MSco
May 26, 2023, 6:03am
1
My Wi-Fi device cannot be found since one of the last system updates. I tried the following:
nmcli dev wifi rescan:
Error: No Wi-Fi device found.
nmcli con show:
Kabelgebundene Verbindung <some-uuid> ethernet enp59s0u2u4
lo <some-uuid> loopback lo
FRITZ!Box <some-uuid> wifi --
WORK-L2TP <some-uuid> vpn --
Fritzbox-VPN <some-uuid> vpn --
eduroam <wifi-uuid> wifi --
nmcli connection up <wifi-uuid>
Error: Connection activation failed: No suitable device found for this connection (device lo not available because profile is not compatible with device (connection type is not "loopback")).
My system:
Linux Kernel: 5.15.112-1-MANJARO
KDE-Plasma: 5.27.4
Are you sure you’re copying the correct UUID?
Is your device plugged in? Had you ever have to install custom drivers?
MSco
May 26, 2023, 6:59am
3
Yes, i copied the uuid of eduroam, which is my wifi network. I tried it again after your post and it is the same error message.
I have a notebook, so there is no external wifi device to be plugged in. Wifi is built-in. I never installed any custom drivers for my wifi.
hardly any info that can tell anything;
need atleast info from;
inxi -Fazy
lspci -k
MSco
May 26, 2023, 7:09am
5
inxi -Fazy
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "de:en_US",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_TIME = "de_DE.UTF-8",
LANG = "CC"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.15.112-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=9e724a40-8c4b-422e-b365-efcba6835b8d rw apparmor=1
security=apparmor resume=UUID=d361c180-0d72-4fd9-b546-d112a614ff38
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude 7530 v: N/A
Mobo: Dell model: 0NMM73 v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.1 date: 05/13/2022
ID-1: BAT0 charge: 58.2 Wh (100.0%) condition: 58.2/58.0 Wh (100.3%)
volts: 16.6 min: 15.2 model: BYD DELL H4PVC22 type: Li-poly serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
status: discharging
Info: model: 12th Gen Intel Core i7-1265U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x429
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 728 high: 1142 min/max: 400/4800:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 732 2: 679 3: 776 4: 751
5: 817 6: 881 7: 1142 8: 851 9: 550 10: 473 11: 545 12: 544 bogomips: 64536
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: DP-4,DP-5 off: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:46a8 class-ID: 0300
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.3.3.2:9
chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1014x317mm (39.92x12.48")
s-diag: 1062mm (41.83")
Monitor-1: not-matched mapped: DP-1-2 pos: left res: 1920x1200 hz: 60
dpi: 94 size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-2: not-matched mapped: DP-1-3 pos: primary,right res: 1920x1200
hz: 60 dpi: 94 size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-3: eDP-1 note: disabled model: AU Optronics 0x1f92 built: 2020
res: 1920x1200 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-3: Generalplus USB Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-2.3.3.3:11 chip-ID: 1b3f:2008 class-ID: 0300
API: ALSA v: k5.15.112-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: N/A modules: iwlwifi
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-2.4:4
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp59s0u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 235.54 GiB (24.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: CA6-8D1024-Q11 NVMe SSSTC 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 24201113 temp: 46.9 C
scheme: GPT
ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 52.83 GiB (27.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 364 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-1: swap-1 type: partition size: 33.88 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 298 Uptime: 1h 16m wakeups: 5 Memory: available: 30.8 GiB
used: 4.44 GiB (14.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: dpkg
pkgs: 0 pm: pacman pkgs: 1549 libs: 401 tools: pamac pm: rpm pkgs: 0
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
lspci -k
0000:00:00.0 Host bridge: Intel Corporation Device 4601 (rev 04)
Subsystem: Dell Device 0b0d
Kernel driver in use: igen6_edac
Kernel modules: igen6_edac
0000:00:02.0 VGA compatible controller: Intel Corporation Alder Lake-UP3 GT2 [Iris Xe Graphics] (rev 0c)
Kernel driver in use: i915
Kernel modules: i915
0000:00:04.0 Signal processing controller: Intel Corporation Alder Lake Innovation Platform Framework Processor Participant (rev 04)
Kernel driver in use: proc_thermal_pci
Kernel modules: processor_thermal_device_pci
0000:00:06.0 System peripheral: Intel Corporation RST VMD Managed Controller
0000:00:07.0 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 04)
Kernel driver in use: pcieport
0000:00:07.1 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #1 (rev 04)
0000:00:08.0 System peripheral: Intel Corporation 12th Gen Core Processor Gaussian & Neural Accelerator (rev 04)
0000:00:0d.0 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 USB Controller (rev 04)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
0000:00:0d.2 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #0 (rev 04)
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
0000:00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller
Kernel driver in use: vmd
Kernel modules: vmd
0000:00:12.0 Serial controller: Intel Corporation Alder Lake-P Integrated Sensor Hub (rev 01)
Kernel driver in use: intel_ish_ipc
Kernel modules: intel_ish_ipc
0000:00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
0000:00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
0000:00:14.3 Network controller: Intel Corporation Alder Lake-P PCH CNVi WiFi (rev 01)
Subsystem: Intel Corporation Wi-Fi 6E AX211 160MHz
Kernel modules: iwlwifi
0000:00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
0000:00:15.1 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 (rev 01)
0000:00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
Kernel driver in use: mei_me
Kernel modules: mei_me
0000:00:1f.0 ISA bridge: Intel Corporation Alder Lake PCH eSPI Controller (rev 01)
0000:00:1f.3 Audio device: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
0000:00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
0000:00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
Kernel driver in use: intel-spi
Kernel modules: intel_spi_pci
0000:39:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
Subsystem: Intel Corporation Device 0000
0000:3a:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
0000:3a:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
0000:3b:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge DD 2018] (rev 06)
10000:e0:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 04)
10000:e1:00.0 Non-Volatile memory controller: Solid State Storage Technology Corporation Device 1001 (rev 01)
Subsystem: INNOGRIT Corporation Device 5236
Kernel driver in use: nvme
MSco:
8086:51f0
Try kernel 6.2 or 6.3 and see how it goes. The driver should be included in the kernel. I had a hard time with this (new) computer with an Intel AX200. I tried modprobe and other fixes, nothing worked. I grabbbed the driver direct from Intel (the 46 driver) and placed in /lib/firmware and it magically worked the next morning and ever since although it now loads a more recent driver. Strange.
sudo journalctl -k | grep iwlwifi
May 26 05:57:31 Beelink kernel: iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
May 26 05:57:31 Beelink kernel: iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
May 26 05:57:31 Beelink kernel: iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
May 26 05:57:31 Beelink kernel: iwlwifi 0000:02:00.0: loaded firmware version 74.a5e9588b.0 cc-a0-74.ucode op_mode iwlmvm
May 26 05:57:32 Beelink kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
May 26 05:57:32 Beelink kernel: iwlwifi 0000:02:00.0: Detected RF HR B3, rfid=0x10a100
May 26 05:57:32 Beelink kernel: iwlwifi 0000:02:00.0: base HW address: xx:xx:xx:xx:xx:xx
It now loads the “74” driver for some reason even though “77” is present in the folder.
What nmcli device status
and rfkill list
show?
MSco
May 30, 2023, 5:19am
9
I installed kernel 6.1 und now it works! Thank you all for your help!!
system
Closed
June 1, 2023, 7:20pm
10
