The painfo had a failure but also spat out lots of stuff.
The command failure is listed after the first command…
The output from the successful part of painfo was piped to a file and then pasted here.
If you want to make this post more tidy … feel free … code window didn’t work.
$ sudo dmesg | egrep -i '(snd|sof|alsa|hda)'
[sudo] password for bhante:
[ 0.465578] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@
linux.it>
[ 0.740664] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.740667] software IO TLB: mapped [mem 0x878c7000-0x8b8c7000] (64MB)
[ 2.659219] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0
x040100
[ 2.659225] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SST
driver
[ 3.010654] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x0
40100
[ 3.010660] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SST dr
iver
[ 3.115550] snd_soc_skl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops
[i915])
[ 3.168358] HDMI HDA Codec ehdaudio0D2: Max dais supported: 3
sudo pa-info >> ~/Desktop/painfo.txt
Connection failure: Connection refused
pa_context_connect() failed: Connection refused
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
Output information may be incomplete.
ls: cannot access '/proc/asound/card[0-9]': No such file or directory
alsactl: save_state:1595: No soundcards found...
cat: /tmp/alsa-info.orcYwEgzxb/alsactl.tmp: No such file or directory
> pulseaudio_ps_do
bhante 1174 0.0 0.1 945496 10124 ? S<sl 06:29 0:00 /usr/bin/pulseaudio --daemonize=no --log-target=journal
bhante 3253 0.0 0.0 3144 840 pts/3 S+ 07:00 0:00 grep pulseaudio
> which pulseaudio
/usr/bin/pulseaudio
> pidof pulseaudio
1174
> pulseaudio --version
pulseaudio 14.2
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 34
Server Protocol Version: 34
Is Local: yes
Client Index: 10
Tile Size: 65472
User Name: bhante
Host Name: subhuntu
Server Name: pulseaudio
Server Version: 14.2
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: auto_null
Default Source: auto_null.monitor
Cookie: fccd:1f50
> pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "14.2"
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #7
Argument:
Usage counter: n/a
Properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #8
Argument:
Usage counter: n/a
Properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #9
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #10
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #11
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #12
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #13
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #14
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #15
Argument: sink_name=auto_null sink_properties='device.description="Dummy Output"'
Usage counter: 0
Properties:
module.description = "Clocked NULL sink"
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #17
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is idle for too long, suspend it"
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #23
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Module #24
Argument: display=:0 xauthority=/home/bhante/.Xauthority
Usage counter: n/a
Properties:
module.description = "X11 credential publisher"
Module #25
Argument: display=:0 xauthority=/home/bhante/.Xauthority session_manager=local/subhuntu:@/tmp/.ICE-unix/1136,unix/subhuntu:/tmp/.ICE-unix/1136
Usage counter: n/a
Properties:
module.description = "X11 session management"
Sink #0
State: SUSPENDED
Description: Dummy Output
Driver: module-null-sink.c
Owner Module: 15
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: auto_null.monitor
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
device.description = "Dummy Output"
device.class = "abstract"
device.icon_name = "audio-card"
Formats:
pcm
Source #0
State: SUSPENDED
Description: Monitor of Dummy Output
Owner Module: 15
Mute: no
balance 0.00
Monitor of Sink: auto_null
Properties:
device.description = "Monitor of Dummy Output"
device.class = "monitor"
Formats:
pcm
Client #0
Driver: module-systemd-login.c
Owner Module: 19
Properties:
application.name = "Login Session 2"
systemd-login.session = "2"
Client #3
Driver: module-x11-xsmp.c
Owner Module: 25
Properties:
application.name = "XSMP Session on KDE as 10e8e3d6dd000161110079000000011360012"
xsmp.vendor = "KDE"
