No Sound after updates or reinstall
 Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
     Active: active (running) since Wed 2021-08-18 22:45:14 EDT; 21min ago
TriggeredBy: ● pulseaudio.socket
   Main PID: 2505 (pulseaudio)
     CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.service
             ├─2505 /usr/bin/pulseaudio --daemonize=no --log-target=journal
             └─2508 /usr/lib/pulse/gsettings-helper
Aug 18 22:45:14 headache systemd[742]: Starting Sound Service...
Aug 18 22:45:14 headache systemd[742]: Started Sound Service.
Aug 18 22:45:39 headache pulseaudio[2505]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply:> ]```
Could someone explain "GetManagedObjects() failed org.freedesktop.Dbus.Error.NoReply" ?
If my headphones work- does that indicate no sound from speakers is a driver issue?
Tonight I reinstalled Manjaro in case I loused up a setting but mostly because after another update, programs would start but then not work (settings, add/remove).  The little ball spun and spun and I had to force close.  The upgrade tonight- and assume my new reinstall too, included bluetooth for pulse audio.  I don't have bluetooth on this computer.  So I tried to uninstall pulse-audio service only to find that pulseaudio DEPENDS on pulseaudio-bluetooth!!! which explains why pulse audio didn't get reinstalled with the update.  Isn't it backwards to have audio dependent on a bluetooth service????
```pactl list short
0	module-device-restore
1	module-stream-restore
2	module-card-restore
3	module-augment-properties
4	module-switch-on-port-available
5	module-udev-detect
6	module-alsa-card	device_id="0" name="pci-0000_00_01.1" card_name="alsa_card.pci-0000_00_01.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
7	module-alsa-card	device_id="1" name="pci-0000_00_14.2" card_name="alsa_card.pci-0000_00_14.2" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
8	module-jackdbus-detect	channels=2
9	module-bluetooth-policy
10	module-bluetooth-discover
11	module-bluez5-discover
12	module-dbus-protocol
13	module-native-protocol-unix
14	module-gsettings
15	module-default-device-restore
16	module-always-sink
17	module-intended-roles
18	module-suspend-on-idle
19	module-console-kit
20	module-systemd-login
21	module-position-event-sounds
22	module-role-cork
23	module-filter-heuristics
24	module-filter-apply
0	alsa_output.pci-0000_00_14.2.analog-stereo	module-alsa-card.c	s16le 2ch 44100Hz	SUSPENDED
0	alsa_output.pci-0000_00_14.2.analog-stereo.monitor	module-alsa-card.c	s16le 2ch 44100Hz	SUSPENDED
1	alsa_input.pci-0000_00_14.2.analog-stereo	module-alsa-card.c	s16le 2ch 44100Hz	SUSPENDED
5	0	3	protocol-native.c	float32le 2ch 48000Hz
0	module-systemd-login.c	(null)
1	protocol-native.c	xfwm4
2	protocol-native.c	wrapper-2.0
3	protocol-native.c	firefox
6	protocol-native.c	pactl
0	audio-volume-change	s16le 2ch 44100Hz	0.067
0	alsa_card.pci-0000_00_01.1	module-alsa-card.c
1	alsa_card.pci-0000_00_14.2	module-alsa-card.c
inxi -A
Audio:     Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series]
           driver: snd_hda_intel
           Device-2: AMD FCH Azalia driver: snd_hda_intel
           Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
           Sound Server-2: PulseAudio v: 14.2 running: yes
inxi -F
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Hewlett-Packard product: HP Pavilion g7 Notebook PC
           v: 0690130000204610000620100 serial: <superuser required>
           Mobo: Hewlett-Packard model: 3568 v: 21.35 serial: <superuser required>
           BIOS: Hewlett-Packard v: F.40 date: 10/07/2011
CPU:       Info: Quad Core model: AMD A6-3420M APU with Radeon HD Graphics bits: 64 type: MCP cache:
           L2: 4 MiB
           Speed: 804 MHz min/max: 800/1500 MHz Core speeds (MHz): 1: 804 2: 804 3: 804 4: 799
Graphics:  Device-1: AMD Sumo [Radeon HD 6520G] driver: radeon v: kernel
           Device-2: Chicony HP Integrated Webcam type: USB driver: uvcvideo
           Display: x11 server: X.Org 1.20.11 driver: loaded: ati,radeon unloaded: modesetting
           resolution: 1600x900~60Hz
           OpenGL: renderer: AMD SUMO (DRM 2.50.0 / 5.10.34-1-MANJARO LLVM 11.1.0) v: 3.3 Mesa 21.0.3
Network:   Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
           IF: wlo1 state: up mac: 20:10:7a:09:ea:2c
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
           IF: eno1 state: down mac: ec:9a:74:57:f5:78
Drives:    Local Storage: total: 149.05 GiB used: 6.34 GiB (4.3%)
