No sound coming from my RME sound card
I installed ALSA and my sound card could be seen in the system but there is still no sound.
My sound card model is RME Hammerfall HDSP 9632
inxi -Fazy
  Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=bf1f4795-e218-4c64-849b-8ed7623d3a28 rw quiet apparmor=1
  security=apparmor resume=UUID=8537929b-909f-4f2b-a362-e8a9845931b0
  udev.log_priority=3
  Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: B150M-PLUS v: Rev X.0x serial: <filter>
  UEFI [Legacy]: American Megatrends v: 3402 date: 07/10/2017
  Info: Quad Core model: Intel Core i7-6700 bits: 64 type: MT MCP
  arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2
  L2 cache: 8192 KiB
  bogomips: 54417
  Speed: 2001 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 2000 2: 2001
  3: 2000 4: 2000 5: 2000 6: 2001 7: 2001 8: 2000
  Type: l1tf
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:1912
  Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
  alternate: fbdev,vesa display ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x318mm (40.0x12.5")
  s-diag: 1065mm (41.9")
  Monitor-1: HDMI1 res: 1920x1200 hz: 60 dpi: 90 size: 540x350mm (21.3x13.8")
  diag: 644mm (25.3")
  Monitor-2: HDMI2 res: 1920x1200 hz: 60 dpi: 90 size: 540x350mm (21.3x13.8")
  diag: 644mm (25.3")
  OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.2.3
  direct render: Yes
  Device-1: Xilinx RME Hammerfall DSP driver: snd_hdsp v: kernel
  bus ID: 04:00.0 chip ID: 10ee:3fc5
  Device-2: Logitech HD Webcam C910 type: USB driver: snd-usb-audio,uvcvideo
  bus ID: 1-7:8 chip ID: 046d:0821 serial: <filter>
  Sound Server: ALSA v: k5.9.11-3-MANJARO
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
  port: f040 bus ID: 00:1f.6 chip ID: 8086:15b8
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.82 TiB used: 1.25 TiB (32.7%)
  ID-1: /dev/sda vendor: Intel model: SSDSCKKR080H6 size: 74.53 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: G100 scheme: GPT
  ID-2: /dev/sdb vendor: OCZ model: ARC100 size: 111.79 GiB block size:
  physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1.01
  scheme: MBR
  ID-3: /dev/sdc vendor: Seagate model: ST31000528AS size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: CC37 scheme: MBR
  ID-4: /dev/sdd vendor: Western Digital model: WD30PURX-64P6ZY0
  size: 2.73 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
  ID-5: /dev/sde type: USB model: Kindle Internal Storage size: 1.33 GiB
  block size: physical: 512 B logical: 512 B serial: <filter> rev: 0100
  scheme: MBR
  ID-1: / raw size: 102.99 GiB size: 100.87 GiB (97.94%)
  used: 56.06 GiB (55.6%) fs: ext4 dev: /dev/sdb1
  ID-1: swap-1 type: partition size: 8.80 GiB used: 1020.0 MiB (11.3%)
  priority: -2 dev: /dev/sdb2
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 234 Uptime: 1d 3h 57m Memory: 15.50 GiB used: 11.82 GiB (76.3%)
  Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1123 lib: 333
  flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
pa-info
> pulseaudio_ps_do
tekno23     1060  0.0  0.0 1024368 11344 ?       S<sl Dec25   0:05 /usr/bin/pulseaudio --daemonize=no --log-target=journal
tekno23     1074  0.1  0.1 514060 17180 ?        Sl   Dec25   1:41 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libpulseaudio-plugin.so 9 14680074 pulseaudio PulseAudio Plugin Adjust the audio volume of the PulseAudio sound system
tekno23    18445  0.0  0.0   3144   856 pts/0    S+   14:49   0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
1060
________________
> pulseaudio --version
pulseaudio 14.0
________________
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 34
Server Protocol Version: 34
Is Local: yes
Client Index: 8
Tile Size: 65472
User Name: tekno23
Host Name: tekno23-VI
Server Name: pulseaudio
Server Version: 14.0
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_04_00.0.multichannel-output
Default Source: alsa_input.usb-046d_0821_CE7141A0-00.analog-stereo
