No sound - Dummy output
Fresh new minipc with Intel Tiger Lake 11th Gen CPU and freshly installed Manjaro Gnome and latest kernel 5.14. No sound.
This is the alsa information..
This is dmesg:
sudo dmesg | egrep -i '(snd|sof|alsa|hda)'
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=a3cb73c6-7b80-4e8e-94a7-1aae8fea64dd rw quiet udev.log_priority=3 snd_intel_dspcfg.dsp_driver=0
[    0.048043] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=a3cb73c6-7b80-4e8e-94a7-1aae8fea64dd rw quiet udev.log_priority=3 snd_intel_dspcfg.dsp_driver=0
[    0.818329] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.887561] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.887561] software IO TLB: mapped [mem 0x00000000326fb000-0x00000000366fb000] (64MB)
[    2.592886] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    2.592907] snd_hda_intel 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[    2.941013] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    2.941041] sof-audio-pci-intel-tgl 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[    2.941070] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[    2.941337] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[    3.194757] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.222100] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[    3.305915] sof-audio-pci-intel-tgl 0000:00:1f.3: No SoundWire machine driver found
[    3.305922] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 4
[    3.305926] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[    3.305936] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[    3.307850] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[    3.307858] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:18:0
[    3.307868] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[    3.394886] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[    3.394889] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:18:0
[    3.404514] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:18:1 Kernel ABI 3:18:0
[    3.419467] sof-audio-pci-intel-tgl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[    3.440148] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[    3.440152] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 4
[    3.440153] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 5
[    3.440154] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 6
[    3.440154] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 7
[    3.440155] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 8
[    3.457761] snd_hda_codec_hdmi ehdaudio0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
[    3.479199] input: sof-hda-dsp HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input12
[    3.483860] input: sof-hda-dsp HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input13
[    3.483890] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input14
I tried as suggested in some posts:
GRUB_CMDLINE_LINUX_DEFAULT=" quiet udev.log_priority=3 snd_hda_intel.dmic_detect=1"
I get all HDMI sources and can hear sounds if I connect headphones to the screen but this is a very suboptimal solution.
Here is the inxi --admin --verbosity=7 --filter --no-host --width result:
  Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop System: BESSTAR TECH LIMITED product: TL50 v: N/A
  serial: <filter>
  Mobo: BESSTAR Tech model: N/A serial: <filter>
  UEFI: American Megatrends LLC. v: TLTB9011 date: 07/08/2021
  Device-1: hidpp_battery_0
  model: Logitech MX Vertical Advanced Ergonomic Mouse serial: <filter>
  charge: 100% (should be ignored) rechargeable: yes status: Discharging
  RAM: total: 11.44 GiB used: 1.78 GiB (15.6%)
  Info: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
  arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 88
  cache: L2: 8 MiB bogomips: 38720
  Speed: 1200 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 1200 2: 1200
  3: 1200 4: 1200 5: 1201 6: 1202 7: 1201 8: 1201
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
  avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
  avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
  clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
  dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
  fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
  hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
  lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
  sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
  tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.1
  direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Realtek
  driver: sof-audio-pci-intel-tgl
  alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
  chip-ID: 8086:a0c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: no
  Device-1: Intel Ethernet I225-V driver: igc v: kernel port: efa0
  bus-ID: af:00.0 chip-ID: 8086:15f3 class-ID: 0200
  IF: enp175s0 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V driver: igc v: kernel port: efa0
  bus-ID: b0:00.0 chip-ID: 8086:15f3 class-ID: 0200
  IF: enp176s0 state: down mac: <filter>
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: efa0
  bus-ID: b1:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp177s0 state: up mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-5:4
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 8.63 GiB (1.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-A02
  lanes: 4 type: SSD serial: <filter> rev: ECFK52.9 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 350.67 GiB size: 344.09 GiB (98.13%) used: 8.61 GiB (2.5%)
  fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
  uuid: a3cb73c6-7b80-4e8e-94a7-1aae8fea64dd
  used: 25.3 MiB (26.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM uuid: 082A-789B
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 125.09 GiB fs: ntfs label: N/A
  uuid: 28C62B04C62AD23C
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 983 MiB fs: ntfs label: Recovery
  uuid: C2862B22862B1707
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 3-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-3:3 info: RominRonin CandyKeys Katana60 rev1 type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 7272:0c2c class-ID: 0300
  Device-3: 3-5:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 264 Uptime: 1m wakeups: 2 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 981 lib: 276 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.06
In the meantime I tried various Kernel versions without success, I went back to latest LTS.