           ID-1: /dev/sda vendor: Western Digital model: WD1600BEKT-60PVMT0 size: 149.05 GiB
Partition: ID-1: / size: 145.65 GiB used: 6.34 GiB (4.4%) fs: ext4 dev: /dev/sda1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 60.6 C mobo: N/A gpu: radeon temp: 52.0 C
Info:      Processes: 167 Uptime: 1h 52m Memory: 5.29 GiB used: 2.09 GiB (39.4%) Shell: Bash
           inxi: 3.3.04```
You should update system again to get Pulseaudio v15.0 and then try this
Thanks- I will do that again. I did a complete reinstall of Manjaro OS & still no sound after updates (2 so far in less than 24 hrs). I replaced the physical speakers…still no sound. I tried this read out command found on the forum and though I’m not sure what pipewire even is, yet I found the output for “Active” very curious! I’m going to follow your command though and see if maybe now it will help. I’ve just about had it - I require sound next week for a student.
○ pipewire.service - Multimedia Service
   Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor p>
   Active: inactive (dead)
TriggeredBy: ● pipewire.socket
My system has no available updates- but I do see pulseaudio version 15.0.1 is installed. I did the command mentioned anyway but still no sound. Just ran systemctl --user status pulseaudio - The output shows an Error.
     Active: active (running) since Thu 2021-08-19 08:51:59 EDT; 9min ago
   Main PID: 849 (pulseaudio)
      Tasks: 7 (limit: 6477)
     Memory: 11.2M
        CPU: 2.922s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
             ├─849 /usr/bin/pulseaudio --daemonize=no --log-target=journal
             └─882 /usr/lib/pulse/gsettings-helper
Aug 19 08:51:55 headache systemd[737]: Starting Sound Service...
Aug 19 08:51:59 headache pulseaudio[849]: stat('/etc/pulse/default.pa.d'): No such file or directory
Aug 19 08:51:59 headache systemd[737]: Started Sound Service.
Aug 19 08:52:23 headache pulseaudio[849]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply.
~Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.```
I have no idea how to repair the possible causes it lists. Is the bus security policy- a bus- the audio bus? My sound card (like many computer these days) is built in to the motherboard. My network connection seems to be working for video visual and text upload to this forum. Since I redid Manjaro I have not bothered to setup the firewall because redoing the system wiped all my files. And, I’ve yet to install any software. I am running Manjaro as it installed yesterday from the network with no extras.
Please post more information about Pulseaudio configuration
pacmd dump
and more information about audio hardware in ALSA
sudo alsa-info.sh --upload
System data in OP is not showing hardware ID codes so I cannot narrow the search to find comparative data beyond 117 different models of `Pavilion g7’ listed on linux-hardware.org
Since my last post, since Firefox was displaying in the sound settings I decided to remove FF and install Chromium. Here is the output.
### Configuration dump generated at Thu Aug 19 14:40:45 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_01.1" card_name="alsa_card.pci-0000_00_01.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_00_14.2" card_name="alsa_card.pci-0000_00_14.2" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0.0 xauthority=/home/laurie/.Xauthority
load-module module-x11-xsmp display=:0.0 xauthority=/home/laurie/.Xauthority session_manager=local/headache:@/tmp/.ICE-unix/779,unix/headache:/tmp/.ICE-unix/779
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_14.2.analog-stereo 0x17d70
set-sink-mute alsa_output.pci-0000_00_14.2.analog-stereo no
suspend-sink alsa_output.pci-0000_00_14.2.analog-stereo no
set-source-volume alsa_output.pci-0000_00_14.2.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_14.2.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_14.2.analog-stereo.monitor no
set-source-volume alsa_input.pci-0000_00_14.2.analog-stereo 0x15c28
set-source-mute alsa_input.pci-0000_00_14.2.analog-stereo no
suspend-source alsa_input.pci-0000_00_14.2.analog-stereo no
set-card-profile alsa_card.pci-0000_00_01.1 off
set-card-profile alsa_card.pci-0000_00_14.2 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_00_14.2.analog-stereo
set-default-source alsa_input.pci-0000_00_14.2.analog-stereo
### EOF
and
[sudo] password for laurie:
/usr/bin/alsa-info.sh: line 661: tree: command not found
Uploading information to www.alsa-project.org```
which  is still running....
