager: ModemManager available
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7388] agent-manager: agent[7827738f1884ab2b,:1.19/org.kde.plasma.networkmanagement/1000]: agent registered
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7508] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=2574 uid=1000 result="success"
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7573] audit: op="statistics" interface="enp6s0f3u1u3" ifindex=3 args="500" pid=2574 uid=1000 result="success"
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7598] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=2574 uid=1000 result="success"
Nov 24 01:58:13 jon-fa506QR NetworkManager[3554]: <info> [1637715493.7622] audit: op="statistics" interface="enp2s0" ifindex=2 args="500" pid=2574 uid=1000 result="success"
Nov 24 01:58:19 jon-fa506QR NetworkManager[3554]: <info> [1637715499.7336] manager: startup complete
journalctl -b -p err ✔
-- Journal begins at Fri 2021-10-22 17:53:58 CEST, ends at Wed 2021-11-24 02:14:53 CET. --
Nov 24 01:48:18 jon-fa506QR kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.THRM._SCP.CTYP], AE_NOT_FOUND (20210730/psargs-330)
Nov 24 01:48:18 jon-fa506QR kernel: ACPI Error: Aborting method \_TZ.THRM._SCP due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 24 01:48:18 jon-fa506QR kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Nov 24 01:48:18 jon-fa506QR kernel: mt7921e 0000:03:00.0: ASIC revision: 79610010
Nov 24 01:48:19 jon-fa506QR kernel: Bluetooth: hci0: Wrong op received 6 expected 1
Nov 24 01:48:19 jon-fa506QR kernel: Bluetooth: hci0: Failed to send wmt patch dwnld (-5)
Nov 24 01:48:19 jon-fa506QR kernel: Bluetooth: hci0: Wrong op received 1 expected 6
Nov 24 01:48:19 jon-fa506QR kernel: Bluetooth: hci0: Failed to send wmt func ctrl (-5)
Nov 24 01:48:21 jon-fa506QR systemd-cryptsetup[418]: Failed to activate with specified passphrase. (Passphrase incorrect?)
Nov 24 01:48:21 jon-fa506QR systemd-backlight[1130]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
Nov 24 01:48:21 jon-fa506QR systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
Nov 24 01:49:20 jon-fa506QR kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
Nov 24 01:50:09 jon-fa506QR acvpnagent[1410]: Function: processOnLoadPreferencesComplete File: ../../vpn/Agent/MainThread.cpp Line: 7358 Invoked Function: CLoginUtilsMgr::SetAnyConnectLaunchAtLogin Return Code: -28180479 (0xFE520001) D>
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: getConfigurationFileContents File: ../../vpn/Common/Logging/AppLogCustomConfig.cpp Line: 216 The configuration file for customizing debug logs doesn't exist or is not readable.
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: loadConfigurationFromFile File: ../../vpn/Common/Logging/AppLogCustomConfig.cpp Line: 284 Invoked Function: CAppLogCustomConfig::getConfigurationFileContents Return Code: -1893989>
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: initConfigurationMap File: ../../vpn/Common/Logging/AppLogCustomConfig.cpp Line: 76 Invoked Function: CAppLogCustomConfig::loadConfigurationFromFile Return Code: -18939894 (0xFEDF>
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: getTargetPath File: ../../vpn/Common/Utility/DeviceID.cpp Line: 616 /dev/nvme0n1p5 is not a link
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: getProfilePath File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 576 Invoked Function: getpwnam Return Code: -31457275 (0xFE200005) Description: CERTSTORE_ERROR_NULL>
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 400 Invoked Function: CNSSCertUtils::getProfilePath Return Code: -31457275 (0xFE200005) Description: CERTST>
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 76 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457275 (0xFE200005) Description: CERTSTOR>
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1887 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457275 (0xFE200005) Descript>
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: verify_callback File: ../../vpn/CommonCrypt/Certificates/FileCertificate.cpp Line: 417 Invoked Function: X509_verify_cert Return Code: 0 (0x00000000) Description: ok
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: startParser File: ../../vpn/Common/Xml/CVCSaxParser.cpp Line: 171 Invoked Function: xmlCreateFileParserCtxt Return Code: -33554427 (0xFE000005) Description: GLOBAL_ERROR_NULL_POIN>
Nov 24 01:50:10 jon-fa506QR acvpnagent[1410]: Function: LoadSettingsFromXmlFile File: ../../vpn/PhoneHome/PhoneHomeAgent.cpp Line: 627 Invoked Function: XmlParser::parseFile Return Code: -33554423 (0xFE000009) Description: GLOBAL_ERROR>
Nov 24 01:55:10 jon-fa506QR acvpnagent[1410]: Function: GetSettings File: ../../vpn/Agent/ServicePluginMgr.cpp Line: 289 m_pIServicePlugin is NULL
Nov 24 02:03:11 jon-fa506QR systemd-coredump[4077]: [🡕] Process 2547 (plasmashell) of user 1000 dumped core.
Found module linux-vdso.so.1 with build-id: 24435ce20302d79e701201bfbe1d78550cf2b415
Found module KF5IdleTimeXcbPlugin0.so with build-id: 2401509a6cad3ed8ba465434d50a398f5dd95008
Found module libdatrie.so.1 with build-id: 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Found module libthai.so.0 with build-id: 3fdce1a7db2b94d9168eea540dbf5ff5caa3b8ad
Found module libfribidi.so.0 with build-id: 79124bad061c2aab4ec89f25d067363d5b781114
Found module libpixman-1.so.0 with build-id: 341f793dcada3a48a306a793d265a517e3f2e7d6
Found module libpangoft2-1.0.so.0 with build-id: 52a846673f7bf9e8acdd0ae9a825926c9cfc5920
Found module libpango-1.0.so.0 with build-id: 5deae7c16592ea404754114e8ae56ddf9cf4ca7e
Found module libcairo.so.2 with build-id: 06820af9cf79c2deb207d9533a61caf04e67a8ad
Found module libpangocairo-1.0.so.0 with build-id: 2554be0474a6ee311b6e9aa4fd79a244167cdcfd
Found module libgdk_pixbuf-2.0.so.0 with build-id: ca4beb15a30de8d8767f7bca8222038c61b58b36
Found module libcairo-gobject.so.2 with build-id: abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
Found module librsvg-2.so.2 with build-id: 386351f79d7a10d84fa858631fc4b92d1cbd24f2
Found module krunner_placesrunner.so with build-id: 789be6bd3af421c111b392fa5da89c964733c220
Found module krunner_recentdocuments.so with build-id: ce3d035af3eb7dd796a35765995ba4befe2d8cde
Found module krunner_kwin.so with build-id: d3efd2976239864d6728c81e4c2852e0888d8e76