Cookie: 7cb9:d398
________________
> pactl list
Module #0
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Lennart Poettering"
		module.description = "Automatically restore the volume/mute state of devices"
		module.version = "14.0"
Module #1
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore profile of cards"
Module #3
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Augment the property sets of streams with additional static information"
Module #4
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "David Henningsson"
		module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Detect available audio hardware and load matching drivers"
Module #6
	Argument: device_id="1" name="usb-046d_0821_CE7141A0-00" card_name="alsa_card.usb-046d_0821_CE7141A0-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
	Usage counter: 0
	Properties:
		module.description = "ALSA Card"
Module #7
	Argument: device_id="0" name="pci-0000_04_00.0" card_name="alsa_card.pci-0000_04_00.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
	Usage counter: 0
	Properties:
Module #8
	Argument: channels=2
	Usage counter: n/a
	Properties:
		module.description = "Adds JACK sink/source ports when JACK is started"
Module #9
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Frédéric Dalleau, Pali Rohár"
		module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #10
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "João Paulo Rechi Vita"
		module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #11
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #12
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Tanu Kaskinen"
		module.description = "D-Bus interface"
Module #13
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Native protocol (UNIX sockets)"
Module #14
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Sylvain Baubeau"
		module.description = "GSettings Adapter"
Module #15
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore the default sink and source"
Module #16
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Colin Guthrie"
		module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #17
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically set device of streams based on intended roles of devices"
Module #18
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "When a sink/source is idle for too long, suspend it"
Module #19
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Create a client for each ConsoleKit session of this user"
Module #20
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Create a client for each login session of this user"
Module #21
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #22
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Mute & cork streams with certain roles while others exist"
Module #23
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Detect when various filters are desirable"
Module #24
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Load filter sinks automatically when needed"
Module #25
	Argument: display=:0.0 xauthority=/home/tekno23/.Xauthority
	Usage counter: n/a
	Properties:
		module.description = "X11 credential publisher"
Module #26
	Argument: display=:0.0 xauthority=/home/tekno23/.Xauthority session_manager=local/tekno23-VI:@/tmp/.ICE-unix/993,unix/tekno23-VI:/tmp/.ICE-unix/993
	Usage counter: n/a
	Properties:
		module.description = "X11 session management"
Sink #0
	State: SUSPENDED
	Description: RME Hammerfall DSP Multichannel
	Driver: module-alsa-card.c
	Sample Specification: s32le 12ch 48000Hz
	Channel Map: front-left,front-right,rear-left,rear-right,front-center,lfe,side-left,side-right,aux0,aux1,aux2,aux3
	Owner Module: 7
