Hi, I installed manjaro on Microsoft Surface 6 and WI-FI doesn’t work. I tried to fix them, but I failed. Do you have any ideas on how to fix this?
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc vi 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=c4de2e61-a427-4c87-8788-21ab3a788aa2 rw quiet splash apparmor-1
security apparmor udev.log_priority=3
Desktop: GNOME v: 45.3 tk: GTK v: 3.24.39 wm: gn-shell dm: GDM
v: 45.0.1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Microsoft product: Surface Pro
v: 124000000000000000000000D:0B:09F:5C:09P:385:12E:0
serial: <superuser required> Chassis: type: 9 serial: <superuser required> Mobo: Microsoft model: Surface Pro serial: <superuser required>
UEFI: Microsoft v: 239,871.768 date: 11/07/2015
ID-1: BAT1 charge: 23.5 Wh (100.0%) condition: 23.5/45.0 Wh (52.2%)
power: 5.0 W volts: 8.5 min: 7.6 model: SMP M1009169 type: Li-ion
serial: <filter> status: full cycles: 432
Info: model: Intel Core 17-76600 bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF4
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB desc: d-2x32 K1B; 1-2x32 K1B L2: 512 KiB desc: 2x256 KiB
L3: 4 MiB desc: 1x4 MiB Speed (MHz): avg: 400 min/max: 400/4000 scaling: driver: intel pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 20004
Type: itlb multihit status: KVM: VMX disabled
Type: litf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
Type: spectre_v1 mitigation: usercopy/swapgs barriers and_user pointer sanitization
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-EIBRS: Not affected
Device-1: Intel Iris Plus Graphics 640 vendor: Microsoft driver: 1915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5926 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 compositor: gnome-shell driver: gpu: 1915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x0555 serial: <filter> built: 2016 res: 2736x1824 dpi: 267 gamma: 1.2 size: 260x173mm (10.24x6.81")
diag : EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
: 312mm (12.3") ratio: 3:2 modes: 2736x1824
API
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Plus Graphics 640
(Kaby Lake GT3e) (KBL GT3) device-ID: 8086:5926 memory: 15.18 GiB
unified: yes display-ID: :0.0
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging Unit driver: ipu3-imgu alternate: 1pu3_imgu bus-ID: 00:05.0
chip-ID: 8086:1919 class-ID: 0480
Device-2: Intel CSI-2 Host driver: 1pu3-cio2 alternate: 1pu3_cio2 bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl, snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsactl,alsamixer, amixer
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pci
v: 1.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 11ab:2b38 class-ID: 0200
Local Storage: total: 953.88 GiB used: 9.52 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: KUS040202M-B000 size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8
lanes: 2 tech: SSD serial: <filter> fw-rev: DXYBAM10 temp: 34.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: KUS040202M-B000 size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8
lanes: 2 tech: SSD serial: <filter> fw-rev: DXYBAM10 temp: 33.9 C
scheme: GPT
ID-1: /raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 9.52 GiB (2.0
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme@n1p1 maj-min: 259:1
System Temperatures: cpu: 34.0 C pch: 30.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 203 Uptime: 9m wakeups: Memory: total: 16 GiB
available: 15.54 GiB used: 1.73 GiB (11.1%) Init: systemd v: 255 default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman pkgs: 1209 libs: 349 tools: gnome-software, pamac pm: flatpak pkgs: Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.31
