Hello! I’m somewhat new-ish to Linux so please do bare with me. After installing Manjaro, randomly after a random amount of time audio will stop working. It would play videos and the test chime just fine, then all of a sudden stop and respond to neither; locking up the video and playing no test tone. This would happen in both the live disk from a USB drive, as well as a full install over multiple fresh installs. I also tried installing Pop Os and the same thing happened there. After a bit of research, I decided I’d try switching from Pulseaudio to Pipewire to see if that was the cause, but the issue still persists. I really don’t mind which audio service I end up using, so long as I can get something. Device in question is the usb DAC
Can’t post alsa report as I cannot post links.
Output of inxi -Fxz:
base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: RAMPAGE IV BLACK EDITION v: Rev 1.xx serial: <filter> UEFI: American Megatrends
v: 0801 date: 07/04/2014
CPU: Info: 6-Core model: Intel Core i7-4930K bits: 64 type: MT MCP arch: Ivy Bridge rev: 4 cache: L2: 12 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 81677
Speed: 1655 MHz min/max: 1200/3900 MHz Core speeds (MHz): 1: 1655 2: 2604 3: 2227 4: 1322 5: 2165 6: 1431 7: 1581
8: 1326 9: 1599 10: 1431 11: 3273 12: 1411
Graphics: Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: eVga.com. driver: nvidia v: 460.80 bus-ID: 01:00.0
Display: x11 server: X.org 1.20.11 driver: loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GTX 980 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.80 direct render: Yes
Audio: Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0
Device-2: NVIDIA GM200 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: GYROCOM C&C UAC1 DAC type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-1.4:5
Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.28 running: yes
Network: Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe driver: e1000e v: kernel port: f040
bus-ID: 00:19.0
RAID: Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 bus-ID: 00:1f.2
Device-1: md126 type: mdraid level: raid-0 status: active size: 476.9 GiB
Info: report: N/A blocks: 500065280 chunk-size: 128k
Components: Online: 0: sdb 1: sda
Device-2: md127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 10402 chunk-size: N/A
Components: Online: N/A Spare: 0: sda 1: sdb
Drives: Local Storage: total: raw: 2.39 TiB usable: 1.93 TiB used: 9.2 GiB (0.5%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
ID-3: /dev/sdc vendor: OCZ model: AGILITY3 size: 111.79 GiB
ID-4: /dev/sdd vendor: Western Digital model: WD2003FZEX-00Z4SA0 size: 1.82 TiB
Partition: ID-1: / size: 24.44 GiB used: 8.79 GiB (36.0%) fs: ext4 dev: /dev/sdd4
ID-2: /boot/efi size: 511 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sdd6
ID-3: /home size: 116.56 GiB used: 419.6 MiB (0.4%) fs: ext4 dev: /dev/sdd5
Swap: ID-1: swap-1 type: partition size: 6 GiB used: 0 KiB (0.0%) dev: /dev/sdd3
Sensors: System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 61 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Info: Processes: 312 Uptime: 26m Memory: 31.3 GiB used: 3.61 GiB (11.5%) Init: systemd Compilers: gcc: N/A Packages: 1057
Shell: Bash v: 5.1.8 inxi: 3.3.04
Output of aplay -l:
card 0: PCH [HDA Intel PCH], device 0: ALC1150 Analog [ALC1150 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC1150 Digital [ALC1150 Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
card 2: DAC [UAC1 DAC], device 0: USB Audio [USB Audio]
Subdevices: 1/1
pactl info returns:
Server String: /run/user/1000/pulse/native
Library Protocol Version: 34
Server Protocol Version: 35
Is Local: yes
Client Index: 108
Tile Size: 65472
User Name: [Redacted]
Host Name: [Redacted]
Server Name: PulseAudio (on PipeWire 0.3.28)
Server Version: 14.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.usb-Yoyodyne_Consulting_UAC1_DAC-01.analog-stereo
Default Source: pulseeffects_source
Cookie: bc0d:2bad
Happy to post any further info if needed, or even fresh install back to pulseaudio as I’ve not really got any data to lose. Any help is appreciated as I’m slowly losing my mind
