No sound after sleep mode
I have a Xioami notebook pro laptop on fresh Manjaro GNOME.
After the laptop goes in sleep/hibernate mode, there is no sound that comes out of the speakers. The system settings (settings>sounds) are detecting music is being played and the headphones are working fine after sleep. The issue is only related to the speakers integrated in the laptop. As a quick fix, I need to reboot to have the speakers to work again.
I tried to use method that I had found:
$ sudo su -
$ echo 1 > /sys/bus/pci/devices/0000:00:1f.3/remove
$ echo 1 > /sys/bus/pci/rescan
But nothing happens after any of this commands. Cursor just blinking, tab in terminal looks frozen. Output device in GNOME Settings changes to dummy output.
Additional hardware info:
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
$ cat /proc/asound/cards
0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xb4314000 irq 157
$ lspci -nnk | grep -A2 Audio
00:1f.3 Audio device [0403]: Intel Corporation Device [8086:02c8]
	Subsystem: Xiaomi Device [1d72:1905]
	Kernel driver in use: snd_hda_intel
pacmd list-cards
1 card(s) available.
    index: 0
	driver: <module-alsa-card.c>
	owner module: 6
	properties:
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xb4314000 irq 157"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "02c8"
		device.string = "0"
		device.description = "Built-in Audio"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
For me disabling pipewire and restarting pulsaudio did the trick.
systemctl --user disable --now pipewire.socket
systemctl --user disable --now pipewire.service
systemctl --user restart pulseaudio.service
I also masked pipewire just to make sure.
@chromsky Thank you very much!
After disabling pipewire I added the restart audio script to /lib/systemd/system-sleep/99_restart_sound and now sound working after waking up.
#!/bin/sh
case "$1" in
    post)
        DEVICE_ID=`lspci -D |grep Audio|awk '{print $1}'`
        echo 1 > /sys/bus/pci/devices/${DEVICE_ID}/remove
        sleep 1
esac
The file must be executable:
sudo chmod +x /lib/systemd/system-sleep/99_restart_sound
After disabling pipewire I didn’t have any issues with sound after sleep mode but I’ll keep your script in mind if the audio problems were to return.
