Hi guys,
I,m doing this from my aunt’s aged care home. This morning my aunt heard a crackle and then no audio.
I am clearly out of my depth, all advice appreciated
inxi -v7azy
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=513977d3-c70c-4431-ada2-64417674bf19 rw quiet splash apparmor=1
security=apparmor resume=UUID=e090e46f-903a-43c7-bd43-69facc50e49d
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: HP product: HP ProBook 470 G3 v: N/A
Mobo: HP model: 8102 v: KBC Version 40.73 serial: <superuser required>
part-nu: T3Z14PT#ABG uuid: <superuser required> UEFI: HP v: N78 Ver. 01.53
date: 11/24/2021
ID-1: BAT0 charge: 46.4 Wh (99.1%) condition: 46.8/55.1 Wh (85.0%)
volts: 12.2 min: 10.7 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 482
System RAM: total: 16 GiB available: 15.52 GiB used: 2.35 GiB (15.1%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: Bottom-Slot 1(top) type: DDR3 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 1600 MT/s volts: curr: 1.35 width (bits):
data: 64 total: 64 manufacturer: Hynix/Hyundai part-no: HMT41GS6BFR8A-PB
serial: <filter>
Device-2: Bottom-Slot 2(under) type: DDR3 detail: synchronous unbuffered
data: 64 total: 64 manufacturer: Samsung part-no: M471B1G73DB0-YK0
serial: <filter>
Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3098 min/max: 400/3100 scaling: driver: intel_pstate
governor: powersave cores: 1: 3098 2: 3098 3: 3098 4: 3098 bogomips: 20810
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: gather_data_sampling status: Vulnerable: No microcode
Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Topaz XT [Radeon R7 M260/M265 /
M340/M360 M440/M445 530/535 620/625 Mobile] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6900
class-ID: 0380 temp: 48.0 C
Device-3: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-6:3 chip-ID: 05c8:0383 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x219e built: 2015 res: 1600x900
dpi: 106 gamma: 1.2 size: 382x214mm (15.04x8.43") diag: 438mm (17.2")
ratio: 16:9 modes: 1600x900
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
surfaceless: drv: iris x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.58 GiB unified: yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
Local Storage: total: 1.02 TiB used: 209.38 GiB (20.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Netac model: SSD 120GB MX
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 17O4 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM035-1RK172
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: GPT
ID-1: / raw-size: 102.69 GiB size: 100.52 GiB (97.89%)
used: 10.93 GiB (10.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 513977d3-c70c-4431-ada2-64417674bf19
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: DE67-9D2F
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 198.45 GiB (21.7%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Data
uuid: a4103972-457e-4f6e-95b4-6376db536015
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: e090e46f-903a-43c7-bd43-69facc50e49d
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: YICHIP Wireless Device type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
Device-2: 1-6:3 info: Cheng Uei Precision Industry (Foxlink) HP HD Camera
type: video driver: uvcvideo interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 58.0 C pch: 49.0 C mobo: N/A gpu: amdgpu
temp: 48.0 C
Fan Speeds (rpm): N/A
Processes: 202 Power: uptime: 51m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1045 libs: 312 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.36
This will take some time as I have to try and resolve the problem onsite, meaning several 30 minute trips to my aunt’s facility.