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB,   rear-left: 65536 / 100% / 0.00 dB,   rear-right: 65536 / 100% / 0.00 dB,   front-center: 65536 / 100% / 0.00 dB,   lfe: 65536 / 100% / 0.00 dB,   side-left: 65536 / 100% / 0.00 dB,   side-right: 65536 / 100% / 0.00 dB,   aux0: 65536 / 100% / 0.00 dB,   aux1: 65536 / 100% / 0.00 dB,   aux2: 65536 / 100% / 0.00 dB,   aux3: 65536 / 100% / 0.00 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_04_00.0.multichannel-output.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE DECIBEL_VOLUME LATENCY
	Properties:
		alsa.resolution_bits = "32"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "RME Hammerfall HDSP 9632"
		alsa.id = "RME Hammerfall HDSP 9632"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "0"
		alsa.card_name = "Hammerfall DSP"
		alsa.long_card_name = "RME Hammerfall HDSP 9632 at 0xf7000000, irq 18"
		alsa.driver_name = "snd_hdsp"
		device.bus_path = "pci-0000:04:00.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1d.2/0000:03:00.0/0000:04:00.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "10ee"
		device.vendor.name = "Xilinx Corporation"
		device.product.id = "3fc5"
		device.product.name = "RME Hammerfall DSP"
		device.string = "plug:hw:0"
		device.buffering.buffer_size = "786432"
		device.buffering.fragment_size = "393216"
		device.access_mode = "mmap+timer"
		device.profile.name = "multichannel-output"
		device.profile.description = "Multichannel"
		device.description = "RME Hammerfall DSP Multichannel"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Formats:
		pcm
Source #0
	State: SUSPENDED
	Description: HD Webcam C910 Analog Stereo
	Sample Specification: s16le 2ch 32000Hz
	Owner Module: 6
	Mute: no
	Volume: front-left: 52057 /  79% / -6.00 dB,   front-right: 52057 /  79% / -6.00 dB
	        balance 0.00
	Base Volume: 135877 / 207% / 19.00 dB
	Monitor of Sink: n/a
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		alsa.name = "USB Audio"
		alsa.id = "USB Audio"
		alsa.device = "0"
		alsa.card = "1"
		alsa.card_name = "USB Device 0x46d:0x821"
		alsa.long_card_name = "USB Device 0x46d:0x821 at usb-0000:00:14.0-7, high speed"
		alsa.driver_name = "snd_usb_audio"
		device.bus_path = "pci-0000:00:14.0-usb-0:7:1.0"
		sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/sound/card1"
		udev.id = "usb-046d_0821_CE7141A0-00"
		device.bus = "usb"
		device.vendor.id = "046d"
		device.vendor.name = "Logitech, Inc."
		device.product.id = "0821"
		device.product.name = "HD Webcam C910"
		device.serial = "046d_0821_CE7141A0"
		device.form_factor = "webcam"
		device.string = "front:1"
		device.buffering.buffer_size = "256000"
		device.buffering.fragment_size = "128000"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "HD Webcam C910 Analog Stereo"
		device.icon_name = "camera-web-usb"
	Ports:
		analog-input-mic: Microphone (type: Mic, priority: 8700, availability unknown)
	Active Port: analog-input-mic
	Formats:
		pcm
Source #1
	State: SUSPENDED
	Description: Monitor of RME Hammerfall DSP Multichannel
	Owner Module: 7
	Mute: no
	        balance 0.00
	Monitor of Sink: alsa_output.pci-0000_04_00.0.multichannel-output
	Flags: DECIBEL_VOLUME LATENCY
	Properties:
		device.description = "Monitor of RME Hammerfall DSP Multichannel"
		device.class = "monitor"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Formats:
		pcm
Client #0
	Driver: module-systemd-login.c
	Owner Module: 20
	Properties:
		application.name = "Login Session 2"
		systemd-login.session = "2"
Client #1
	Driver: protocol-native.c
	Owner Module: 13
	Properties:
		application.name = "xfwm4"
		native-protocol.peer = "UNIX socket client"
		native-protocol.version = "34"
		window.x11.display = ":0"
		window.x11.screen = "0"
		application.process.id = "1050"
		application.process.user = "tekno23"
		application.process.host = "tekno23-VI"
		application.process.binary = "xfwm4"
		application.language = "en_US.utf8"
		application.process.machine_id = "78593ffb51814530ba0dfc450568d8be"
		application.process.session_id = "2"
Client #2
	Owner Module: 13
	Properties:
		application.name = "xfce4-pulseaudio-plugin"
		application.version = "0.4.3"
		application.id = "org.xfce.pulseaudio-plugin"
