So today i installed manjaro linux, trying it, i got problems, i cant even boot it properly ( i figured i can every time type sudo lightdm and it boots somehow) and i have no sound. I need help - i copy-pasted the kernel info or smth
ystem: Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=943451a6-76ef-49fe-836a-4dff75c15458 rw quiet apparmor=1 security=apparmor udev.log_priority=3 Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux Machine: Type: Desktop Mobo: Gigabyte model: H81M-S1 v: x.x serial: <filter> BIOS: American Megatrends v: FF date: 06/20/2014 Battery: Message: No system battery data found. Is one present? Memory: RAM: total: 3.73 GiB used: 1.72 GiB (46.2%) RAM Report: permissions: Unable to run dmidecode. Root privileges required. CPU: Info: Dual Core model: Intel Core i3-4170 bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 3 MiB bogomips: 29532 Speed: 1097 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 1097 2: 1098 3: 1098 4: 1098 Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable Type: mds mitigation: Clear CPU buffers; SMT vulnerable Type: meltdown mitigation: PTI Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling Type: srbds mitigation: Microcode Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel 4th Generation Core Processor Family Integrated Graphics vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:041e class-ID: 0300 Device-2: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300 Display: x11 server: X.Org 1.20.11 driver: loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0.0 screens: 1 Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4") s-diag: 485mm (19.1") Monitor-1: VGA-2 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8") diag: 508mm (20") OpenGL: renderer: llvmpipe (LLVM 11.1.0 256 bits) v: 4.5 Mesa 21.0.3 compat-v: 3.1 direct render: Yes Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403 Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403 Device-3: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403 Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes Sound Server-2: JACK v: 0.125.0 running: no Sound Server-3: PulseAudio v: 14.2 running: no Sound Server-4: PipeWire v: 0.3.26 running: no Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200 IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter> IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter> IP v6: <filter> type: noprefixroute scope: link WAN IP: <filter> Bluetooth: Message: No bluetooth data found. Logical: Message: No logical block device data found. RAID: Message: No RAID data found. Drives: Local Storage: total: 223.57 GiB used: 6.36 GiB (2.8%) SMART Message: Required tool smartctl not installed. Check --recommends ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: B1D1 scheme: MBR Message: No optical or floppy data found. Partition: ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 6.36 GiB (2.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 943451a6-76ef-49fe-836a-4dff75c15458 Swap: Alert: No swap data was found. Unmounted: Message: No unmounted partitions found. USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900 Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900 Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900 Device-1: 3-1:2 info: China Resource Semico USB Keyboard type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 100mA chip-ID: 1a2c:0c21 class-ID: 0301 Device-2: 3-3:3 info: SteelSeries ApS SteelSeries Rival 3 type: Mouse,HID driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 400mA chip-ID: 1038:184c class-ID: 0300 Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900 Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 44.0 C Fan Speeds (RPM): N/A gpu: nouveau fan: 2430 Info: Processes: 181 Uptime: 12m wakeups: 0 Init: systemd v: 247 tool: systemctl Compilers: gcc: N/A Packages: pacman: 1058 lib: 298 flatpak: 0 Shell: Bash v: 5.1.4 running-in: xfce4-terminal inxi: 3.3.04
