Hi! I just installed Musescore, and I’m not getting any sound from it. Nothing else about Musescore seems to be having any issues. Pulse Audio control shows me a there’s a playback module for it, but doesn’t register any sound coming from the app. I’m having no audio issues from any other sources if that wasn’t already clear. I don’t even know how to go about diagnosing the issue! Yes I rebooted. Also double-checked for missing dependencies, no issues there.
Thanks in advance for your help.
Trying to think ahead to relevant diagnostic information, here’s the result of pulseaudio --dump-conf
### Read from configuration file: /etc/pulse/daemon.conf ###
daemonize = no
fail = yes
high-priority = yes
nice-level = -11
realtime-scheduling = yes
realtime-priority = 5
allow-module-loading = yes
allow-exit = yes
use-pid-file = yes
system-instance = no
local-server-type = user
cpu-limit = no
enable-shm = yes
flat-volumes = no
rescue-streams = yes
lock-memory = no
exit-idle-time = 20
scache-idle-time = 20
dl-search-path = /usr/lib/pulseaudio/modules
default-script-file = /etc/pulse/default.pa
load-default-script-file = yes
log-target =
log-level = notice
resample-method = auto
avoid-resampling = no
enable-remixing = yes
remixing-use-all-sink-channels = yes
remixing-produce-lfe = no
remixing-consume-lfe = no
lfe-crossover-freq = 0
default-sample-format = s16le
default-sample-rate = 44100
alternate-sample-rate = 48000
default-sample-channels = 2
default-channel-map = front-left,front-right
default-fragments = 4
default-fragment-size-msec = 25
enable-deferred-volume = yes
deferred-volume-safety-margin-usec = 8000
deferred-volume-extra-delay-usec = 0
shm-size-bytes = 0
log-meta = no
log-time = no
log-backtrace = 0
rlimit-fsize = -1
rlimit-data = -1
rlimit-stack = -1
rlimit-core = -1
rlimit-rss = -1
rlimit-as = -1
rlimit-nproc = -1
rlimit-nofile = 256
rlimit-memlock = -1
rlimit-locks = -1
rlimit-sigpending = -1
rlimit-msgqueue = -1
rlimit-nice = 31
rlimit-rtprio = 9
rlimit-rttime = 200000
and details of my sound card:
04:00.0 Multimedia audio controller: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
Subsystem: Creative Labs SB1550 Audigy 5/Rx
Flags: bus master, medium devsel, latency 32, IRQ 24
I/O ports at e000 [size=64]
Capabilities: <access denied>
Kernel driver in use: snd_emu10k1
Kernel modules: snd_emu10k1
