Unfortunately, since today I have no sound when starting videos, for example on YouTube, although my speakers are working and producing sound when tested. What could be the reason for this? I use Manjaro-KDE
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=9f58b150-d229-40ac-b851-50f2c1743587 rw quiet splash
resume=UUID=29e3f248-8497-4337-b8af-b5d8d5199411 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: LENOVO product: 20KGS9SA0J v: ThinkPad X1 Carbon 6th
Mobo: LENOVO model: 20KGS9SA0J serial: <superuser required>
part-nu: LENOVO_MT_20KG_BU_Think_FM_ThinkPad X1 Carbon 6th
uuid: <superuser required> UEFI: LENOVO v: N23ET88W (1.63 )
date: 02/28/2024
ID-1: BAT0 charge: 50.7 Wh (99.0%) condition: 51.2/56.2 Wh (91.2%)
power: 4.7 W volts: 13.0 min: 11.6 model: LGC 01AV430 type: Li-poly
serial: <filter> status: charging cycles: 10
Info: model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 437 high: 700 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 bogomips: 33615
vulnerable
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: DP-3,DP-4,eDP-1 empty: DP-1, DP-2, DP-5, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b615
class-ID: 0e02
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:6 chip-ID: 04f2:b614
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 d-rect: 5120x1800 display-ID: 0
Monitor-1: DP-3 pos: primary,top-left res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-4 pos: top-right res: 1920x1080 size: N/A modes: N/A
Monitor-3: eDP-1 pos: bottom-c res: 1280x720 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
device-ID: 8086:5917 memory: 15.13 GiB unified: yes display-ID: :1.0
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Device-2: GN Netcom Jabra SPEAK 410 driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.3.4.3:12
chip-ID: 0b0e:0410 class-ID: 0300 serial: <filter>
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.3.4:4 chip-ID: 0b95:1790
class-ID: 0a00 serial: <filter>
IF: enp59s0u2u3u4c2 state: up speed: 100 Mbps duplex: half mac: <filter>
Local Storage: total: 238.47 GiB used: 347.1 GiB (145.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: LENSE30256GMSP34MEAT3TA size: 238.47 GiB block-size: physical: 512 B
fw-rev: 2.5.0412 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 221.13 GiB size: 216.59 GiB (97.95%)
used: 103.72 GiB (47.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 17.05 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 56.0 C pch: 56.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Memory: total: 16 GiB available: 15.49 GiB used: 3.31 GiB (21.4%)
Processes: 278 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
image: 6.18 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1364 pm: pacman pkgs: 1357 libs: 394 tools: pamac pm: flatpak
pkgs: 7 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.35
