PeterW
1
Hello people,
after an (unsuccessfull) installation of Nix suddenly there is no sound output anymore.
I use:
- Manjaro XFCE 20.0.3 64bit
- A pair of speakers connected over the sound output socket.
(I don’t know if Nix is related with this problem at all.)
Greetings
Peter
Please post the output of the following commands:
pacmd list-sources
Play sound and type:
pacmd list-sinks
Check if sound is muted:
pulseaudio-ctl
PeterW
3
Output of “pacmd list-sources”:
1 source(s) available.
- index: 0
driver: <module-alsa-card.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1030
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max rewind: 0 KiB
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 … 1999,82 ms
monitor_of: 0
card: 0 <alsa_card.pci-0000_00_14.2>
module: 6
properties:
device.description = “Monitor of Internes Audio Analog Stereo”
device.class = “monitor”
alsa.card = “0”
alsa.card_name = “HDA ATI SB”
alsa.long_card_name = “HDA ATI SB at 0xfe9f4000 irq 16”
alsa.driver_name = “snd_hda_intel”
device.bus_path = “pci-0000:00:14.2”
sysfs.path = “/devices/pci0000:00/0000:00:14.2/sound/card0”
device.bus = “pci”
device.vendor.id = “1002”
device.vendor.name = “Advanced Micro Devices, Inc. [AMD/ATI]”
device.product.id = “4383”
device.product.name = “SBx00 Azalia (Intel HDA)”
device.form_factor = “internal”
device.string = “0”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-pci”
Output of “pacmd list-sinks”:
1 sink(s) available.
index: 0
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 95027 / 145% / 9,68 dB, front-right: 95027 / 145% / 9,68 dB
balance 0,00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
Stereo
used by: 0
linked by: 0
module: 6
properties:
alsa.resolution_bits = “16”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “ALC662 rev1 Analog”
alsa.id = “ALC662 rev1 Analog”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0”
alsa.device = “0”
alsa.card = “0”
device.bus = “pci”
device.string = “front:0”
device.buffering.buffer_size = “352768”
device.buffering.fragment_size = “176384”
device.access_mode = “mmap+timer”
device.profile.name = “analog-stereo”
device.profile.description = “Analog Stereo”
device.description = “Internes Audio Analog Stereo”
alsa.mixer_name = “Realtek ALC662 rev1”
alsa.components = “HDA:10ec0662,18497662,00100101”
ports:
analog-output-lineout: Line-Ausgang (priority 9000, latency offset 0 usec, available: no)
properties:
analog-output-headphones: Kopfhörer (priority 9900, latency offset 0 usec, available: yes)
properties:
device.icon_name = “audio-headphones”
active port:
Output of “pulseaudio-ctl”:
Volume level : 145 %
Is sink muted : no
Is source muted : no
Detected sink : 0
Detected source : 0
