Hi, so I have problems with my laptop audio. Headphones work both with Bluetooth and by type C cable. I have tried some things that I could find online. I updated the kernel and installed pipe wire and PulseAudio. I have also tried to unmute with amixer.
This maybe is interesting?
amixer sset Speaker unmute ✔
amixer: Unable to find simple control 'Speaker',0
Here is all the info I can think of giving.
Kernel: 5.17.1-1-rt16-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-rt-x86_64
root=UUID=333f6e70-9683-450e-ac01-16ab6d323b1f rw quiet
cryptdevice=UUID=394675e1-92c4-48c6-901d-592f7f77b906:luks-394675e1-92c4-48c6-901d-592f7f77b906
root=/dev/mapper/luks-394675e1-92c4-48c6-901d-592f7f77b906 splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-a3aaad29-5fb0-4f44-858b-85d1cb28646a
udev.log_priority=3
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: LENOVO product: 82N6 v: Legion 7 16ACHg6
serial: <superuser required> Chassis: type: 10 v: Legion 7 16ACHg6
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: GKCN49WW date: 11/08/2021
ID-1: BAT0 charge: 74.6 Wh (100.0%) condition: 74.6/80.0 Wh (93.2%)
volts: 17.3 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: full cycles: 91
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3350 high: 3714 min/max: 400/4463 boost: enabled
scaling: driver: amd-pstate governor: schedutil cores: 1: 3168 2: 3237
3: 3375 4: 3324 5: 3527 6: 3497 7: 3308 8: 3350 9: 3290 10: 3245 11: 3610
12: 3167 13: 3165 14: 3165 15: 3473 16: 3714 bogomips: 102204
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: Lenovo driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24dc class-ID: 0300
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 2560x1600 s-size: <missing: xdpyinfo>
Monitor-1: DP-4 res: 2560x1600 hz: 60 dpi: 188
size: 345x215mm (13.58x8.46") diag: 407mm (16") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.17.1-1-rt16-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: no
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.16 TiB used: 36.27 GiB (3.1%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung
model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
rev: 3L1QEXF7 temp: 49.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211210WD temp: 45.9 C scheme: GPT
ID-1: / raw-size: 215.55 GiB size: 211.11 GiB (97.94%)
used: 36.27 GiB (17.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-394675e1-92c4-48c6-901d-592f7f77b906
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 17.03 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-a3aaad29-5fb0-4f44-858b-85d1cb28646a
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 56 C
Processes: 490 Uptime: 5m wakeups: 1 Memory: 15.55 GiB
used: 1.92 GiB (12.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1320 pacman: 1313 lib: 421 flatpak: 0
snap: 7 Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.15
### Configuration dump generated at Mon Apr 18 14:22:23 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_06_00.6" card_name="alsa_card.pci-0000_06_00.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_06_00.6.analog-stereo 0x10000
set-sink-mute alsa_output.pci-0000_06_00.6.analog-stereo no
suspend-sink alsa_output.pci-0000_06_00.6.analog-stereo yes
set-source-volume alsa_output.pci-0000_06_00.6.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_06_00.6.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_06_00.6.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_06_00.6.analog-stereo 0x4421
set-source-mute alsa_input.pci-0000_06_00.6.analog-stereo no
suspend-source alsa_input.pci-0000_06_00.6.analog-stereo yes
set-card-profile alsa_card.pci-0000_01_00.1 off
set-card-profile alsa_card.pci-0000_06_00.6 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_06_00.6.analog-stereo
set-default-source alsa_input.pci-0000_06_00.6.analog-stereo
### EOF
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
http://alsa-project.org/db/?f=43e69bc95ace14767c8f30734a8e682e1058f125
speaker-test 1.2.6
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 192 to 2097152
Period size range from 64 to 699051
Using max buffer size 2097152
Periods = 4
was set period_size = 524288
was set buffer_size = 2097152
0 - Front Left
Time per period = 10,928825
0 - Front Left
Time per period = 10,928515
0 - Front Left
Time per period = 10,928743
0 - Front Left
Time per period = 10,928567
0 - Front Left
Time per period = 10,928428
0 - Front Left
Time per period = 10,928667
0 - Front Left
Time per period = 10,928268
0 - Front Left
Time per period = 10,928553
0 - Front Left
Time per period = 10,927838
0 - Front Left
Time per period = 10,928274
0 - Front Left
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
HDA NVidia, HDMI 4
HDMI Audio Output
hdmi:CARD=NVidia,DEV=5
HDA NVidia, HDMI 5
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
sysdefault:CARD=Generic
HD-Audio Generic, ALC287 Analog
Default Audio Device
front:CARD=Generic,DEV=0
Front output / input
surround21:CARD=Generic,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
snd_hda_codec_realtek 159744 1
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
ledtrig_audio 16384 1 snd_hda_codec_generic
snd_hda_codec_hdmi 73728 1
snd_hda_intel 57344 6
snd_intel_dspcfg 32768 1 snd_hda_intel
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
snd_hda_codec 176128 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core 106496 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 159744 5 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_timer 40960 1 snd_pcm
snd_hda_scodec_cs35l41_i2c 16384 0
snd 118784 19 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
snd_hda_scodec_cs35l41 16384 1 snd_hda_scodec_cs35l41_i2c
soundcore 16384 1 snd
snd_soc_cs35l41_lib 28672 2 snd_hda_scodec_cs35l41_i2c,snd_hda_scodec_cs35l41
