Hi all. Despite my best efforts I cannot get any audio output on this system. Using the same hardware, I can boot into another Linux system and have the sound working. The hardware is detected and enabled. How to diagnose this problem? Any ideas appreciated. My audio experience is mid level only.
inxi -czv8
Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
root=UUID=90ca14dd-52ca-484a-bd02-3602ebcdeeca rw quiet splash udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0 wm: kwin_x11 vt: 2
dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG B550M MORTAR MAX WIFI (MS-7C94) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.D0
date: 08/17/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 3.49 GiB (11.2%)
Array-1: capacity: 128 GiB slots: 4 modules: 2 EC: None max-module-size: 32 GiB note: est.
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64
total: 64 manufacturer: Kingston part-no: KF3200C16D4/16GX serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
pulseaudio -k
bash: pulseaudio: command not found
systemctl --user status wireplumber
β wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
Active: active (running) since Wed 2025-09-24 19:55:23 ACST; 14min ago
Invocation: 55525ba62d05446a9ac5093d9a69c047
Main PID: 1001 (wireplumber)
Tasks: 6 (limit: 38207)
Memory: 19.8M (peak: 20.7M)
CPU: 614ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
ββ1001 /usr/bin/wireplumber
Sep 24 19:55:23 Manj-New systemd[801]: Started Multimedia Service Session Manager.
Sep 24 19:55:24 Manj-New wireplumber[1001]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it instal>
Sep 24 19:55:24 Manj-New wireplumber[1001]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some cam>
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA ATI HDMI], device 3: HDMI 0 [ASUS PA238]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 1: ALC1220 Digital [ALC1220 Digital]
Subdevices: 0/1
Thanks nikgnomic
Sorry about this long copy/paste.
pactl list cards
Card #50
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "0"
api.alsa.card.longname = "HDA ATI HDMI at 0xfcb20000 irq 74"
api.alsa.card.name = "HDA ATI HDMI"
api.alsa.path = "hw:0"
api.alsa.split-enable = "true"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1.Priority = "-20"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:2d:00.1"
device.description = "Navi 21/23 HDMI/DP Audio Controller"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_2d_00.1"
device.nick = "HDA ATI HDMI"
device.plugged.usec = "9849644"
device.product.id = "0xab28"
device.product.name = "Navi 21/23 HDMI/DP Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:2b:00.0/0000:2c:00.0/0000:2d:00.1/sound/card0"
device.vendor.id = "0x1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
media.class = "Audio/Device"
spa.object.id = "2"
factory.id = "15"
client.id = "47"
object.id = "50"
object.serial = "50"
object.path = "alsa:acp:HDMI"
alsa.card = "0"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xfcb20000 irq 74"
alsa.mixer_name = "ATI R6xx HDMI"
alsa.components = "HDA:1002aa01,00aa0100,00100800"
alsa.id = "HDMI"
device.string = "0"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 5, sources: 0, priority: 1, available: yes)
Active Profile: pro-audio
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
device.product.name = "ASUS PA238"
iec958.codecs.detected = "[\"PCM\"]"
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-surround-extra4, output:hdmi-surround71-extra4
Card #51
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "1"
api.alsa.card.longname = "HD-Audio Generic at 0xfc900000 irq 76"
api.alsa.card.name = "HD-Audio Generic"
api.alsa.path = "hw:1"
api.dbus.ReserveDevice1 = "Audio1"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:2f:00.4"
device.description = "Starship/Matisse HD Audio Controller"
device.name = "alsa_card.pci-0000_2f_00.4"
device.nick = "HD-Audio Generic"
device.plugged.usec = "9873592"
device.product.id = "0x1487"
device.product.name = "Starship/Matisse HD Audio Controller"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1"
device.vendor.id = "0x1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
spa.object.id = "4"
factory.id = "15"
client.id = "47"
object.id = "51"
object.serial = "51"
object.path = "alsa:acp:Generic"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfc900000 irq 76"
alsa.mixer_name = "Realtek ALC1220"
alsa.components = "HDA:10ec1168,1462ec94,00100101"
alsa.id = "Generic"
device.string = "1"
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: no)
output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
pro-audio: Pro Audio (sinks: 2, sources: 2, priority: 1, available: yes)
Active Profile: output:iec958-stereo
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "line"
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "line"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, available)
Properties:
port.type = "headphones"
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
card.profile.port = "5"
Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