NEW EDIT---it finally must have timed out
```sudo alsa-info.sh --upload
Uploading information to www.alsa-project.org ...^C
[laurie@headache ~]$ sudo alsa-info.sh --upload
An error occurred while contacting www.alsa-project.org.
Your information was NOT automatically uploaded.
Your ALSA information is in /tmp/alsa-info.txt.4JeweXc7Yv
PS replacing FF did not work- still no speaker sound.
PSS This laptop does not have a bluetooth wifi adapter. Would it help to replace that card with one that has bluetooth?
Text from /tmp/alsa-info.txt.4JeweXc7Yv
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.0
!!Script ran on: Thu Aug 19 18:43:55 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      Hewlett-Packard
Product Name:      HP Pavilion g7 Notebook PC
Product Version:   0690130000204610000620100
Firmware Version:  F.40
System SKU:        A7A41UA#ABA
Board Vendor:      Hewlett-Packard
Board Name:        3568
!!ACPI Device Status Information
/sys/bus/acpi/devices/LNXVIDEO:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0303:00/status 	 15
/sys/bus/acpi/devices/PNP0C0A:00/status 	 15
/sys/bus/acpi/devices/PNP0C0C:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:01/status 	 11
/sys/bus/acpi/devices/PNP0C0F:02/status 	 11
/sys/bus/acpi/devices/PNP0C0F:03/status 	 11
/sys/bus/acpi/devices/PNP0C0F:04/status 	 11
/sys/bus/acpi/devices/PNP0C0F:05/status 	 11
/sys/bus/acpi/devices/PNP0C0F:06/status 	 11
/sys/bus/acpi/devices/PNP0C0F:07/status 	 11
/sys/bus/acpi/devices/SYN1E43:00/status 	 15
/sys/bus/acpi/devices/device:3f/status 	 15
!!Kernel Information
Kernel release:    5.10.59-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.10.59-1-MANJARO
Library version:    1.2.5.1
Utilities version:  1.2.5.1
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - No
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xf0344000 irq 31
 1 [Generic_1      ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xf0340000 irq 16
!!PCI Soundcards installed in the system
00:01.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series] [1002:1714]
	Subsystem: Hewlett-Packard Company Device [103c:3568]
00:14.2 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller [1022:780d] (rev 01)
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : N
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
	dmic_detect : Y
	enable_msi : -1
	pm_blacklist : Y
	power_save : 0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100200
No Modem Function Group found
Default PCM:
    rates [0x70]: 32000 44100 48000
    bits [0x2]: 16
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D3
  Power: setting=D0, actual=D0
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x201: Stereo Digital
  Converter: stream=0, channel=0
  Digital: Enabled
  Digital category: 0x0
  IEC Coding Type: 0x0
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Pincap 0x00000094: OUT Detect HDMI
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=01, enabled=1
  Connection: 1
     0x02
Codec: IDT 92HD81B1X5
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x111d7605
Subsystem Id: 0x103c3568
Revision Id: 0x100105
Default PCM:
    rates [0x5e0]: 44100 48000 88200 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Default Amp-Out caps: ofs=0x7f, nsteps=0x7f, stepsize=0x02, mute=1
  Power states:  D0 D1 D2 D3 D3cold S3D3cold CLKSTOP EPSS
GPIO: io=3, o=0, i=0, unsolicited=1, wake=1
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Power-Map: 0x71
Node 0x0a [Pin Complex] wcaps 0x400583: Stereo Amp-In
  Amp-In caps: N/A
  Amp-In vals:  [0x00 0x00]
  Pincap 0x0001173c: IN OUT HP EAPD Detect
    Vref caps: HIZ 50 GRD 80
  EAPD 0x2: EAPD
  Pin Default 0x40f000f0: [N/A] Other at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0xf, Sequence = 0x0
  Pin-ctls: 0x00: VREF_HIZ
  Unsolicited: tag=00, enabled=0
  Power states:
  Power: setting=D3, actual=D3
  Connection: 3
     0x13* 0x14 0x1c
Node 0x0b [Pin Complex] wcaps 0x400581: Stereo
  Pincap 0x0001001c: OUT HP EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x0221101f: [Jack] HP Out at Ext Front
    Conn = 1/8, Color = Black
    DefAssociation = 0x1, Sequence = 0xf
  Pin-ctls: 0xc0: OUT HP
  Power states:
  Connection: 3
     0x13* 0x14 0x1c
Node 0x0c [Pin Complex] wcaps 0x400583: Stereo Amp-In
  Control: name="Mic Boost Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Amp-In caps: N/A
  Pincap 0x00011734: IN OUT EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x02a11020: [Jack] Mic at Ext Front
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=02, enabled=1
  Power states:
  Connection: 3
     0x13* 0x14 0x1c
Node 0x0d [Pin Complex] wcaps 0x400501: Stereo
  Pincap 0x00010050: OUT EAPD Balanced
  EAPD 0x2: EAPD
  Pin Default 0x90170110: [Fixed] Speaker at Int N/A
    Conn = Analog, Color = Unknown
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Power states:
  Connection: 3
     0x13 0x14* 0x1c
Node 0x0e [Pin Complex] wcaps 0x400583: Stereo Amp-In
  Amp-In caps: N/A
  Pincap 0x00010034: IN OUT EAPD Detect
  EAPD 0x2: EAPD
  Pin-ctls: 0x00:
  Power states:
  Connection: 3
     0x13* 0x14 0x1c
Node 0x0f [Pin Complex] wcaps 0x400583: Stereo Amp-In
  Amp-In caps: N/A
  EAPD 0x2: EAPD
  Pin-ctls: 0x00:
  Power states:
  Connection: 3
     0x13* 0x14 0x1c
Node 0x10 [Pin Complex] wcaps 0x400500: Mono
  Pincap 0x00000010: OUT
  Pin-ctls: 0x00:
  Power states:
  Connection: 1
     0x1a
Node 0x11 [Pin Complex] wcaps 0x400483: Stereo Amp-In
  Control: name="Internal Mic Boost Volume", index=0, device=0
  Amp-In caps: N/A
  Amp-In vals:  [0x03 0x03]
  Pincap 0x00000024: IN Detect
  Pin Default 0xd5a30130: [Both] Mic at Int Top
    Conn = ATAPI, Color = Unknown
    DefAssociation = 0x3, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Power states:
Node 0x12 [Vendor Defined Widget] wcaps 0xf00503: Stereo Amp-In
  Amp-In caps: N/A
  Power states:
  Connection: 1
     0x20
Node 0x13 [Audio Output] wcaps 0xd0c05: Stereo Amp-Out R/L
  Control: name="Headphone Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Control: name="Headphone Playback Switch", index=0, device=0
  Device: name="92HD81B1X5 Analog", type="Audio", device=0
  Amp-Out caps: N/A
  Amp-Out vals:  [0x80 0x80]
  Converter: stream=5, channel=0
  Power states:
  Delay: 13 samples
Node 0x14 [Audio Output] wcaps 0xd0c05: Stereo Amp-Out R/L
  Control: name="Speaker Playback Volume", index=0, device=0