xsmp.client.id = "10e8e3d6dd000161110079000000011360012"
Client #4
Driver: protocol-native.c
Owner Module: 11
Properties:
application.name = "QPulse"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "34"
application.process.id = "1149"
application.process.user = "bhante"
application.process.host = "subhuntu"
application.process.binary = "plasmashell"
application.language = "en_US.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "9b45a6f4ec5f4f679bd8481c2febf9b9"
application.process.session_id = "2"
Client #6
Owner Module: 11
Properties:
application.name = "Firefox"
window.x11.screen = "0"
application.process.id = "1648"
application.process.binary = "firefox"
application.icon_name = "firefox"
Client #7
Owner Module: 11
Properties:
Client #11
Owner Module: 11
Properties:
application.name = "pactl"
application.process.id = "3258"
application.process.binary = "pactl"
application.language = "C"
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 33 Jan 20 06:29 /dev/snd/timer
crw-rw----+ 1 root audio 116, 1 Jan 20 06:29 /dev/snd/seq
> lsof /dev/snd/*
> jacks_do
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
> alsa_info_do
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Wed Jan 20 00:30:49 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Acer
Product Name: Swift SF313-51
Product Version: V1.10
Firmware Version: V1.10
System SKU: 0000000000000000
Board Vendor: KBL
Board Name: Snow_KL
!!ACPI Device Status Information
/sys/bus/acpi/devices/10251229:00/status 15
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT3403:02/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT344B:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 15
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0401:01/status 15
/sys/bus/acpi/devices/PNP0A05:04/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:01/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0D:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/SYNA7DAB:00/status 15
/sys/bus/acpi/devices/device:17/status 15
/sys/bus/acpi/devices/device:32/status 15
/sys/bus/acpi/devices/device:73/status 11
!!Kernel Information
Kernel release: 5.9.16-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.9.16-1-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
--- no soundcards ---
!!PCI Soundcards installed in the system
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d71] (rev 21)
Subsystem: Acer Incorporated [ALI] Device [1025:129d]
!!Loaded sound module options
!!ALSA Device nodes
!!Aplay/Arecord output
APLAY
aplay: device_list:274: no soundcards found...
ARECORD
arecord: device_list:274: no soundcards found...
!!Amixer output
!!Alsactl output
--startcollapse--
--endcollapse--
!!All Loaded Modules
ac
ac97_bus
acer_wireless
acer_wmi
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
ath
ath10k_core
ath10k_pci
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i8042
i915
idma64
input_leds
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
intel_wmi_thunderbolt
intel_xhci_usb_role_switch
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
libarc4
libps2
loop
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mousedev
msr
nls_cp437
nls_iso8859_1
parport
parport_pc
pcspkr
ppdev
processor_thermal_device
rapl
rc_core
rfcomm
rfkill
rng_core
roles
serio
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hdmi
snd_soc_skl
snd_soc_skl_hda_dsp
snd_soc_skl_ssp_clk
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_timer
soundcore
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
uas
uinput
usb_storage
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!ALSA/HDA dmesg
________________
> pulseaudio_ps_do
bhante 1174 0.0 0.1 945496 10132 ? S<sl 06:29 0:00 /usr/bin/pulseaudio --daemonize=no --log-target=journal
root 3748 0.0 0.0 3144 844 pts/3 S+ 07:01 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
1174
________________
pulseaudio 14.2
________________
> pactl info
________________
> pactl list
________________
## commenting.
; daemonize = no
; fail = yes
; allow-exit = yes
; enable-shm = yes
; lock-memory = no
; cpu-limit = no
; nice-level = -11
; log-target = auto
; log-meta = no
; log-time = no
; log-backtrace = 0
; flat-volumes = no
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-locks = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