		application.icon_name = "multimedia-volume-control"
		application.process.id = "1074"
		application.process.binary = "wrapper-2.0"
Client #5
	Driver: module-x11-xsmp.c
	Owner Module: 26
	Properties:
		application.name = "XSMP Session on xfce4-session as 2e553248e-6280-4b88-8549-c1b9ee7f26e8"
		xsmp.vendor = "xfce4-session"
		xsmp.client.id = "2e553248e-6280-4b88-8549-c1b9ee7f26e8"
Client #6
	Owner Module: 13
	Properties:
		application.name = "Firefox"
		application.process.id = "1310"
		application.process.binary = "firefox"
		window.x11.display = ":0.0"
		application.icon_name = "firefox"
Client #9
	Owner Module: 13
	Properties:
		application.name = "pactl"
		application.process.id = "18450"
		application.process.binary = "pactl"
		application.language = "C"
Card #0
	Owner Module: 6
	Properties:
		alsa.card = "1"
		device.bus = "usb"
		device.string = "1"
		device.description = "HD Webcam C910"
	Profiles:
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
	Active Profile: input:analog-stereo
	Ports:
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
			Properties:
			Part of profile(s): input:analog-stereo
Card #1
	Owner Module: 7
	Properties:
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
		device.description = "RME Hammerfall DSP"
	Profiles:
		input:multichannel-input: Multichannel Input (sinks: 0, sources: 1, priority: 1, available: yes)
		output:multichannel-output: Multichannel Output (sinks: 1, sources: 0, priority: 100, available: yes)
		output:multichannel-output+input:multichannel-input: Multichannel Duplex (sinks: 1, sources: 1, priority: 101, available: yes)
	Active Profile: output:multichannel-output+input:multichannel-input
cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out.  Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116,  2 Dec 26 10:54 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116,  3 Dec 25 10:53 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116,  7 Dec 25 10:53 /dev/snd/pcmC1D0c
crw-rw----+ 1 root audio 116,  8 Dec 25 10:51 /dev/snd/controlC1
crw-rw----+ 1 root audio 116,  6 Dec 25 10:51 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  5 Dec 25 10:51 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116,  4 Dec 25 10:51 /dev/snd/midiC0D0
crw-rw----+ 1 root audio 116, 33 Dec 25 10:51 /dev/snd/timer
crw-rw----+ 1 root audio 116,  1 Dec 25 10:51 /dev/snd/seq
/dev/snd/by-id:
total 0
drwxr-xr-x 2 root root  60 Dec 25 10:51 .
drwxr-xr-x 4 root root 260 Dec 25 10:51 ..
lrwxrwxrwx 1 root root  12 Dec 25 10:51 usb-046d_0821_CE7141A0-00 -> ../controlC1
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  80 Dec 25 10:51 .
lrwxrwxrwx 1 root root  12 Dec 25 10:51 pci-0000:00:14.0-usb-0:7:1.0 -> ../controlC1
lrwxrwxrwx 1 root root  12 Dec 25 10:51 pci-0000:04:00.0 -> ../controlC0
lsof /dev/snd/*
COMMAND    PID    USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 1060 tekno23   21u   CHR  116,8      0t0  503 /dev/snd/controlC1
________________
> jacks_do
card=0
card=1
________________
> aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=DSP
    Hammerfall DSP, RME Hammerfall HDSP 9632
    Default Audio Device
usbstream:CARD=DSP
    Hammerfall DSP
    USB Stream Output
usbstream:CARD=U0x46d0x821
    USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
    Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=DSP
usbstream:CARD=DSP
    Hammerfall DSP
    USB Stream Output
sysdefault:CARD=U0x46d0x821
    USB Device 0x46d:0x821, USB Audio
front:CARD=U0x46d0x821,DEV=0
    Front output / input
    USB Stream Output
________________
> alsa_info_do
dmesg: read kernel buffer failed: Operation not permitted
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Sat Dec 26 12:49:17 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      System manufacturer
Product Name:      System Product Name
Product Version:   System Version
Firmware Version:  3402
System SKU:        SKU
Board Vendor:      ASUSTeK COMPUTER INC.