  Control: name="Speaker Playback Switch", index=0, device=0
  Amp-Out caps: N/A
  Amp-Out vals:  [0x7f 0x7f]
  Power states:
  Delay: 13 samples
Node 0x15 [Audio Input] wcaps 0x1d0541: Stereo
  Converter: stream=1, channel=0
  SDI-Select: 0
  Power states:
  Delay: 13 samples
  Connection: 1
     0x17
  Processing caps: benign=0, ncoeff=0
Node 0x16 [Audio Input] wcaps 0x1d0541: Stereo
  SDI-Select: 0
  Power states:
  Delay: 13 samples
  Connection: 1
     0x18
Node 0x17 [Audio Selector] wcaps 0x300d0d: Stereo Amp-Out R/L
  Control: name="Capture Volume", index=0, device=0
  Control: name="Capture Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x0f, stepsize=0x05, mute=1
  Amp-Out vals:  [0x0f 0x0f]
  Power states:
  Connection: 7
     0x0c 0x0e 0x0f 0x1b 0x11* 0x12 0x0a
Node 0x18 [Audio Selector] wcaps 0x300d0d: Stereo Amp-Out R/L
  Power states:
  Connection: 7
     0x0c* 0x0e 0x0f 0x1b 0x11 0x12 0x0a
Node 0x19 [Audio Selector] wcaps 0x300501: Stereo
  Power states:
  Connection: 3
     0x13* 0x14 0x1c
Node 0x1a [Audio Mixer] wcaps 0x200500: Mono
  Power states:
  Connection: 1
     0x19
Node 0x1b [Audio Mixer] wcaps 0x20050b: Stereo Amp-In
  Control: name="Mic Playback Volume", index=0, device=0
  Control: name="Mic Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Power states:
  Connection: 6
     0x0c 0x0e 0x0f 0x13 0x14 0x0a
Node 0x1c [Audio Selector] wcaps 0x30050d: Stereo Amp-Out
  Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=1
  Power states:
  Connection: 1
     0x1b
Node 0x1d [Audio Output] wcaps 0x4061d: Stereo Digital Amp-Out
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Digital:
  PCM:
    formats [0x5]: PCM AC3
  Power states:
  Delay: 4 samples
Node 0x1e [Audio Output] wcaps 0x4061d: Stereo Digital Amp-Out
  Digital:
  PCM:
  Power states:
  Delay: 4 samples
Node 0x1f [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000014: OUT Detect
  Pin-ctls: 0x00:
  Power states:
  Connection: 1
     0x1d
Node 0x20 [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000034: IN OUT Detect
  Pin-ctls: 0x00:
  Power states:
  Connection: 1
     0x1e
Node 0x21 [Beep Generator Widget] wcaps 0x70040c: Mono Amp-Out
  Control: name="Beep Playback Switch", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="Beep Playback Volume", index=0, device=0
  Amp-Out caps: ofs=0x03, nsteps=0x03, stepsize=0x17, mute=1
  Amp-Out vals:  [0x01]
  Power states:
Node 0x22 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116,  4 Aug 19 13:35 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  8 Aug 19 13:35 /dev/snd/controlC1
crw-rw----+ 1 root audio 116,  3 Aug 19 13:35 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116,  7 Aug 19 13:35 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116,  2 Aug 19 13:35 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116,  6 Aug 19 14:35 /dev/snd/pcmC1D0c
crw-rw----+ 1 root audio 116,  5 Aug 19 14:35 /dev/snd/pcmC1D0p
crw-rw----+ 1 root audio 116,  1 Aug 19 13:35 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Aug 19 13:35 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  80 Aug 19 13:35 .
drwxr-xr-x 3 root root 240 Aug 19 13:35 ..
