No sound is coming out from front panel headphones, I only use these. Tried several suggestions for ALC cards but nothing worked so far. Sound worked flawlessly on windows.
$ aplay -lL
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=Generic,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
hdmi:CARD=Generic,DEV=1
HD-Audio Generic, HDMI 1
HDMI Audio Output
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
sysdefault:CARD=Generic_1
HD-Audio Generic, ALC892 Analog
Default Audio Device
front:CARD=Generic_1,DEV=0
Front output / input
surround21:CARD=Generic_1,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic_1,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic_1,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic_1,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic_1,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic_1,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=Generic_1
HD-Audio Generic
USB Stream Output
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: Generic_1 [HD-Audio Generic], device 0: ALC892 Analog [ALC892 Analog]
Subdevices: 1/1
$ amixer -c1
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 44 [69%] [-20.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Simple mixer control 'Center',0
Mono: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
Mono:
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 46
Front Left: Capture 28 [61%] [12.00dB] [on]
Front Right: Capture 28 [61%] [12.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-16.00dB] [off]
Front Right: Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
$ pactl list cards
Card #0
Driver: module-alsa-card.c
Owner Module: 6
Properties:
alsa.card = "0"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfcb88000 irq 77"
device.bus_path = "pci-0000:27:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:27:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "15de"
device.product.name = "Raven/Raven2/Fenghuang HDMI/DP Audio Controller"
device.string = "0"
device.description = "Raven/Raven2/Fenghuang HDMI/DP Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: off
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
Card #1
Owner Module: 7
Properties:
alsa.card = "1"
alsa.long_card_name = "HD-Audio Generic at 0xfcb80000 irq 78"
device.bus_path = "pci-0000:27:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:27:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h/19h HD Audio Controller"
device.string = "1"
device.description = "Family 17h/19h HD Audio Controller"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-71: Analog Surround 7.1 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-71+input:analog-stereo: Analog Surround 7.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
Active Profile: off
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, not available)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:analog-surround-71+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, not available)
Properties:
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, not available)
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, not available)
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-71, output:analog-surround-71+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, not available)
Properties:
$ pactl list sinks
Sink #0
State: RUNNING
Description: Dummy Output
Driver: module-null-sink.c
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 16
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: auto_null.monitor
Latency: 7858 usec, configured 75000 usec
Flags: DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
device.description = "Dummy Output"
device.class = "abstract"
device.icon_name = "audio-card"
Formats:
pcm
$ pactl list sink-inputs
Sink Input #0
Driver: protocol-native.c
Owner Module: 12
Client: 9
Sink: 0
Sample Specification: float32le 2ch 48000Hz
Format: pcm, format.sample_format = "\"float32le\"" format.rate = "48000" format.channels = "2" format.channel_map = "\"front-left,front-right\""
Corked: no
Mute: no
balance 0.00
Buffer Latency: 125000 usec
Sink Latency: 37978 usec
Resample method: copy
Properties:
media.name = "Mind relax lofi song (slowed+reverb) all songs mixed - YouTube"
application.name = "Firefox"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "35"
application.process.id = "2083"
application.process.user = "kaushik"
application.process.host = "dipta-ms7c02"
application.process.binary = "firefox"
application.language = "en_US.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "f13eced6f2064e1885c7c4f3ff02046f"
application.icon_name = "firefox"
module-stream-restore.id = "sink-input-by-application-name:Firefox"
I will be glad to provide any additional info required.