Board Name:        B150M-PLUS
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 	 15
/sys/bus/acpi/devices/INT33A1:00/status 	 15
/sys/bus/acpi/devices/INT340E:00/status 	 15
/sys/bus/acpi/devices/INT3F0D:00/status 	 15
/sys/bus/acpi/devices/LNXPOWER:00/status 	 1
/sys/bus/acpi/devices/LNXPOWER:01/status 	 1
/sys/bus/acpi/devices/LNXPOWER:02/status 	 1
/sys/bus/acpi/devices/LNXPOWER:03/status 	 1
/sys/bus/acpi/devices/LNXPOWER:04/status 	 1
/sys/bus/acpi/devices/LNXPOWER:05/status 	 1
/sys/bus/acpi/devices/LNXPOWER:06/status 	 1
/sys/bus/acpi/devices/LNXPOWER:07/status 	 1
/sys/bus/acpi/devices/LNXPOWER:08/status 	 1
/sys/bus/acpi/devices/LNXPOWER:09/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0a/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0b/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0c/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0d/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0e/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0f/status 	 1
/sys/bus/acpi/devices/LNXPOWER:10/status 	 1
/sys/bus/acpi/devices/LNXPOWER:11/status 	 1
/sys/bus/acpi/devices/LNXPOWER:12/status 	 1
/sys/bus/acpi/devices/LNXPOWER:13/status 	 1
/sys/bus/acpi/devices/LNXPOWER:14/status 	 1
/sys/bus/acpi/devices/LNXPOWER:15/status 	 1
/sys/bus/acpi/devices/LNXPOWER:16/status 	 1
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0501:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:02/status 	 15
/sys/bus/acpi/devices/PNP0C02:04/status 	 3
/sys/bus/acpi/devices/PNP0C02:06/status 	 3
/sys/bus/acpi/devices/PNP0C04:00/status 	 31
/sys/bus/acpi/devices/PNP0C0C:00/status 	 15
/sys/bus/acpi/devices/PNP0C0E:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/device:68/status 	 15
/sys/bus/acpi/devices/device:7a/status 	 11
!!Kernel Information
Kernel release:    5.9.11-3-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.9.11-3-MANJARO
Library version:    1.2.4
Utilities version:  1.2.4
!!Loaded ALSA modules
snd_hdsp
snd_usb_audio
!!Sound Servers on this system
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [DSP            ]: H-DSP - Hammerfall DSP
 1 [U0x46d0x821    ]: USB-Audio - USB Device 0x46d:0x821
!!PCI Soundcards installed in the system
04:00.0 Multimedia audio controller [0401]: Xilinx Corporation RME Hammerfall DSP [10ee:3fc5] (rev 9b)
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
!!Loaded sound module options
!!Module: snd_hdsp
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
!!Module: snd_usb_audio
	autoclock : Y
	delayed_register : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	device_setup : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	ignore_ctl_error : N
	pid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	quirk_alias : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	skip_validation : N
	use_vmalloc : Y
	vid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
!!USB Mixer information
--startcollapse--
USB Mixer: usb_id=0x046d0821, ctrlif=0, ctlerr=0
Card: USB Device 0x46d:0x821 at usb-0000:00:14.0-7, high speed
  Unit: 5
    Control: name="Mic Capture Volume", index=0
    Info: id=5, control=2, cmask=0x0, channels=1, type="S16"
    Volume: min=-18176, max=-4864, dBmin=-7100, dBmax=-1900
  Unit: 5
    Control: name="Mic Capture Switch", index=0
    Info: id=5, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
    Volume: min=0, max=1, dBmin=0, dBmax=0
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-id:
total 0
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: DSP [Hammerfall DSP], device 0: RME Hammerfall HDSP 9632 [RME Hammerfall HDSP 9632]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
card 1: U0x46d0x821 [USB Device 0x46d:0x821], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card DSP
Card hw:0 'DSP'/'RME Hammerfall HDSP 9632 at 0xf7000000, irq 18'
  Mixer name	: 'Xilinx FPGA'
  Components	: ''
  Controls      : 31
  Simple ctrls  : 24
Simple mixer control 'Line Out',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'Phones Gain',0
  Capabilities: enum
  Items: '0 dB' '-6 dB' '-12 dB'
  Item0: '0 dB'
Simple mixer control 'IEC958 Emphasis Bit',0
  Mono: Playback [off]
Simple mixer control 'IEC958 Input Connector',0
  Capabilities: enum
  Items: 'Optical' 'Coaxial' 'Internal' 'AES'
  Item0: 'Coaxial'
Simple mixer control 'IEC958 Non-audio Bit',0
Simple mixer control 'IEC958 Output also on ADAT1',0
Simple mixer control 'IEC958 Professional Bit',0
Simple mixer control 'AD Gain',0
  Capabilities: enum
  Items: '-10 dBV' '+4 dBu' 'Lo Gain'
  Item0: '+4 dBu'
Simple mixer control 'ADAT Lock Status',1
  Capabilities: enum
  Items: 'No Lock' 'Lock' 'Sync'
  Item0: 'No Lock'
Simple mixer control 'ADAT Sync Lock Status',0
  Capabilities: enum
  Item0: 'No Lock'
Simple mixer control 'Analog Extension Board',0
Simple mixer control 'AutoSync Reference',0
  Capabilities: enum
  Items: 'Word' 'ADAT Sync' 'IEC958' 'None' 'ADAT1' 'ADAT2' 'ADAT3'
  Item0: 'None'
Simple mixer control 'DA Gain',0
  Capabilities: enum
  Items: 'Hi Gain' '+4 dBu' '-10 dbV'
  Item0: '+4 dBu'
Simple mixer control 'DDS Sample Rate Offset',0
  Capabilities: volume volume-joined
  Capture channels: Mono
  Limits: -5000 - 5000
  Mono: 0 [50%]
Simple mixer control 'External Rate',0
  Capabilities: enum
  Items: '32000' '44100' '48000' '64000' '88200' '96000' 'None' '128000' '176400' '192000'
  Item0: 'None'
Simple mixer control 'Preferred Sync Reference',0
  Capabilities: enum
  Items: 'Word' 'IEC958' 'ADAT1'
  Item0: 'ADAT1'
Simple mixer control 'SPDIF Lock Status',0
  Capabilities: enum
  Item0: 'No Lock'
Simple mixer control 'SPDIF Sample Rate',0
  Capabilities: enum
  Item0: 'None'
Simple mixer control 'Sample Clock Source',0
  Capabilities: enum
  Items: 'AutoSync' 'Internal 32.0 kHz' 'Internal 44.1 kHz' 'Internal 48.0 kHz' 'Internal 64.0 kHz' 'Internal 88.2 kHz' 'Internal 96.0 kHz' 'Internal 128 kHz' 'Internal 176.4 kHz' 'Internal 192.0 KHz'
  Item0: 'Internal 48.0 kHz'
Simple mixer control 'Sample Clock Source Locking',0
Simple mixer control 'System Clock Mode',0
  Capabilities: enum
  Items: 'Master' 'Slave'
  Item0: 'Master'
Simple mixer control 'System Sample Rate',0
  Limits: 0 - 0
  Mono: 0 [0%]
Simple mixer control 'Word Clock Lock Status',0
  Capabilities: enum
  Item0: 'No Lock'
Simple mixer control 'XLR Breakout Cable',0
!!-------Mixer controls for card U0x46d0x821
Card hw:1 'U0x46d0x821'/'USB Device 0x46d:0x821 at usb-0000:00:14.0-7, high speed'
  Mixer name	: 'USB Mixer'
  Components	: 'USB046d:0821'
  Controls      : 4
  Simple ctrls  : 1
Simple mixer control 'Mic',0
  Capabilities: cvolume cvolume-joined cswitch cswitch-joined
  Limits: Capture 0 - 52
  Mono: Capture 46 [88%] [-25.00dB] [on]
!!Alsactl output
--startcollapse--
state.DSP {
	control.1 {
		iface PCM
		name 'IEC958 Playback Default'
		value '0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.2 {
		iface PCM
