Hi, I was trying to get GPU passthrough working on my PC. I was using the AUR package gpu-passthrough-manager to do so. After selecting the GTX 1650 for vfio I dont get a video Output at all on both GPUs. How can I fix this, so that I get video output again?
GitHub - uwzis/GPU-Passthrough-Manager: GPU passthrough made easy.
They say that you need to chroot.
Boot from usb, manjaro-chroot -a and remove the file vfio.conf from /etc/modprobe.d/
and also restore /etc/default/grub and then update-grub
Perhaps also regenerate the initrd:
mkinitcpio -P is the command to do it if I recall correctly
Help others to help you.
Please provide system information as described (below) along with any other specific details that might be useful.
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi --filter --verbosity=8
or the short form:
inxi -zv8
- inxi man pages (Arch Manual)
