Manjaro Gnome randomly crashing with an error: 'Failed to execute shutdown binary', while using the system
I need help!. I have installed Manjaro Gnome recently on my laptop. While I browse and run Jupyter notebook on my laptop, it is crashing with an error ‘Failed to execute shutdown binary’. I need help in fixing this issue.
Unless the systemd-sysvcompat package got corrupted on your end, or you did a partial update … i can’t explain it. So, you can try from terminal:
sudo pacman -Scc && sudo pacman-mirrors -f5 && sudo pacman -Syyu systemd-sysvcompat
and after that is finished
systemctl reboot
Then see if that issue comes up again … also, in what cases you seen that error happening?
This is issue is happening when I use my Firefox browser for viewing lectures and using Jupyter notebooks simultaneously.
And where is that message appearing ?
system is crashing and going into black screen and when i press ctrl+alt+del i am getting that error
These are the errors that i am getting when typing " sudo journalctl -p 3 -xb "
-- Journal begins at Mon 2021-11-29 23:59:27 IST, ends at Fri 2021-12-10 19:26:05 IST. --
Dec 10 19:24:15 My-Omen kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP4.WLAN], AE_NOT_FOUND (20210331/dswload2-162)
Dec 10 19:24:15 My-Omen kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210331/psobject-220)
Dec 10 19:24:15 My-Omen kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P000 (20210331/dspkginit-438)
Dec 10 19:24:16 My-Omen kernel: acp_pdm_mach acp_pdm_mach.0: snd_soc_register_card(acp) failed: -517
Dec 10 19:24:23 My-Omen pulseaudio[888]: Failed to find a working profile.
Dec 10 19:24:23 My-Omen pulseaudio[888]: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false>
Dec 10 19:24:28 My-Omen gdm-password][1158]: gkr-pam: unable to locate daemon control file
Dec 10 19:24:31 My-Omen pulseaudio[1393]: Failed to find a working profile.
Dec 10 19:24:31 My-Omen pulseaudio[1393]: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=fals>
Dec 10 19:24:33 My-Omen systemd[1170]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 384 and the job result is failed.
Dec 10 19:24:34 My-Omen gdm-launch-environment][716]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
You truncated the journal text … See bellow how to share properly formatted output from terminal and what information about system to share with us.
Please use <pre><code> for terminal output. I’ve done it for you this time. :wink:
