No sound with analog stereo Asus
Hi. I have a laptop with dual boot windows 11. When I try to use analog stereo output or duplex no sound, but in sound settings I can see that there is sound. When I use HDMI output, sound working.
inxi -Fxxxz
  Kernel: 5.16.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X7400PC_N7400PC
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X7400PC v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: X7400PC.207 date: 07/14/2021
  ID-1: BAT0 charge: 62.8 Wh (100.0%) condition: 62.8/63.0 Wh (99.6%)
    volts: 12.0 min: 12.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 4
  Info: quad core model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
    smt: enabled arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB
    L3: 12 MiB
  Speed (MHz): avg: 1082 high: 1142 min/max: 400/4800 cores: 1: 1090
    2: 1071 3: 958 4: 1104 5: 1072 6: 1115 7: 1108 8: 1142 bogomips: 52856
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
    driver: nouveau v: kernel bus-ID: 0000:01:00.0 chip-ID: 10de:25a2
    class-ID: 0302
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-6:4 chip-ID: 13d3:5458 class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 4800x1800 s-dpi: 96 s-size: 1270x476mm (50.00x18.74")
    s-diag: 1356mm (53.4")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: Acer VG272 P
    serial: <filter> res: 1920x1080 hz: 120 dpi: 82
    size: 597x336mm (23.5x13.23") diag: 685mm (27") modes: max: 3840x2160
    min: 720x400
  Monitor-2: eDP-1 pos: right model: Samsung 0x4154 res: 2880x1800 hz: 90
    dpi: 242 size: 302x189mm (11.89x7.44") diag: 356mm (14") modes: 2880x1800
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.3.7
    direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0403
  Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
    bus-ID: 3-10:8 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
    class-ID: 0104
  Local Storage: total: 953.87 GiB used: 11.96 GiB (1.3%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM001TD3JX013N
    size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: 41000C20 temp: 32.9 C scheme: GPT
  ID-1: / size: 360.8 GiB used: 11.94 GiB (3.3%) fs: ext4 dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 27.7 MiB (9.2%) fs: vfat
    dev: /dev/nvme0n1p1
  System Temperatures: cpu: 49.0 C mobo: N/A
  Processes: 252 Uptime: 13m wakeups: 2 Memory: 15.31 GiB
  used: 3.48 GiB (22.7%) Init: systemd v: 250 Compilers: gcc: 11.2.0
  clang: 13.0.1 Packages: 1214 pacman: 1207 flatpak: 7 Shell: Zsh v: 5.8.1
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
pulseaudio --dump-conf
### Read from configuration file: /etc/pulse/daemon.conf ###
daemonize = no
fail = yes
high-priority = yes
nice-level = -11
realtime-scheduling = yes
realtime-priority = 5
allow-module-loading = yes
allow-exit = yes
use-pid-file = yes
system-instance = no
local-server-type = user
cpu-limit = no
enable-shm = yes
flat-volumes = no
rescue-streams = yes
lock-memory = no
exit-idle-time = 20
scache-idle-time = 20
dl-search-path = /usr/lib/pulse-15.0/modules
default-script-file = /etc/pulse/default.pa
load-default-script-file = yes
log-target =
log-level = notice
resample-method = auto
avoid-resampling = no
enable-remixing = yes
remixing-use-all-sink-channels = yes
remixing-produce-lfe = no
remixing-consume-lfe = no
lfe-crossover-freq = 0
default-sample-format = s16le
default-sample-rate = 44100
alternate-sample-rate = 48000
default-sample-channels = 2
default-channel-map = front-left,front-right
default-fragments = 4
default-fragment-size-msec = 25
enable-deferred-volume = yes
deferred-volume-safety-margin-usec = 8000
deferred-volume-extra-delay-usec = 0
shm-size-bytes = 0
log-meta = no
log-time = no
log-backtrace = 0
rlimit-fsize = -1
rlimit-data = -1
rlimit-stack = -1
rlimit-core = -1
rlimit-rss = -1
rlimit-as = -1
rlimit-nproc = -1
rlimit-nofile = 256
rlimit-memlock = -1
rlimit-locks = -1
rlimit-sigpending = -1
rlimit-msgqueue = -1
rlimit-nice = 31
rlimit-rtprio = 9
rlimit-rttime = 200000
alsa-info.sh --upload
I tried to follow solution from this thread, but this doesn’t change anything.
Hello,
I think you need to install sof-firmare
Personally i would chose what server to use as default and be one, not both.
See here how to do that.
Now sound working. Thank you.
