I’ve been on Manjaro GNOME for a bit now on my gram. Dual boot with Windows. The speaker output has never worked on Linux. This has been a known issue with my laptop (LG gram 16Z90R) for a while, and I just dealt with it by having sound come out of another source.
According to this recent post, it has been patched, and for my model specifically:
However even after updating, I got no sound. So I decided I would try reinstalling. I backed up my files, then did a clean install of the newest version of Manjaro GNOME yesterday.
The sound still doesn’t work. Maybe there’s another issue I am missing. I’d appreciate any help I could get.
inxi -Fazy
Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=de8f2cfc-9f59-49e1-ad09-6ecae993f5c2 rw quiet splash apparmor=1
security=apparmor resume=UUID=c097fc9f-2bb9-4dc2-ae2d-41a119bcf5fd
udev.log_priority=3
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: LG product: 16Z90R-A.ADC8U1 v: 0.1
serial: <superuser required> Chassis: type: 10 v: 0.1
Mobo: LG model: 16Z90R v: FAB1 serial: <superuser required> part-nu: EVO
uuid: <superuser required> UEFI: Phoenix v: R1ZH0330 X64 date: 02/03/2023
ID-1: BAT0 charge: 63.8 Wh (78.3%) condition: 81.5/90.0 Wh (90.6%)
power: 8.3 W volts: 8.3 min: 7.8 model: LG LGES-LG type: Li-ion
serial: <filter> status: discharging cycles: 181
Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4123
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 400 min/max: 400/5000:3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 83584
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: LG driver: i915
v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:a7a0 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 4GB Laptop GPU] vendor: LG
driver: nvidia v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 4 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25ab
class-ID: 0302
Device-3: Luxvisions Innotech LGE Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 30c9:0084
Display: x11 server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: LG Display 0x075b built: 2022 size-res: N/A
gamma: 1.2 diag: 405mm (15.9") modes: 2560x1600
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 15.17 GiB unified: yes
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: LG
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0401
API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 1.16 TiB used: 72.98 GiB (6.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TEJ9X101N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 51000A20 temp: 39.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: MZVLB256HAHQ-000H1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EXD70H1Q temp: 28.9 C
scheme: GPT
ID-1: / raw-size: 204.01 GiB size: 199.75 GiB (97.91%)
used: 72.98 GiB (36.5%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-1: swap-1 type: partition size: 34.17 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8
System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 32 GiB note: est. available: 31.06 GiB used: 3.09 GiB (9.9%)
Processes: 364 Power: uptime: 6m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 12.39 GiB services: gsd-power, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1131 libs: 313 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Compilers: N/A Shell: Bash v: 5.2.37
running-in: gnome-terminal inxi: 3.3.36
