No Sound after Latest Update
PinePhone Basic/Manjaro Phosh ARM/xfce desktop
[manjaro@manjaro-arm ~]$ inxi -Fxz
  Kernel: 6.4.14-1-MANJARO-ARM arch: aarch64 bits: 64 compiler: gcc
    v: 12.1.0 Desktop: Xfce v: 4.18.1 Distro: Manjaro ARM base: Arch Linux
  Type: ARM System: Pine64 PinePhone (1.2) details: N/A serial: <filter>
  ID-1: axp20x-battery charge: 53% condition: N/A/8.2 Wh volts: 3.7
    min: 3.0 model: N/A status: discharging
  ID-2: ip5xxx-battery charge: N/A condition: N/A/18.0 Wh volts: N/A
    min: 3.0 model: N/A status: N/A
  Info: quad core model: N/A variant: cortex-a53 bits: 64 type: MCP
    arch: ARMv8 rev: 4
  Speed (MHz): avg: 648 min/max: 648/1152 cores: 1: 648 2: 648 3: 648
    4: 648 bogomips: N/A
  Features: Use -f option to see features
  Device-1: sun50i-a64-mali driver: lima v: kernel bus-ID: N/A
  Device-2: sun50i-a64-dw-hdmi driver: sun8i_dw_hdmi v: N/A
    bus-ID: N/A
  Device-3: sun50i-a64-display-engine driver: sun4i_drm v: N/A
    bus-ID: N/A
  Device-4: sun9i-a80-hdmi-audio driver: N/A bus-ID: N/A
  Display: server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 driver:
    X: loaded: modesetting dri: sun4i-drm
    gpu: lima,sun8i_dw_hdmi,sun4i_drm resolution: 1440x720~60Hz
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: sun50i-a64-dw-hdmi driver: sun8i_dw_hdmi bus-ID: N/A
  Device-2: simple-audio-card driver: asoc_simple_card bus-ID: N/A
  Device-3: sun9i-a80-hdmi-audio driver: N/A bus-ID: N/A
  API: ALSA v: k6.4.14-1-MANJARO-ARM status: kernel-api
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 0.3.83 status: off
  Server-3: PulseAudio v: 16.1 status: active
  Device-1: mmc-pwrseq-simple driver: pwrseq_simple v: N/A port: N/A
    bus-ID: N/A
  Device-2: sun50i-a64-emac driver: N/A port: N/A bus-ID: N/A
  Device-1: dw-apb-uart driver: dw_apb_uart bus-ID: N/A
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter>
    bt-v: 4.1 lmp-v: 7
  Device-2: dw-apb-uart driver: N/A bus-ID: N/A
  Local Storage: total: 57.94 GiB used: 28.53 GiB (49.2%)
  ID-1: /dev/mmcblk0 vendor: SanDisk model: SD32G size: 28.82 GiB
  ID-2: /dev/mmcblk2 vendor: SanDisk model: DA4032 size: 29.12 GiB
  ID-1: / size: 28.12 GiB used: 14.2 GiB (50.5%) fs: ext4
    dev: /dev/mmcblk2p2
  ID-2: /boot size: 457.5 MiB used: 39.6 MiB (8.7%) fs: vfat
    dev: /dev/mmcblk2p1
  ID-1: swap-1 type: zram size: 4.39 GiB used: 0 KiB (0.0%)
    dev: /dev/zram0
  System Temperatures: cpu: 41.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 193 Uptime: 13m Memory: total: N/A available: 2.92 GiB
  used: 794 MiB (26.5%) Init: systemd Compilers: gcc: 12.1.0
  Packages: 1080 Shell: Bash v: 5.2.15 inxi: 3.3.31
[manjaro@manjaro-arm ~]$ systemctl --user start pipwewire-pulse
Failed to start pipwewire-pulse.service: Unit pipwewire-pulse.service not found.
No sound from speaker/headphones. Installed alsa-utils but the controls are enabled and at full-blast.
Also, the update said it was having to remove some packages, which I’ve noted, but am unsure if they are pertinent:
( 1/41) removing amtk                              [################] 100%
( 2/41) removing kactivities                       [################] 100%
( 3/41) removing kparts                            [################] 100%
( 4/41) removing kcmutils                          [################] 100%
( 5/41) removing kdeclarative                      [################] 100%
( 6/41) removing syntax-highlighting               [################] 100%
( 7/41) removing kdnssd                            [################] 100%
( 8/41) removing knewstuff                         [################] 100%
( 9/41) removing syndication                       [################] 100%
(10/41) removing kpackage                          [################] 100%
(11/41) removing baloo                             [################] 100%
(12/41) removing kio                               [################] 100%
(13/41) removing kded                              [################] 100%
(14/41) removing ktextwidgets                      [################] 100%
(15/41) removing sonnet                            [################] 100%
(16/41) removing kcompletion                       [################] 100%
(17/41) removing kwallet                           [################] 100%
(18/41) removing kservice                          [################] 100%
(19/41) removing knotifications                    [################] 100%
(20/41) removing kbookmarks                        [################] 100%
(21/41) removing kxmlgui                           [################] 100%
(22/41) removing kitemviews                        [################] 100%
(23/41) removing kiconthemes                       [################] 100%
(24/41) removing kconfigwidgets                    [################] 100%
(25/41) removing kguiaddons                        [################] 100%
(26/41) removing kcodecs                           [################] 100%
(27/41) removing kauth                             [################] 100%
(28/41) removing kglobalaccel                      [################] 100%
(29/41) removing kcrash                            [################] 100%
(30/41) removing kwindowsystem                     [################] 100%
(31/41) removing kdbusaddons                       [################] 100%
(32/41) removing kjobwidgets                       [################] 100%
(33/41) removing kwidgetsaddons                    [################] 100%
(34/41) removing solid                             [################] 100%
(35/41) removing kidletime                         [################] 100%
(36/41) removing kfilemetadata                     [################] 100%
(37/41) removing kcoreaddons                       [################] 100%
(38/41) removing kconfig                           [################] 100%
(39/41) removing karchive                          [################] 100%
(40/41) removing ki18n                             [################] 100%
(41/41) removing attica
Thanks, and help would be much appreciated.
alsamixer -c 0
restored sound even after reboot ( didn’t play with any of its controls)
Any particular reason why this might’ve happened?