lrwxrwxrwx 1 root root  12 Aug 19 13:35 pci-0000:00:01.1 -> ../controlC0
lrwxrwxrwx 1 root root  12 Aug 19 13:35 pci-0000:00:14.2 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: Generic_1 [HD-Audio Generic], device 0: 92HD81B1X5 Analog [92HD81B1X5 Analog]
  Subdevices: 0/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 0/1
!!Amixer output
!!-------Mixer controls for card Generic
Card sysdefault:0 'Generic'/'HD-Audio Generic at 0xf0344000 irq 31'
  Mixer name	: 'ATI R6xx HDMI'
  Components	: 'HDA:1002aa01,00aa0100,00100200'
  Controls      : 7
  Simple ctrls  : 1
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
!!-------Mixer controls for card Generic_1
Card sysdefault:1 'Generic_1'/'HD-Audio Generic at 0xf0340000 irq 16'
  Mixer name	: 'IDT 92HD81B1X5'
  Components	: 'HDA:111d7605,103c3568,00100105'
  Controls      : 23
  Simple ctrls  : 11
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Limits: Playback 0 - 127
  Mono: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 0 [0%] [-99999.99dB] [off]
  Front Right: Playback 0 [0%] [-99999.99dB] [off]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 127 [100%] [0.00dB] [on]
  Front Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Beep',0
  Mono: Playback 1 [33%] [-12.00dB] [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 15
  Front Left: Capture 15 [100%] [22.50dB] [on]
  Front Right: Capture 15 [100%] [22.50dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
  Front Left: 3 [100%] [30.00dB]
  Front Right: 3 [100%] [30.00dB]
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
!!Alsactl output
--startcollapse--
state.Generic {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.7 {
		iface PCM
		device 3
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
state.Generic_1 {
	control.1 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 127'
			dbmin -9999999
			dbmax 0
			dbvalue.0 -9999999
			dbvalue.1 -9999999
	control.2 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Speaker Playback Volume'
		value.0 127
		value.1 127
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 127'
			dbmin -9999999
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.4 {
		iface MIXER
		name 'Speaker Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.6 {
		iface MIXER
		name 'Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.7 {
		iface MIXER
		name 'Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.8 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.9 {
		iface MIXER
		name 'Capture Volume'
		value.0 15
		value.1 15
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 15'
			dbmin 0
			dbmax 2250
			dbvalue.0 2250
			dbvalue.1 2250
	control.10 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.11 {
		iface MIXER
		name 'Internal Mic Boost Volume'
		value.0 3
		value.1 3
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 3000
			dbvalue.1 3000
	control.12 {
		iface MIXER
		name 'Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.13 {
		iface MIXER
		name 'Beep Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		name 'Beep Playback Volume'
		value 1
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 3'
			dbmin -1800
			dbmax 0
			dbvalue.0 -1200
	control.15 {
		iface MIXER
		name 'Master Playback Volume'
		value 127
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 127'
			dbmin -9999999
			dbmax 0
			dbvalue.0 0
	control.16 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.17 {
		iface CARD
		name 'Internal Mic Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.18 {
		iface CARD
		name 'Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.19 {
		iface CARD
		name 'Front Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface CARD
		name 'Speaker Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.21 {
		iface PCM
		value.0 3
		value.1 4
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.22 {
		iface PCM
		name 'Capture Channel Map'
		value.0 3
		value.1 4
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.23 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_cpufreq
agpgart
ccm
ccp
cdrom
cec
cfg80211
crc16
crc32c_generic
crypto_user
drm
drm_kms_helper
ext4
fb_sys_fops
fuse
hp_wmi
i2c_algo_bit
i2c_piix4
ip_tables
irqbypass
jbd2
joydev
k10temp
kvm
ledtrig_audio
libarc4
libphy
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mmc_core
mousedev
pcspkr
psmouse
r8169
radeon
realtek
rfkill
rng_core
rtl8192c_common
rtl8192ce
rtl_pci
rtlwifi
rtsx_pci
rtsx_pci_sdmmc
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_idt
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_core
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sp5100_tco
sparse_keymap
squashfs
sr_mod
syscopyarea
sysfillrect
sysimgblt
ttm
uinput
uvcvideo
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x_tables
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x03 0x18560010
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x0a 0x40f000f0
0x0b 0x0221101f
0x0c 0x02a11020
0x0d 0x90170110
0x0e 0x40f000f0
0x0f 0x40f000f0
0x10 0x40f000f0
0x11 0xd5a30130
0x1f 0x40f000f0
0x20 0x40f000f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[    0.278650] ACPI: Added _OSI(Linux-Dell-Video)
[    0.278652] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.278654] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[   17.879497] [drm] Connector 2:
[   17.879498] [drm]   HDMI-A-1
[   17.879499] [drm]   HPD3
[   18.095271] fbcon: radeondrmfb (fb0) is primary device
[   18.192820] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input9
[   18.294978] rtl8192ce: Chip Version ID: B_CHIP_88C
[   18.304366] rtl8192ce: Using firmware rtlwifi/rtl8192cfw.bin
[   18.313441] snd_hda_codec_idt hdaudioC1D0: autoconfig for 92HD81B1X5: line_outs=1 (0xd/0x0/0x0/0x0/0x0) type:speaker
[   18.313447] snd_hda_codec_idt hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   18.313450] snd_hda_codec_idt hdaudioC1D0:    hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
[   18.313452] snd_hda_codec_idt hdaudioC1D0:    mono: mono_out=0x0
[   18.313454] snd_hda_codec_idt hdaudioC1D0:    inputs:
[   18.313457] snd_hda_codec_idt hdaudioC1D0:      Internal Mic=0x11
[   18.313460] snd_hda_codec_idt hdaudioC1D0:      Mic=0xc
[   18.314578] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[   18.348644] rtl8192ce 0000:01:00.0 wlo1: renamed from wlan0
[   18.356603] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input10
[   18.356757] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input11
[   18.439478] Console: switching to colour frame buffer device 200x56```
Are you using HDMI or (internal?) AMD FCH Azalia for sound?