## commenting.
; default-sink =
; default-source =
; default-server =
autospawn = no
; autospawn = yes
; cookie-file =
; enable-shm = yes
.fail
.else
.endif
.nofail
.fail
.endif
.endif
.endif
.endif
### loaded modules.
.nofail
.fail
.endif
### during runtime
.endif
.endif
# mode.
.else
.endif
.endif
### during runtime
> ls -alt /dev/snd/*
> lsof /dev/snd/*
________________
> jacks_do
________________
> aplay -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
________________
> alsa_info_do
!!Script ran on: Wed Jan 20 00:31:28 UTC 2021
ID_LIKE=arch
!!DMI Information
Manufacturer: Acer
Board Vendor: KBL
Board Name: Snow_KL
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Pulseaudio:
Running - Yes
Jack:
Running - No
!!ALSA Device nodes
APLAY
ARECORD
!!Amixer output
!!Alsactl output
--startcollapse--
--endcollapse--
ac
ac97_bus
acer_wireless
acer_wmi
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
ath
ath10k_core
ath10k_pci
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i8042
i915
idma64
input_leds
int3400_thermal
int3403_thermal
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
libarc4
libps2
loop
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mousedev
msr
nls_cp437
nls_iso8859_1
parport
parport_pc
pcspkr
ppdev
rapl
rc_core
rfcomm
rfkill
rng_core
roles
serio
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hdmi
snd_soc_skl
snd_soc_skl_hda_dsp
snd_soc_skl_ssp_clk
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_timer
soundcore
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
uas
uinput
usb_storage
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x_tables
xhci_hcd
xhci_pci
!!ALSA/HDA dmesg
[ 0.172139] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.172141] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.172142] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 2.623260] loop: module loaded
[ 2.659219] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 2.659225] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SST driver
[ 2.661656] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.987908] ath10k_pci 0000:01:00.0: firmware ver WLAN.RM.4.4.1-00157-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 90eebefb
[ 3.010654] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 3.010660] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SST driver
[ 3.046592] input: SYNA7DAB:00 06CB:CD40 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA7DAB:00/0018:06CB:CD40.0001/input/input12
[ 3.103857] mousedev: PS/2 mouse device common for all mice
[ 3.115550] snd_soc_skl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.116742] fbcon: i915drmfb (fb0) is primary device
[ 3.161602] ath10k_pci 0000:01:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 3.251216] fbcon: Taking over console
> pulseaudio_ps_do
root 4274 0.0 0.0 3144 780 pts/3 S+ 07:02 0:00 grep pulseaudio
> which pulseaudio
/usr/bin/pulseaudio
> pidof pulseaudio
1174
pulseaudio 14.2
> pactl info
> pactl list
## commenting.
; daemonize = no
; fail = yes
; allow-exit = yes
; enable-shm = yes
; lock-memory = no
; cpu-limit = no
; nice-level = -11
; log-target = auto
; log-meta = no
; log-time = no
; log-backtrace = 0
; flat-volumes = no
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-locks = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
## commenting.
; default-sink =
; default-source =
; default-server =
autospawn = no
; autospawn = yes
; cookie-file =
; enable-shm = yes
.fail
.else
.endif
.nofail
.fail
.endif
.endif
.endif
.endif
### loaded modules.
.nofail
.fail
.endif
### during runtime
.endif
.endif
# mode.
.else
.endif
.endif
### during runtime
> ls -alt /dev/snd/*
> lsof /dev/snd/*
> jacks_do
> aplay -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
> alsa_info_do
!!Script ran on: Wed Jan 20 00:32:02 UTC 2021
ID_LIKE=arch
!!DMI Information
Manufacturer: Acer
Board Vendor: KBL
Board Name: Snow_KL
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Pulseaudio:
Running - Yes
Jack:
Running - No
!!ALSA Device nodes
APLAY
ARECORD
!!Amixer output
!!Alsactl output
--startcollapse--
--endcollapse--
ac
ac97_bus
acer_wireless
acer_wmi
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
ath
ath10k_core
ath10k_pci
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i8042
i915
idma64
input_leds
int3400_thermal
int3403_thermal
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
libarc4
libps2
loop
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mousedev
msr
nls_cp437
nls_iso8859_1
parport
parport_pc
pcspkr
ppdev
rapl
rc_core
rfcomm
rfkill
rng_core
roles
serio
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hdmi
snd_soc_skl
snd_soc_skl_hda_dsp
snd_soc_skl_ssp_clk
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_timer
soundcore
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
uas
uinput
usb_storage
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x_tables
xhci_hcd
xhci_pci
!!ALSA/HDA dmesg
