**inxi -Fazy**
manjaro@manjaro ~]$ inxi -Fazy
Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2111 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Swift SF314-54G v: V1.17 serial: <filter>
Mobo: KBL model: Strongbow_KL v: V1.17 serial: <filter> UEFI: Insyde v: 1.17
date: 04/16/2021
ID-1: BAT0 charge: 19.2 Wh (49.7%) condition: 38.6/50.8 Wh (76.1%)
volts: 16.2 min: 15.3 model: SMP-SDI3320 AC14B7K type: Li-ion
serial: <filter> status: Charging
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: 9A cache: L2: 6 MiB
bogomips: 28808
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 3232
3: 2499 4: 1855 5: 1039 6: 900 7: 900 8: 900
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: srbds status: Vulnerable: No microcode
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Acer Incorporated ALI
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1d10 class-ID: 0302
Device-3: Realtek USB Boot type: USB driver: N/A bus-ID: 1-7:3
chip-ID: 0bda:5846 class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_soc_skl v: kernel alternate: snd_hda_intel bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0401
Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-5:2 chip-ID: 8087:0a2a class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
Local Storage: total: 1.2 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-60JC3T1
type: HDD rpm: 5400 serial: <filter> rev: 1A02 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB model: External USB3.0
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0204 scheme: GPT
Message: No partition data found.
System Temperatures: cpu: 48.5 C mobo: 42.0 C gpu: nouveau temp: 42.0 C
Processes: 234 Uptime: 32m wakeups: 3199 Memory: 7.65 GiB
used: 3.14 GiB (41.0%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1230 lib: 331 flatpak: 0 Shell: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.06
[manjaro@manjaro ~]$
```[alsa-info.sh](http://alsa-project.org/db/?f=d17e24954f21d7a6be41aca719a13951c1f16145)
Please read this:
At a minimum the section Linux has multiple kernels, then install 2 LTS kernels and see if the problem goes away automagically.
If that doesn’t help, try stopping pipewire and running on Pulseaudio only:
systemctl --user disable --now pipewire.socket && systemctl --user disable --now pipewire.service
If that helped and you don’t want to run this command every time you reboot, also execute a:
systemctl --user mask pipewire.socket
to disable it permanently.
This is unrelated to your current issue but:
Please read this
