I just booted a new build, installed discord and my mic will not playback sound on test. It shows as available but will not work. Also I have no sound coming out of either of my monitors (i have 3 plugged via DP)
I am unsure of what might be the issue, I looked online but could not find anything with my exact situation
I have a dedicated mic plugged with an XLR cable to a audio interface (behringer UM2)
Any help is must appreciated.
Can you post inxi -Fza on console ?
~ inxi -Fza ✔
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7fe997d6-c0a6-4edc-aa1b-a3eb253392ad rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG RAMPAGE VI EXTREME ENCORE v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_KBLX
uuid: <superuser required> UEFI: American Megatrends v: 1301
date: 09/24/2021
Info: model: Intel Core i9-10940X bits: 64 type: MT MCP arch: Cascade Lake
gen: core 10 level: v4 note: check built: 2019 process: Intel 14nm family: 6
model-id: 0x55 (85) stepping: 7 microcode: 0x5003604
Topology: cpus: 1x cores: 14 tpc: 2 threads: 28 smt: enabled cache:
L1: 896 KiB desc: d-14x32 KiB; i-14x32 KiB L2: 14 MiB desc: 14x1024 KiB
L3: 19.2 MiB desc: 1x19.2 MiB
Speed (MHz): avg: 1200 high: 1209 min/max: 1200/4600:4700:4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 1200 3: 1200
4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200
13: 1209 14: 1200 15: 1200 16: 1200 17: 1200 18: 1200 19: 1200 20: 1200
21: 1200 22: 1200 23: 1200 24: 1200 25: 1200 26: 1200 27: 1200 28: 1200
bogomips: 184883
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 550.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-1,DP-2,DP-3 empty: HDMI-A-1,HDMI-A-2 bus-ID: 65:00.0
chip-ID: 10de:2206 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
alternate: fbdev,vesa dri: nouveau gpu: nouveau d-rect: 7680x1440
display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,left res: 2560x1440 size: N/A modes: N/A
Monitor-3: DP-3 pos: center res: 2560x1440 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV172 device-ID: 10de:2206
memory: 9.7 GiB unified: no display-ID: :1.0
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 65:00.1 chip-ID: 10de:1aef
class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5:26 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-3: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
10G] vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 link-max: lanes: 4 port: N/A bus-ID: 06:00.0 chip-ID: 1d6a:07b1
class-ID: 0200 temp: 56.3 C
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager,wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:14 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 1.36 TiB used: 12.27 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN770 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 731030WD temp: 40.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 40.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 12.27 GiB (1.3%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
System Temperatures: cpu: 27.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 96 GiB note: est. available: 93.98 GiB used: 3.49 GiB (3.7%)
Processes: 474 Power: uptime: 59m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 37.58 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1156 libs: 341 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
