hello
to day i upgrade my manjaro
after reboot
i play video , music , … but i dont have any sound !!!
in the PulseAudio Volume Controll > output devices > port by default use headphones port
before upgrade worked for me !!!
after upgrade i dont have any sound on this port
when i switch to line out plugged in i have sound !!!
and everything is ok !!!
this is normal or problem ?
when i enter this command to terminal
alsactl init
i got this result
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel PCH at 0xf7e00000 irq 29)
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
Found hardware: "HDA-Intel" "Realtek ALC887-VD" "HDA:10ec0887,1458a002,00100302" "0x1458" "0xa002"
Hardware is initialized using a generic method
and after , Headphones port is ok and have sound !!!
but after reboot problem is exist again !!!
