Hi,
when i mute my sound (click on the speaker icon) and then unmute it again, i have no sound and need to restart my system.
when i play musik, the “bar” from the sound menu is moving like there is sound, but nothing to hear.
systemctl --user restart pulseaudio.service
is not working
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset: enabled)
Active: active (running) since Thu 2023-06-29 14:54:22 CEST; 2min 29s ago
TriggeredBy: ● pulseaudio.socket
Main PID: 50371 (pulseaudio)
Tasks: 12 (limit: 76653)
Memory: 10.7M
CPU: 346ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
├─50371 /usr/bin/pulseaudio --daemonize=no --log-target=journal
└─50385 /usr/lib/pulse/gsettings-helper
Jun 29 14:54:22 garog-manjaro systemd[903]: Starting Sound Service...
Jun 29 14:54:22 garog-manjaro pulseaudio[50371]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Jun 29 14:54:22 garog-manjaro systemd[903]: Started Sound Service.
Jun 29 14:54:22 garog-manjaro pulseaudio[50371]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with exp>
any advice here ?
thank you