I also switched to unstable as described in Switching Branches - Manjaro and then switched back to stable since there was no improvement.
This is the alsa upload with unstable: http://alsa-project.org/db/?f=c11ef3d7ea94c663e843411b194628d2025c13bf
Executing journalctl -xe --user-unit pulseaudio I got some interesting errors:
A stop job for unit UNIT has begun execution.
░░ The job identifier is 592.
set 15 18:50:55 mandarin pulseaudio[1250]: Failed to find a working profile.
set 15 18:50:55 mandarin pulseaudio[1250]: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_00_1f.3-platform-skl_hda_dsp_generic" card_name="alsa_card.pci-0000_00_1f.3-plat>
set 15 18:50:55 mandarin pulseaudio[1250]: Lost I/O connection in module "module-gsettings"
set 15 18:50:55 mandarin systemd[1106]: Stopped Sound Service.
░░ Subject: A stop job for unit UNIT has finished
░░ Defined-By: systemd
░░ A stop job for unit UNIT has finished.
░░ The job identifier is 592 and the job result is done.
-- Boot ec0285c7e4044c83bf685aa36e1dccdd --
set 15 20:51:16 mandarin systemd[1113]: Starting Sound Service...
░░ Subject: A start job for unit UNIT has begun execution
░░ A start job for unit UNIT has begun execution.
░░ The job identifier is 232.
set 15 20:51:16 mandarin pulseaudio[1256]: Failed to find a working profile.
set 15 20:51:16 mandarin pulseaudio[1256]: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_00_1f.3-platform-skl_hda_dsp_generic" card_name="alsa_card.pci-0000_00_1f.3-plat>
set 15 20:51:16 mandarin pulseaudio[1256]: stat('/etc/pulse/default.pa.d'): No such file or directory
set 15 20:51:16 mandarin systemd[1113]: Started Sound Service.
░░ Subject: A start job for unit UNIT has finished successfully
░░ A start job for unit UNIT has finished successfully.
set 15 20:51:16 mandarin pulseaudio[1256]: Tried to configure /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0 (alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic) more often than 5 ti>
lines 8-55/55 (END)
Urgh! Good find though, but it might mean:
You’ve got a very, very new machine, so even Linus Torvalds hasn’t caught up with you yet!
(I.E. You might have to wait for the 5.15-RC1 to come out)
:scream:
Having said that, if you want to try (=*no guarantees) audio output (mic will still not work), you might want to:
  • keep a bootable Manjaro USB stick handy to undo the following change:
  • add snd_intel_dspcfg.dsp_driver=1 as a grub boot option.
(If you don’t know how to do that, please shout out!)
:crossed_fingers:
Ahahah, I know it makes no sense to buy brand new hardware and install Linux on it but I could not resist.
No worries I’m not using this machine yet so I’m ready to do a fresh install at the end when I find the solution.
For who may be interested found instructions here but unfortunately did not work.
:sweat:
But I must say that there is something different, now I see 10 HDMI sources and one it is plugged… unfortunately no sound even connecting to the monitor.
Not needed on a rolling release! Just install the next kernel when it comes out! And as you seem to be new to this: please read this:
Like I said:
so just live without sound for the moment: we’ll figure it out in the future with a shiny new (unstable) kernel. :stuck_out_tongue_winking_eye:
:crossed_fingers:
Actually I may have spoken too soon. I don’t know why but I tried to disconnect and reconnect the HDMI cable and now I have crystal clear sound but I have to connect headphones to the screen. Still no microphone but already a step forward :partying_face:
Actually this is the reason why I moved to Manjaro in the first place :smiley:
Can you do me a favour and post a full inxi and a link to alsa-info.sh to see what changed so we have that for future reference for shiny happy people like you???
:innocent:
  parameters: BOOT_IMAGE=/boot/vmlinuz-linux
  root=UUID=59bca643-f205-4877-9d26-efb711f3b640 rw quiet loglevel=3
  nowatchdog snd_intel_dspcfg.dsp_driver=1
  serial: <filter>
  RAM: total: 11.44 GiB used: 1.98 GiB (17.3%)
  RAM Report:
  missing: Required tool dmidecode not installed. Check --recommends
  Speed: 3489 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 3489 2: 3183
  3: 3759 4: 1579 5: 1399 6: 1300 7: 2026 8: 1198
  Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver:
  loaded: intel unloaded: fbdev,modesetting,vesa display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4")
  diag: 690mm (27.2")
  driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
  bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.14.5-arch1-1 running: yes
  Sound Server-4: PipeWire v: 0.3.35 running: no
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: not found
  rfk-block: hardware: no software: no address: see --recommends
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 476.94 GiB used: 8.18 GiB (1.7%)
  lanes: 4 rotation: SSD serial: <filter> rev: ECFK52.9 scheme: GPT
  ID-1: / raw-size: 350.67 GiB size: 344.09 GiB (98.13%) used: 8.16 GiB (2.4%)
  uuid: 59bca643-f205-4877-9d26-efb711f3b640
  used: 25.5 MiB (26.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  fs: <superuser required> label: N/A uuid: 28C62B04C62AD23C
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 983 MiB fs: <superuser required>
  label: Recovery uuid: C2862B22862B1707
  Device-1: 3-2:5 info: RominRonin CandyKeys Katana60 rev1 type: Keyboard,HID
  Device-2: 3-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  class-ID: e001
  Processes: 241 Uptime: 14m wakeups: 2 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 826 lib: 205 Shell: Bash v: 5.1.8
  running-in: code inxi: 3.3.05
alsa-info.sh
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.0
!!Script ran on: Thu Sep 16 21:15:04 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      BESSTAR TECH LIMITED
Product Name:      TL50
Product Version:   Default string
Firmware Version:  TLTB9011
System SKU:        SKU1
Board Vendor:      BESSTAR Tech
Board Name:        Default string
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 	 15
/sys/bus/acpi/devices/ACPI000E:00/status 	 15
/sys/bus/acpi/devices/ESSX8336:00/status 	 15
/sys/bus/acpi/devices/INT33A1:00/status 	 15
/sys/bus/acpi/devices/INT340E:00/status 	 15
/sys/bus/acpi/devices/INT34C5:00/status 	 15
/sys/bus/acpi/devices/INT3F0D:00/status 	 15
/sys/bus/acpi/devices/INTC1051:00/status 	 15
/sys/bus/acpi/devices/LNXPOWER:00/status 	 1
/sys/bus/acpi/devices/LNXPOWER:01/status 	 1
/sys/bus/acpi/devices/LNXPOWER:02/status 	 1
/sys/bus/acpi/devices/LNXPOWER:03/status 	 1
/sys/bus/acpi/devices/LNXPOWER:04/status 	 1
/sys/bus/acpi/devices/LNXPOWER:05/status 	 1
/sys/bus/acpi/devices/LNXPOWER:06/status 	 1
/sys/bus/acpi/devices/LNXPOWER:07/status 	 1
/sys/bus/acpi/devices/LNXPOWER:08/status 	 1
/sys/bus/acpi/devices/MSFT0101:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0303:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:02/status 	 11
/sys/bus/acpi/devices/PNP0C02:04/status 	 11
/sys/bus/acpi/devices/PNP0C0C:00/status 	 15
/sys/bus/acpi/devices/PNP0C0E:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/PRP00001:00/status 	 11
/sys/bus/acpi/devices/PRP00001:01/status 	 11
/sys/bus/acpi/devices/device:06/status 	 15
/sys/bus/acpi/devices/device:94/status 	 15
/sys/bus/acpi/devices/device:95/status 	 15
/sys/bus/acpi/devices/device:96/status 	 15
/sys/bus/acpi/devices/device:98/status 	 15
/sys/bus/acpi/devices/device:99/status 	 15
/sys/bus/acpi/devices/device:9a/status 	 15
/sys/bus/acpi/devices/device:9f/status 	 15
/sys/bus/acpi/devices/device:a6/status 	 15
/sys/bus/acpi/devices/device:a7/status 	 15
/sys/bus/acpi/devices/device:a8/status 	 15
/sys/bus/acpi/devices/device:aa/status 	 15
/sys/bus/acpi/devices/device:ac/status 	 15
/sys/bus/acpi/devices/device:ae/status 	 15
!!Kernel Information
Kernel release:    5.14.0-0-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.14.0-0-MANJARO
Library version:    1.2.5.1
Utilities version:  1.2.5.1
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - No
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0x607d1a0000 irq 201
!!PCI Soundcards installed in the system
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller [8086:a0c8] (rev 20)
	Subsystem: Realtek Semiconductor Co., Ltd. Device [10ec:119e]
!!Modprobe options (Sound related)
snd_intel_dspcfg: dsp_driver=1
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 1
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Tigerlake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x80862812
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Device: name="HDMI 0", type="HDMI", device=3
  Converter: stream=1, channel=0
  Digital: Enabled GenLevel KAE
  Digital category: 0x2
  IEC Coding Type: 0x0
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0x1a]: 16 24 32
    formats [0x5]: PCM AC3
  Power states:  D0 D3 EPSS
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x0b000094: OUT Detect HBR HDMI DP
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x00:
  Unsolicited: tag=00, enabled=0
  Devices: 0
  Connection: 0
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Converter: stream=0, channel=0
  Digital: Enabled KAE
  Digital category: 0x0
  PCM:
  Power: setting=D3, actual=D3
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x40: OUT
  Devices: 0
  Connection: 4
     0x03* 0x05 0x07 0x09
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x08 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x0a [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0c [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0d [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0e [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0f [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 15 Sep 16 22:54 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 14 Sep 16 22:54 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116,  6 Sep 16 22:54 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116,  7 Sep 16 22:54 /dev/snd/pcmC0D11p
crw-rw----+ 1 root audio 116,  8 Sep 16 22:54 /dev/snd/pcmC0D12p
crw-rw----+ 1 root audio 116,  9 Sep 16 22:54 /dev/snd/pcmC0D13p
crw-rw----+ 1 root audio 116, 10 Sep 16 22:54 /dev/snd/pcmC0D14p
crw-rw----+ 1 root audio 116, 11 Sep 16 22:54 /dev/snd/pcmC0D15p
crw-rw----+ 1 root audio 116, 12 Sep 16 22:54 /dev/snd/pcmC0D16p
crw-rw----+ 1 root audio 116, 13 Sep 16 22:54 /dev/snd/pcmC0D17p
crw-rw----+ 1 root audio 116,  2 Sep 16 22:55 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116,  3 Sep 16 22:54 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116,  4 Sep 16 22:54 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116,  5 Sep 16 22:54 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116,  1 Sep 16 22:54 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Sep 16 22:54 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Sep 16 22:54 .
drwxr-xr-x 3 root root 380 Sep 16 22:54 ..
lrwxrwxrwx 1 root root  12 Sep 16 22:54 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 11: HDMI 5 [HDMI 5]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 12: HDMI 6 [HDMI 6]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 13: HDMI 7 [HDMI 7]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 14: HDMI 8 [HDMI 8]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 15: HDMI 9 [HDMI 9]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 16: HDMI 10 [HDMI 10]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 17: HDMI 11 [HDMI 11]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x607d1a0000 irq 201'
  Mixer name	: 'Intel Tigerlake HDMI'
  Components	: 'HDA:80862812,80860101,00100000'
  Controls      : 84
  Simple ctrls  : 12
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
Simple mixer control 'IEC958',5
  Mono: Playback [on]
Simple mixer control 'IEC958',6
  Mono: Playback [on]
Simple mixer control 'IEC958',7
  Mono: Playback [on]
Simple mixer control 'IEC958',8
  Mono: Playback [on]
Simple mixer control 'IEC958',9
  Mono: Playback [on]
Simple mixer control 'IEC958',10
  Mono: Playback [on]
Simple mixer control 'IEC958',11
  Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write locked'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value '100007006712000100000000000000004c2d320d433237463339300907070000'
		comment {
			access 'read volatile'
			type BYTES
			count 32
	control.7 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.13 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.25 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface CARD
		name 'HDMI/DP,pcm=11 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.33 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.34 {
		iface MIXER
		index 5
		comment {
			access 'read write'
			type IEC958
			count 1
	control.35 {
		iface MIXER
		index 5
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		device 11
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.37 {
		iface CARD
		name 'HDMI/DP,pcm=12 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.38 {
		iface MIXER
		index 6
		comment {
			access read
			type IEC958
			count 1
	control.39 {
		iface MIXER
		index 6
		comment {
			access read
			type IEC958
			count 1
	control.40 {
		iface MIXER
		index 6
		comment {
			access 'read write'
			type IEC958
			count 1
	control.41 {
		iface MIXER
		index 6
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.42 {
		iface PCM
		device 12
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.43 {
		iface CARD
		name 'HDMI/DP,pcm=13 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.44 {
		iface MIXER
		index 7
		comment {
			access read
			type IEC958
			count 1
	control.45 {
		iface MIXER
		index 7
		comment {
			access read
			type IEC958
			count 1
	control.46 {
		iface MIXER
		index 7
		comment {
			access 'read write'
			type IEC958
			count 1
	control.47 {
		iface MIXER
		index 7
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.48 {
		iface PCM
		device 13
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.49 {
		iface CARD
		name 'HDMI/DP,pcm=14 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.50 {
		iface MIXER
		index 8
		comment {
			access read
			type IEC958
			count 1
	control.51 {
		iface MIXER
		index 8
		comment {
			access read
			type IEC958
			count 1
	control.52 {
		iface MIXER
		index 8
		comment {
			access 'read write'
			type IEC958
			count 1
	control.53 {
		iface MIXER
		index 8
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.54 {
		iface PCM
		device 14
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.55 {
		iface CARD
		name 'HDMI/DP,pcm=15 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.56 {
		iface MIXER
		index 9
		comment {
			access read
			type IEC958
			count 1
	control.57 {
		iface MIXER
		index 9
		comment {
			access read
			type IEC958
			count 1
	control.58 {
		iface MIXER
		index 9
		comment {
			access 'read write'
			type IEC958
			count 1
	control.59 {
		iface MIXER
		index 9
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.60 {
		iface PCM
		device 15
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.61 {
		iface CARD
		name 'HDMI/DP,pcm=16 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.62 {
		iface MIXER
		index 10
		comment {
			access read
			type IEC958
			count 1
	control.63 {
		iface MIXER
		index 10
		comment {
			access read
			type IEC958
			count 1
	control.64 {
		iface MIXER
		index 10
		comment {
			access 'read write'
			type IEC958
			count 1
	control.65 {
		iface MIXER
		index 10
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.66 {
		iface PCM
		device 16
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.67 {
		iface CARD
		name 'HDMI/DP,pcm=17 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.68 {
		iface MIXER
		index 11
		comment {
			access read
			type IEC958
			count 1
	control.69 {
		iface MIXER
		index 11
		comment {
			access read
			type IEC958
			count 1
	control.70 {
		iface MIXER
		index 11
		comment {
			access 'read write'
			type IEC958
			count 1
	control.71 {
		iface MIXER
		index 11
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.72 {
		iface PCM
		device 17
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.73 {
		iface PCM
		device 3
		name 'Playback Channel Map'
		value.0 3
		value.1 4
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.74 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.75 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.76 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.77 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.78 {
		iface PCM
		device 11
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.79 {
		iface PCM
		device 12
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.80 {
		iface PCM
		device 13
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.81 {
		iface PCM
		device 14
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.82 {
		iface PCM
		device 15
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.83 {
		iface PCM
		device 16
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.84 {
		iface PCM
		device 17
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
--endcollapse--
!!All Loaded Modules
8250_dw
ac97_bus
acpi_pad
acpi_tad
aesni_intel
agpgart
atkbd
bluetooth
bpf_preload
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
drm
drm_kms_helper
dw_dmac
ecc
ecdh_generic
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
hid_logitech_dj
hid_logitech_hidpp
i2c_algo_bit
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
igc
igen6_edac
intel_cstate
intel_gtt
intel_hid
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_spi
intel_spi_pci
intel_tcc_cooling
intel_uncore
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
mac80211
mac_hid
mbcache
mei
mei_hdcp
mei_me
mousedev
mtd
pcspkr
pkcs8_key_parser
rfkill
rng_core
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_nor
spi_pxa2xx_platform
syscopyarea
sysfillrect
sysimgblt
thunderbolt
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
usbhid
vfat
video
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
xhci_pci_renesas
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
0x0c 0x18560010
0x0d 0x18560010
0x0e 0x18560010
0x0f 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
I switched to https://endeavouros.com/ because of more continuous and updated kernel and the sound is now working from USB and monitors. Still not working the on-board jack but I did not spend any time trying to fix it.
Kernel version: 5.14.12-arch1-1