		name 'IEC958 Playback PCM Stream'
		comment {
			access 'read write inactive'
			type IEC958
			count 1
	control.3 {
		iface PCM
		name 'IEC958 Playback Con Mask'
		value '3b00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface PCM
		name 'IEC958 Playback Pro Mask'
		value '1f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.5 {
		iface HWDEP
		name Mixer
		value.0 0
		value.1 0
		value.2 0
		comment {
			access 'read write volatile'
			type INTEGER
			count 3
			range '0 - 65536 (step 1)'
	control.6 {
		iface MIXER
		name 'IEC958 Input Connector'
		value Coaxial
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Optical
			item.1 Coaxial
			item.2 Internal
			item.3 AES
	control.7 {
		iface MIXER
		name 'IEC958 Output also on ADAT1'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		name 'IEC958 Professional Bit'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'IEC958 Emphasis Bit'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.10 {
		iface MIXER
		name 'IEC958 Non-audio Bit'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.11 {
		iface MIXER
		name 'Sample Clock Source'
		value 'Internal 48.0 kHz'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 AutoSync
			item.1 'Internal 32.0 kHz'
			item.2 'Internal 44.1 kHz'
			item.3 'Internal 48.0 kHz'
			item.4 'Internal 64.0 kHz'
			item.5 'Internal 88.2 kHz'
			item.6 'Internal 96.0 kHz'
			item.7 'Internal 128 kHz'
			item.8 'Internal 176.4 kHz'
			item.9 'Internal 192.0 KHz'
	control.12 {
		iface MIXER
		name 'Sample Clock Source Locking'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.13 {
		iface MIXER
		name 'System Clock Mode'
		value Master
		comment {
			access read
			type ENUMERATED
			count 1
			item.0 Master
			item.1 Slave
	control.14 {
		iface MIXER
		name 'Preferred Sync Reference'
		value ADAT1
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Word
			item.1 IEC958
			item.2 ADAT1
	control.15 {
		iface MIXER
		name 'AutoSync Reference'
		value None
		comment {
			access read
			type ENUMERATED
			count 1
			item.0 Word
			item.1 'ADAT Sync'
			item.2 IEC958
			item.3 None
			item.4 ADAT1
			item.5 ADAT2
			item.6 ADAT3
	control.16 {
		iface MIXER
		name 'SPDIF Sample Rate'
		value None
		comment {
			access read
			type ENUMERATED
			count 1
			item.0 '32000'
			item.1 '44100'
			item.2 '48000'
			item.3 '64000'
			item.4 '88200'
			item.5 '96000'
			item.6 None
			item.7 '128000'
			item.8 '176400'
			item.9 '192000'
	control.17 {
		iface MIXER
		name 'System Sample Rate'
		value 48000
		comment {
			access read
			type INTEGER
			count 1
			range '0 - 0'
	control.18 {
		iface MIXER
		name 'External Rate'
		value None
		comment {
			access read
			type ENUMERATED
			count 1
			item.0 '32000'
			item.1 '44100'
			item.2 '48000'
			item.3 '64000'
			item.4 '88200'
			item.5 '96000'
			item.6 None
			item.7 '128000'
			item.8 '176400'
			item.9 '192000'
	control.19 {
		iface MIXER
		name 'Word Clock Lock Status'
		value 'No Lock'
		comment {
			access 'read volatile'
			type ENUMERATED
			count 1
			item.0 'No Lock'
			item.1 Lock
			item.2 Sync
	control.20 {
		iface MIXER
		name 'SPDIF Lock Status'
		value 'No Lock'
		comment {
			type ENUMERATED
			count 1
			item.0 'No Lock'
			item.1 Lock
			item.2 Sync
	control.21 {
		iface MIXER
		name 'ADAT Sync Lock Status'
		value 'No Lock'
		comment {
			type ENUMERATED
			count 1
			item.0 'No Lock'
			item.1 Lock
			item.2 Sync
	control.22 {
		iface MIXER
