Contrarily to the original post, it has nothing to do with USB itself; the USB cable is for charging purposes only: it’s the jack that doesn’t work if inserted into the docking station but works when inserted straight into the laptop.
hdajackretask ? Or something else entirely?
P.S. @Nito8 next time when anyone asks for a command output, first type export LANG=C. That way any subsequent command comes out in English until you close and reopen the terminal…
CX20724 + HP UltraSlim Docking Station is most likely to be HP Elitebook
support for the audio codec was added to kernel in 2015 so main laptop audio functions should be ok
also found this showing dock function Connecting a Compatible HP Notebook to the HP UltraSlim Docking Station
no USB connection to dock and no audio device within dock showing in aplay -l
so this is probably just an extra couple of jack connections to main audio codec, similar to front panel jacks on a desktop system
please post more data
sudo dmesg | grep snd
and
alsa-info.sh --upload
[@fabby - thinking this may need a modprobe option to get the dock working?]
[ 5.932472] snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX20724: line_outs=1
only one output is detected for line_outs and response has been cropped so I cannot see the pin number, but it is likely to be for the combination jack socket shared with Mic=0x19
I think your basic user status on forum may not allow posting a link to alsa-info.sh data or sending via PM
In case you cannot post links and want to post them, use:
htt!ps://forum.manjaro.org
(add a ! in-between htt and ps)
We will still be able to remove the ! as it’s just to keep spammers from posting links to penis enlargement pills, Pr0n and other things we don’t want on the forum)
