Okay, I think, I have to set second device as primary. But how
amixer -c1 info; echo; amixer -c1
Card sysdefault:1 'Generic_1'/'HD-Audio Generic at 0xe0a80000 irq 78'
Mixer name : 'Realtek ALC3234'
Components : 'HDA:10ec0255,102808d7,00100002'
Controls : 28
Simple ctrls : 15
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 78 [90%] [-6.75dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 82 [94%] [-3.75dB] [on]
Front Right: Playback 82 [94%] [-3.75dB] [on]
Simple mixer control 'Headphone Mic',0
Capabilities: pvolume pswitch cswitch cswitch-joined cswitch-exclusive
Capture exclusive group: 0
Capture channels: Mono
Limits: Playback 0 - 31
Mono: Capture [off]
Front Left: Playback 21 [68%] [-3.00dB] [off]
Front Right: Playback 21 [68%] [-3.00dB] [off]
Simple mixer control 'Headphone Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 2 [67%] [20.00dB]
Front Right: 2 [67%] [20.00dB]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Beep',0
Mono:
Front Left: Playback 18 [58%] [-7.50dB] [off]
Front Right: Playback 18 [58%] [-7.50dB] [off]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 0 [0%] [-17.25dB] [on]
Front Right: Capture 0 [0%] [-17.25dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Digital',0
Limits: Capture 0 - 120
Front Left: Capture 60 [50%] [0.00dB]
Front Right: Capture 60 [50%] [0.00dB]
Simple mixer control 'Headset Mic',0
Mono: Capture [on]
Front Left: Playback 23 [74%] [0.00dB] [off]
Front Right: Playback 23 [74%] [0.00dB] [off]
Simple mixer control 'Headset Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Internal Mic',0
Capabilities: cswitch cswitch-joined cswitch-exclusive
Mono: Capture [off]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
hdmi:CARD=Generic,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
default:CARD=Generic_1
HD-Audio Generic, ALC3234 Analog
Default Audio Device
sysdefault:CARD=Generic_1
front:CARD=Generic_1,DEV=0
Front output / input
surround21:CARD=Generic_1,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic_1,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic_1,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic_1,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic_1,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic_1,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=Generic_1
HD-Audio Generic
USB Stream Output