Did you change kernel on upgrade?
ref
Did you reboot afterwards?
My HP G7 AMD is still having sound issues. Steps I’ve tried:
  • List item
repartioned & reinstalled Manjaro
installed immediate updates
installed recent upgrades (chromium/ff mostly)
followed notice to upgrade kernel (from recommended LSK to 5.13
I’ve tried suggestions on the forum and also read other Linux flavors complaint about recent no sound, but I am really at a loss. Is there a driver or something from AMD/HP that I need or a command to make it see the soundcard? On boot there is a message about IRQ 13 & 18 that seems peculiar- could the IRQ addy be wrong and is there a way I could fix that myself as in dos or old windows?
I’m posting some information here hoping someone can help.
COMMAND   PID   USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 857 laurie  mem    CHR  116,5           412 /dev/snd/pcmC1D0p
pulseaudi 857 laurie   16u   CHR  116,8      0t0  417 /dev/snd/controlC1
pulseaudi 857 laurie   18u   CHR  116,4      0t0  390 /dev/snd/controlC0
pulseaudi 857 laurie   24u   CHR  116,8      0t0  417 /dev/snd/controlC1
pulseaudi 857 laurie   29u   CHR  116,8      0t0  417 /dev/snd/controlC1
pulseaudi 857 laurie   44u   CHR  116,8      0t0  417 /dev/snd/controlC1
pulseaudi 857 laurie   47u   CHR  116,5      0t0  412 /dev/snd/pcmC1D0p
this is now after Kernel upgrade to 5.13 today:
### Configuration dump generated at Mon Sep 13 09:56:26 2021
set-sink-volume alsa_output.pci-0000_00_14.2.analog-stereo 0x10000
set-source-volume alsa_input.pci-0000_00_14.2.analog-stereo 0xfffd
set-source-mute alsa_input.pci-0000_00_14.2.analog-stereo yes
suspend-source alsa_input.pci-0000_00_14.2.analog-stereo yes
### EOF
I retried this:
this is a list of what is running pulseaudio- but has no speaker sound
and once again:
System:    Host: headache Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0
           cache: L2: 4 MiB
           Speed: 800 MHz min/max: 800/1500 MHz Core speeds (MHz): 1: 800 2: 801 3: 893 4: 899
           Display: x11 server: X.Org 1.20.13 driver: loaded: ati,radeon unloaded: modesetting
           OpenGL: renderer: AMD SUMO (DRM 2.50.0 / 5.13.13-1-MANJARO LLVM 12.0.1)
           v: 3.3 Mesa 21.2.1
           Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
           Sound Server-2: PulseAudio v: 15.0 running: yes
Drives:    Local Storage: total: 149.05 GiB used: 12.26 GiB (8.2%)
Partition: ID-1: / size: 145.65 GiB used: 12.26 GiB (8.4%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 48.9 C mobo: N/A gpu: radeon temp: 47.0 C
Info:      Processes: 189 Uptime: 55m Memory: 5.28 GiB used: 1.71 GiB (32.3%) Shell: Bash
           inxi: 3.3.06
I have tried clearing out the database / cookies and rebooting several times but not since kernel upgraded today so I will try that again and remove this msg if there is any change within a half hour.
After I wiped my system, with the exception of Chromium I haven’t installed any other software, to try to figure this out without compounding the problem. Chromium does seem to have an issue with a keyring not found message that requests my password. The nag screen pops up 3x and can be escaped out of. I do notice that one of my browsers actually displayed my one saved password rather than putting it in hidden asteric*s, - maybe due to my escaping the keyring password request???
