Some time before the recent Manjaro update that brought us Pipewire 0.3.19, I tried switching to Pipewire on my old test laptop and it worked fine for the most part but I went back to normal PulseAudio because of some slight annoyances.
Now after the update, I tried it again: I removed Pulseaudio and installed pipewire pipewire-pulse pipewire-alsa pipewire-jack (I also once tried the manjaro-pipewire meta package and it made no difference).
After a reboot, only ALSA sound works, but pulseaudio and jack don’t, and the Plasma sound try thingy shows no devices. The pipewire-pulse service is running, but it shows:
â—Ź pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; vendor preset: enabled)
Active: active (running) since Sat 2021-01-23 14:31:00 CET; 11min ago
TriggeredBy: â—Ź pipewire-pulse.socket
Main PID: 1344 (pipewire-pulse)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire-pulse.service
└─1344 /usr/bin/pipewire-pulse
Jan 23 14:42:03 J-LB-MANJARO pipewire-pulse[1344]: pulse-server 0x558205274da0: failed to connect client: Host is down
Jan 23 14:42:03 J-LB-MANJARO pipewire-pulse[1344]: pulse-server 0x558205290630: [QPulse] ERROR command:9 (SET_CLIENT_NAME) tag:1 error:6 (Host is down)
Jan 23 14:42:04 J-LB-MANJARO pipewire-pulse[1344]: pulse-server 0x558205274da0: failed to connect client: Host is down
Jan 23 14:42:04 J-LB-MANJARO pipewire-pulse[1344]: pulse-server 0x558205290630: [QPulse] ERROR command:9 (SET_CLIENT_NAME) tag:1 error:6 (Host is down)
pactl info returns Connection failure: Connection refused
Jack also doesn’t work at all, even though pipewire-jack is installed and ldd /usr/bin/qjackctl | grep -i libjack returns libjack.so.0 => /usr/lib/pipewire-0.3/jack/libjack.so.0 (0x00007f6f0686b000)
Does Pipewire work for other people as a pulse / jack replacement? Am I doing something wrong or missing something?
