The company claims it has no support for linux operating systems. Is this necessarily true?
Manjaro is playing through the device fine, except it keeps restarting every so often which makes it highly unreliable and unusable.
Is there a driver I am missing for Manjaro Linux that will solve this?
Annoyingly, the website doesn’t outright say if it uses USB Audio Class 1 or 2, but it is USB Audio Class 2 due to the sample rates it supports.
USB Audio Class 1 should work right out of the box regardless of OS.
USB Audio Class 2 is supported natively via the Linux Kernel. But some manufacturers add more stuff to these that sometimes requires a specific driver, or no support for Linux, which causes issues.
Driver-wise? Probably not.
Looks like someone else had the same issue, but was not solved.
It’s better to just use a DAC from a manufacturer that actually supports Linux, such as JDS Labs. All my JDS Labs works out of the box, even the ones that use USB Audio Class 2.
Nice.
So just to tell you that means you can make a file like /etc/tlp.conf.d/scarlett.conf
And in there put:
USB_AUTOSUSPEND=0
But … I do suggest finding the device address instead and using
USB_BLACKLIST="1111:2222 3333:4444"
(where 1111:2222 is your device)
that is … unless you consider usb autsuspend just expendable … then sure disable it altogether.
Of course … none of that is necessary … its just ‘cleaner’ and doesnt require the extra application.
Actually it could just be a one line command … ex:
