Hi ! HP Victus, Manjaro XFCE, I have a Iiyama secondary screen linked by Hdmi, how to use its speakers rather than the victus ones ?
I don’t see them on the audio GUI
➜ ~ inxi -A | grep -A5 "Audio"
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_rn_pci_acp3x
Device-4: AMD Family 17h/19h HD Audio driver: snd_hda_intel
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api
Server-1: PipeWire v: 1.0.3 status: active (process)
Check Configuration tab in PulseAudio Volume Control audio mixer:
pavucontrol --tab=5
Profile for 1st device is probably set to Off
Change Profile to Digital Stereo Output that shows connection to monitor
Mixer and panel GUI controls should then show 3 output sinks
If audio playback to monitor is still not working as expected, check the HDMI output is not muted in ALSA
alsamixer -c0
Hi, thank you for caring.
I have an issue with pavucontrol :
➜ ~ systemctl --user status pipewire-pulse.socket pipewire-pulse.service
● pipewire-pulse.socket - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.socket; enabled; preset: enabled)
Active: active (running) since Sat 2024-03-30 07:57:14 CET; 8h ago
Triggers: ● pipewire-pulse.service
Listen: /run/user/1000/pulse/native (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire-pulse.socket
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
TriggeredBy: ● pipewire-pulse.socket
Main PID: 2050 (pipewire-pulse)
Tasks: 3 (limit: 18339)
Memory: 29.7M (peak: 30.2M swap: 1.1M swap peak: 1.2M zswap: 217.3K)
CPU: 1.866s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─2050 /usr/bin/pipewire-pulse
➜ ~ pavucontrol
➜ ~ pavucontrol --tab=5
and with alsamixer as well I suppose
for ALSA, use M key to unmute the S/PDIF output [OO]
For pipewire-pulse & pavucontrol I suggest reboot system
If pavucontrol is still unable to connect to pipewire-pulse , please post more information about audio devices detected in pipewire-pulse
pactl list cards
Ok, I didn’t grasp the alsamixer interface
Shifted from MM to oo.
Why restart ? pavucontrol & pipewire-pulse are installed for months
Here another issue:
➜ ~ alsamixer -c0
➜ ~ pactl list cards
Connection failure: Connection refused
pa_context_connect() failed: Connection refused
➜ ~ sudo pactl list cards
[sudo] password for sum:
[Edit] Is this normal ?
➜ ~ sudo find / -name pipewire-pulse.conf
/usr/share/pipewire/pipewire-pulse.conf
find: ‘/tmp/.mount_ButterKQeolc’: Permission denied
find: ‘/tmp/.mount_ButterNauECf’: Permission denied
/var/lib/flatpak/runtime/org.freedesktop.Sdk/x86_64/22.08/37618b0f49934fa47c1efb5f3c3e1d9ad50731c0144d4123996ac9db87287f40/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.freedesktop.Sdk/x86_64/23.08/3518892d2bda87abb977abf8b452d5c4400979056e02948617e9c0b9de04ebb9/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.freedesktop.Sdk/x86_64/21.08/6d6d5cb020cefade8c46a53b005d917658945160c0bb6dcc6bad9b4cca36fa4a/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.gnome.Platform/x86_64/44/31ef2cbe419c6d091616be29f7384b9f4601901643d9f8fc74c6d12f509af80b/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.gnome.Platform/x86_64/42/982438648e909ca4648ef41959440312b25bc1392bec2a7629d6b69824cf535e/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.gnome.Platform/x86_64/46/9a6b5e332285a0b9b455a9f3c1589ee85ef2b25ac0f2fa7b63ac90c679ae4756/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.gnome.Platform/x86_64/43/72c5f3d0de590e85995322e18b56731a4b7ed8b47d5fba615dae7ca5c6741930/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.gnome.Platform/x86_64/45/e66d066758b2a7b50a1cac032041fc1569c428f7cff988dcba554b3c035a191d/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.freedesktop.Platform/x86_64/22.08/f1b697054c6ad75a09adfad28193a68fcdba6a3791a41aaac121d8f57012ea7f/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.freedesktop.Platform/x86_64/23.08/232eeb0ac8c31b9768099c037e90fdfb96423bdd16d6d80e07628824ef2ed0b1/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.freedesktop.Platform/x86_64/21.08/8745946eed14ab6da3e21a642a467c994fe0f2bea1ad27a933464dca63ceabe4/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.kde.Platform/x86_64/6.5/d59237689cd510428d159691b9d72cb7d37871fe17eded9f3d048648ed694930/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.kde.Platform/x86_64/6.6/d9a07ad16df6b5858f924014ae6bc0803035276bd317da79e4a36bae2f68790b/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.kde.Platform/x86_64/5.15-23.08/4303bde2170527fa3720b9d77075ff6d1bb3895be3269a1760f86a301fb21211/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/runtime/org.kde.Platform/x86_64/5.15-22.08/662497f7f7e1b03c6b40affb3473c8412d703241770f04f8d6af68b8535ddc5a/files/share/pipewire/pipewire-pulse.conf
/var/lib/flatpak/app/sa.sy.bluerecorder/x86_64/stable/911033f5af5d53db423517659099ef0d4bef44788f51eb7886d56592fba45602/files/share/pipewire/pipewire-pulse.conf
find: ‘/run/user/1000/gvfs’: Permission denied
find: ‘/run/user/1000/doc’: Permission denied
find: ‘/proc/125809/task/125809/net’: Invalid argument
find: ‘/proc/125809/net’: Invalid argument
find: ‘/proc/151015’: No such file or directory
➜ ~ ls /etc/pipewire/
client.conf.d client-rt.conf.d jack.conf.d minimal.conf.d pipewire.conf.d pipewire-pulse.conf.d
➜ ~ ls /etc/pipewire/pipewire.conf.d
➜ ~ ls -lR /etc/pipewire/
/etc/pipewire/:
total 24
drwxr-xr-x 2 root root 4096 Feb 19 2022 client.conf.d
drwxr-xr-x 2 root root 4096 Feb 19 2022 client-rt.conf.d
drwxr-xr-x 2 root root 4096 Feb 19 2022 jack.conf.d
drwxr-xr-x 2 root root 4096 Feb 19 2022 minimal.conf.d
drwxr-xr-x 2 root root 4096 Feb 19 2022 pipewire.conf.d
drwxr-xr-x 2 root root 4096 Oct 8 2022 pipewire-pulse.conf.d
/etc/pipewire/client.conf.d:
total 0
/etc/pipewire/client-rt.conf.d:
total 0
/etc/pipewire/jack.conf.d:
total 0
/etc/pipewire/minimal.conf.d:
total 0
/etc/pipewire/pipewire.conf.d:
total 0
/etc/pipewire/pipewire-pulse.conf.d:
total 0
Restarting system is simpler than restarting multiple unknown pipewire/wireplumber services
If you prefer to restart services with systemctl I suggest using
systemctl --user list-unit-files | grep wire
to find all relevant systemd units
and systemctl --user status to check sockets and services for errors before restarting
Error response from sudo pactl list cards is expected - PipeWire is usually configured to allow one user account only to access audio
But error is not expected when sudo is not used
Try using pipewire command
pw-cli info all
Well, something seems wrong there !
➜ ~ systemctl --user list-unit-files | grep wire
pipewire-pulse.service disabled enabled
pipewire-session-manager.service alias -
pipewire.service disabled enabled
wireplumber.service enabled enabled
wireplumber@.service disabled enabled
pipewire-pulse.socket enabled enabled
pipewire.socket enabled enabled
● Error404
State: running
Units: 276 loaded (incl. loaded aliases)
Jobs: 0 queued
Failed: 0 units
Since: Wed 2024-04-03 08:01:35 CEST; 11h ago
systemd: 255.4-1-manjaro
├─app.slice
│ ├─app-dbus\x2d:1.11\x2dorg.a11y.atspi.Registry.slice
│ │ └─dbus-:1.11-org.a11y.atspi.Registry@0.service
│ │ └─1978 /usr/lib/at-spi2-registryd --use-gnome-session
│ ├─app-dbus\x2d:1.2\x2dorg.fedoraproject.Config.Printing.slice
│ │ └─dbus-:1.2-org.fedoraproject.Config.Printing@0.service
│ │ └─117138 /usr/bin/python3 /usr/share/system-config-printer/scp>
│ ├─app-dbus\x2d:1.2\x2dorg.flameshot.Flameshot.slice
│ │ └─dbus-:1.2-org.flameshot.Flameshot@0.service
│ │ └─13658 /usr/bin/flameshot
│ ├─app-dbus\x2d:1.2\x2dorg.gnome.Identity.slice
│ │ └─dbus-:1.2-org.gnome.Identity@0.service
│ │ └─2467 /usr/lib/goa-identity-service
│ ├─app-dbus\x2d:1.2\x2dorg.gnome.OnlineAccounts.slice
│ │ └─dbus-:1.2-org.gnome.OnlineAccounts@0.service
lines 1-23...skipping...
● Error404
State: running
Jobs: 0 queued
Failed: 0 units
├─app.slice
│ │ └─117138 /usr/bin/python3 /usr/share/system-config-printer/scp-dbus-service.py
│ │ └─2419 /usr/lib/goa-daemon
│ ├─app-dbus\x2d:1.2\x2dorg.xfce.Xfconf.slice
│ │ └─dbus-:1.2-org.xfce.Xfconf@60.service
│ │ └─181023 /usr/lib/xfce4/xfconf/xfconfd
│ ├─app-flatpak-com.slack.Slack-11475.scope
│ │ ├─11475 bwrap --args 41 com.slack.Slack
│ │ ├─11487 bwrap --args 41 xdg-dbus-proxy --args=43
│ │ ├─11488 xdg-dbus-proxy --args=43
│ │ ├─11494 bwrap --args 41 com.slack.Slack
│ │ ├─11495 /bin/bash /app/bin/com.slack.Slack
│ │ ├─11497 "/app/extra/slack -s --enable-features=WebRTCPipeWireCapturer"
│ │ ├─11509 "/app/extra/slack --type=zygote --no-zygote-sandbox"
│ │ ├─11513 cat
│ │ ├─11514 cat
│ │ ├─11551 /app/extra/chrome_crashpad_handler --monitor-self-annotation=ptype=crashpad-handler --no-upload-gzip --database=/home/sum/.var/app/com.slack.Slack/config/Slack/Crashpad "--url=https://s>
│ │ ├─11562 "/app/extra/slack --type=gpu-process --enable-logging --crashpad-handler-pid=41 --enable-crash-reporter=54293575-623b-4ed9-bf04-138c6c3f44b7,no_channel --user-data-dir=/home/sum/.var/ap>
│ │ ├─11569 "/app/extra/slack --type=utility --utility-sub-type=network.mojom.NetworkService --lang=fr --service-sandbox-type=none --enable-logging --crashpad-handler-pid=41 --enable-crash-reporter>
│ │ └─11687 "/app/extra/slack --type=utility --utility-sub-type=audio.mojom.AudioService --lang=fr --service-sandbox-type=none --enable-logging --crashpad-handler-pid=41 --enable-crash-reporter=542>
│ ├─app-flatpak-com.slack.Slack-11515.scope
│ │ ├─11515 bwrap --args 41 /app/bin/zypak-helper child - /app/extra/slack --type=zygote
│ │ ├─11524 bwrap --args 41 /app/bin/zypak-helper child - /app/extra/slack --type=zygote
│ │ ├─11525 "/app/extra/slack --type=zygote"
│ │ └─11602 "/app/extra/slack --type=renderer --crashpad-handler-pid=41 --enable-crash-reporter=54293575-623b-4ed9-bf04-138c6c3f44b7,no_channel --user-data-dir=/home/sum/.var/app/com.slack.Slack/co>
│ ├─appimagelauncherd.service
│ │ └─1902 /usr/bin/appimagelauncherd
│ ├─bamfdaemon.service
│ │ └─2311 /usr/lib/bamf/bamfdaemon
│ ├─dconf.service
│ │ └─2576 /usr/lib/dconf-service
│ ├─evolution-addressbook-factory.service
│ │ └─2498 /usr/lib/evolution-addressbook-factory
│ ├─evolution-calendar-factory.service
│ │ └─2459 /usr/lib/evolution-calendar-factory
│ ├─evolution-source-registry.service
│ │ └─2389 /usr/lib/evolution-source-registry
│ ├─flatpak-portal.service
│ │ └─11502 /usr/lib/flatpak-portal
│ ├─flatpak-session-helper.service
│ │ ├─11479 /usr/lib/flatpak-session-helper
│ │ ├─11484 server --sh -n /run/user/1000/.flatpak-helper/pkcs11-flatpak-11479 --provider p11-kit-trust.so "pkcs11:model=p11-kit-trust?write-protected=yes"
│ │ └─11599 p11-kit-remote --provider p11-kit-trust.so "pkcs11:model=p11-kit-trust?write-protected=yes"
│ ├─gnome-keyring-daemon.service
│ │ └─1906 /usr/bin/gnome-keyring-daemon --foreground --components=pkcs11,secrets --control-directory=/run/user/1000/keyring
│ ├─gpg-agent.service
│ │ └─1992 /usr/bin/gpg-agent --supervised
│ ├─xdg-desktop-portal-gtk.service
│ │ └─2303 /usr/lib/xdg-desktop-portal-gtk
│ └─xfce4-notifyd.service
│ └─2101 /usr/lib/xfce4/notifyd/xfce4-notifyd
├─init.scope
│ ├─1882 /usr/lib/systemd/systemd --user
│ └─1884 "(sd-pam)"
└─session.slice
├─at-spi-dbus-bus.service
│ ├─1965 /usr/lib/at-spi-bus-launcher
│ ├─1970 /usr/bin/dbus-broker-launch --config-file=/usr/share/defaults/at-spi2/accessibility.conf --scope user
│ └─1971 dbus-broker --log 4 --controller 9 --machine-id 866a42a3b558486baf84e7cf0ebd4270 --max-bytes 100000000000000 --max-fds 6400000 --max-matches 5000000000
├─dbus-broker.service
│ ├─1913 /usr/bin/dbus-broker-launch --scope user
│ └─1914 dbus-broker --log 4 --controller 10 --machine-id 866a42a3b558486baf84e7cf0ebd4270 --max-bytes 100000000000000 --max-fds 25000000000000 --max-matches 5000000000
├─gvfs-afc-volume-monitor.service
│ └─2566 /usr/lib/gvfs-afc-volume-monitor
├─gvfs-daemon.service
│ ├─ 1949 /usr/lib/gvfsd
│ ├─ 1955 /usr/lib/gvfsd-fuse /run/user/1000/gvfs -f
│ ├─ 2644 /usr/lib/gvfsd-trash --spawner :1.7 /org/gtk/gvfs/exec_spaw/0
│ ├─ 10304 /usr/lib/gvfsd-http --spawner :1.7 /org/gtk/gvfs/exec_spaw/1
│ ├─118689 /usr/lib/gvfsd-network --spawner :1.7 /org/gtk/gvfs/exec_spaw/2
│ └─118764 /usr/lib/gvfsd-dnssd --spawner :1.7 /org/gtk/gvfs/exec_spaw/4
├─gvfs-gphoto2-volume-monitor.service
│ └─2589 /usr/lib/gvfs-gphoto2-volume-monitor
├─gvfs-metadata.service
│ └─2661 /usr/lib/gvfsd-metadata
├─gvfs-mtp-volume-monitor.service
│ └─2595 /usr/lib/gvfs-mtp-volume-monitor
├─gvfs-udisks2-volume-monitor.service
│ └─2301 /usr/lib/gvfs-udisks2-volume-monitor
├─pipewire-pulse.service
│ └─2015 /usr/bin/pipewire-pulse
├─pipewire.service
│ └─2013 /usr/bin/pipewire
├─wireplumber.service
│ └─2014 /usr/bin/wireplumber
├─xdg-desktop-portal.service
│ └─2227 /usr/lib/xdg-desktop-portal
├─xdg-document-portal.service
│ ├─2267 /usr/lib/xdg-document-portal
│ └─2279 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
├─xdg-permission-store.service
│ └─2121 /usr/lib/xdg-permission-store
├─zeitgeist-fts.service
│ └─2244 /usr/lib/zeitgeist/zeitgeist-fts
└─zeitgeist.service
└─2207 /usr/bin/zeitgeist-daemon
➜ ~ pw-cli info all
Error: "failed to connect: Host is down"
Services are up and host is down (I have no idea of which host )
pw-cli response is similar to responses from PulseAudio tools
PipeWire Wiki - Troubleshooting - PipeWire Not Loading
PipeWire and Wireplumber have three main directories where its files are stored /usr/share/pipewire and /usr/share/wireplumber. It is recommended if you would like to make configuration changes that you copy them from /usr to the corresponding directories in /etc or your ~/.config folder.
The third directory is ~/.local/state/wireplumber which contains four files
default-nodes, default-profile, default-routes, and restore-stream.
These files store your default profile and volume levels so if you’re having profile or volume issues it may be that these files need to be deleted and refreshed.
Make sure your systemd services and sockets are enabled and started (as --user) this includes pipewire.service, pipewire.socket, pipewire-pulse.service, pipewire-pulse.socket and wireplumber.service.
Well, thank you for caring, you helped me reinvestigate.
It was so simple : just had to activate (it was shut down)
system
Closed
17 April 2024 02:48
10