		name 'Line Out'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.23 {
		iface CARD
		name 'Precise Pointer'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface CARD
		name 'Use Midi Tasklet'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.25 {
		iface MIXER
		name 'ADAT Lock Status'
		index 1
		value 'No Lock'
		comment {
			type ENUMERATED
			count 1
			item.0 'No Lock'
			item.1 Lock
			item.2 Sync
	control.26 {
		iface MIXER
		name 'DA Gain'
		value '+4 dBu'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Hi Gain'
			item.1 '+4 dBu'
			item.2 '-10 dbV'
	control.27 {
		iface MIXER
		name 'AD Gain'
		value '+4 dBu'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '-10 dBV'
			item.1 '+4 dBu'
			item.2 'Lo Gain'
	control.28 {
		iface MIXER
		name 'Phones Gain'
		value '0 dB'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '0 dB'
			item.1 '-6 dB'
			item.2 '-12 dB'
	control.29 {
		iface MIXER
		name 'XLR Breakout Cable'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface MIXER
		name 'DDS Sample Rate Offset'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '-5000 - 5000'
	control.31 {
		iface MIXER
		name 'Analog Extension Board'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
state.U0x46d0x821 {
	control.1 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.2 {
		iface MIXER
		name 'Mic Capture Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.3 {
		iface MIXER
		name 'Mic Capture Volume'
		value 46
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 52'
			dbmin -7100
			dbmax -1900
			dbvalue.0 -2500
	control.4 {
		iface CARD
		name 'Keep Interface'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
--endcollapse--
!!All Loaded Modules
aesni_intel
agpgart
asus_wmi
battery
cdrom
cec
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
e1000e
ebtable_filter
ebtables
ee1004
eeepc_wmi
evdev
ext4
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
i2c_algo_bit
i2c_i801
i2c_smbus
i915
iTCO_vendor_support
iTCO_wdt
input_leds
intel_cstate
intel_gtt
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
ip6_tables
ip6table_filter
ip_tables
iptable_filter
irqbypass
jbd2
joydev
kvm
kvm_intel
loop
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mei_wdt
mousedev
mxm_wmi
pcspkr
rapl
rc_core
rfkill
snd
snd_hdsp
snd_hwdep
snd_pcm
snd_rawmidi
snd_seq_device
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
sparse_keymap
squashfs
sr_mod
syscopyarea
sysfillrect
sysimgblt
uas
uinput
usb_serial_simple
usb_storage
usbhid
usblp
uvcvideo
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!ALSA/HDA dmesg
You might need the hdspmixer package installed for sound to become active on the ADAT outs.
just noticed my kernel version is too recent (5.9.11)
anyway the drivers were not available even for kernel v.2
System data shows that the card is recognised in ALSA RME Hammerfall HDSP 9632 and has the correct driver snd_hdsp
[linux-audio-user] [RME HDSP 9632] No sound
there is no conventional mixer on this card, so alsamixer and other
“generic mixer” apps will do nothing. you need to use hdspmixer.
Check if you have alsa-tools installed for tools hdspmixer and hdspconf needed for this card to work in ALSA
(possibly hdsploader but I am not sure if that is needed for this card)
Screenshot_2020-12-30_23-41-26
I could install HDSPConf and HDSPMixer but none of them launch :frowning:
I suggest you reboot system
and try running hdspconf and hdspmixer in terminal
