Hi everyone,
I installed Manjaro on this matebook and initially couldn’t get any sound device to work. After some fiddling I was able to get the microphone to work by uncommenting
load-module module-alsa-source device=hw:1,0
That line, so the microphone now works but the speakers don’t.
To be clear, the only available output device is ‘dummy output’
I’ve tried a few older and newer Kernels, I’m on 5.14.10 now and no luck
Any help will be greatly appreciated.
Output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=4753eda4-3ed2-477e-a70e-cf5dba5f6e28 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: HUAWEI product: HVY-WXX9 v: M1040 serial: <filter>
Mobo: HUAWEI model: HVY-WXX9-PCB-B1 v: M1040 serial: <filter> UEFI: HUAWEI
v: 2.07 date: 08/14/2021
ID-1: BAT0 charge: 32.9 Wh (58.3%) condition: 56.4/55.3 Wh (102.0%)
volts: 15.5 min: 15.3 model: Sunwoda- HB6081V1ECW-41 type: Li-ion
serial: <filter> status: Discharging cycles: 1
RAM: total: 15.01 GiB used: 1.57 GiB (10.5%)
Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L2: 3 MiB bogomips: 71897
Speed: 1527 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz):
1: 1527 2: 1397 3: 1397 4: 1397 5: 1515 6: 1475 7: 1394 8: 1794 9: 1397
10: 1397 11: 1397 12: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir driver: amdgpu v: kernel bus-ID: 03:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 13d3:5476 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 137 size: 355x200mm (14.0x7.9")
diag: 407mm (16")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 8.54 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: YMTC PC005 512GB size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: YM00D213 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 8.54 GiB (1.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 4753eda4-3ed2-477e-a70e-cf5dba5f6e28
label: NO_LABEL uuid: 0A00-89FA
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-4:2 info: Shenzhen Goodix Goodix Fingerprint Device
type: Communication,CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5110 class-ID: 0a00
serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 3-4:3 info: IMC Networks HD Camera type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:5476
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.5 C mobo: N/A gpu: amdgpu temp: 38.0 C
Processes: 284 Uptime: 17m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1071 lib: 307 flatpak: 0
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.07
