I installed Manjaro for the first time today and for some reason, I cannot connect to any wifi. I’ve searched the internet for solutions but nothing works. Does anyone have any solution to this bug? I’ve tried changing the blacklists, restarting the network manager, i tried removing systemd from passwd and group in nsswitch.conf. After all this still nothing works, solutions that has worked for other people is to no avail.
Please give me some guidance on how to get it to work, thanks.
Can you post the output of
inxi -Fza
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=073546e6-520d-4fab-9f3a-5c16624a5720 ro quiet apparmor=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Laptop 14s-fq0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 87B6 v: 28.15 serial: <filter> UEFI: AMI v: F.15
date: 07/22/2020
ID-1: BAT0 charge: 40.6 Wh condition: 41.0/41.0 Wh (100%)
volts: 12.6/11.3 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: Discharging cycles: 369
Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
socket: FP5 bits: 64 type: MT MCP arch: Zen/Zen+ note: check
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109
L1 cache: 384 KiB L2 cache: 2 MiB L3 cache: 3.9 MiB
bogomips: 33548
Speed: 1222 MHz min/max: 1400/2100 MHz base/boost: 2100/3700
boost: enabled volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz):
1: 1222 2: 1222 3: 1222 4: 1222 5: 1222 6: 1222 7: 1316 8: 1395
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
STIBP: disabled, RSB filling
Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 04:00.0 chip ID: 1002:15d8
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus ID: 3-1.2:3 chip ID: 0408:5365
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158
size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.39.0
5.9.16-1-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.3.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 04:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 04:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A modules: rtw88_8821ce port: f000
bus ID: 02:00.0 chip ID: 10ec:c821
Local Storage: total: 238.47 GiB used: 7.42 GiB (3.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNV256G KIOXIA size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: HP00AE00 temp: 25.9 C
SMART: yes health: PASSED on: 61 hrs cycles: 2
read-units: 1,009,679 [516 GB] written-units: 1,162,130 [595 GB]
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 7.42 GiB (3.2%) fs: ext4 block size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
System Temperatures: cpu: 35.6 C mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 298 Uptime: 43m wakeups: 5 Memory: 5.74 GiB
used: 1.98 GiB (34.5%) Init: systemd v: 247 Compilers: gcc: N/A
Packages: pacman: 1222 lib: 373 flatpak: 0 Shell: Bash v: 5.1.0
running in: konsole inxi: 3.2.01
Wollie
26 January 2021 20:50
4
How do i install the driver if i have no internet? Can you give me some insight?
Wollie
26 January 2021 20:53
6
Bluetooth tethering possible? LAN?
I don’t have any clue what so ever on where to find compitable drivers for linux actually. I’ve never had to manually install drivers on a linux distro before so i’m a bit lost.
Wollie
26 January 2021 20:57
8
Why don’t you click the link I provided, then?
Why don’t you click it yourself and see there are no discussions about how to install drivers for it?
Wollie
26 January 2021 21:01
10
Long time that I’ve seen such an ignorant answer. There are descriptions how to install drivers. You not even clicked it, what do you expect here, giving you every single command at hand?
I didn’t find your answer to nice either, why don’t just give me help intead of linking me a forum search with no threads about installing the relevant driver. You’re obviously the more experienced person of us. I guess i’ll go find help somewhere else then.
